should i put the renesis engine in a porsche 944
Old Nov 22, 2006 | 01:10 AM
p-trix's Avatar
I bought a 89 porsche 944 non turbo with the Audi engine.. My mechanic told me he could put a rx8 engine in for a good price.. Should I
Old Nov 22, 2006 | 01:21 AM
maybeashinka?'s Avatar
Can I change my username?
yes you should. light eight car. light weight engine. high powered do it.
Old Nov 22, 2006 | 01:32 AM
Raptor2k's Avatar
Club Marbles Member
The better question is do you have larger pics of your avatar? kay thanks
Go for it...but what's a good price?
Old Nov 22, 2006 | 04:10 AM
p-trix's Avatar
$4500 for the engine.....and a correction...the engine is from a rx7
Old Nov 22, 2006 | 06:22 AM
LostAngel's Avatar
rx7 engine isn't a renesis engine...it's a different design of the rotary. Good luck.
Old Nov 22, 2006 | 11:39 AM
Go48's Avatar
That price should include installation. If not, go elsewhere. You can have a reman 13B engine for half that price. Of course, that's for a basic engine without the trimmings so maybe that isn't such a bad price. I would still expect that to include installation.
Old Nov 22, 2006 | 11:44 AM
dynamho's Avatar
What do you want to do with it? The car was designed for the inline4 it came with. You'll likely mess up the dynamics of the car by putting in a Renesis, so you'll probably have to spend quite a bit on tuning the suspension to match the new powerplant.
You'll probably also need a new transmission (and a new tach) to keep up with 9000 RPMs. I doubt the existing transmission can handle the dramatically different character of the engine. Even if it can, the power curve of the Renesis and the existing transmission will be a mismatch resulting in a weird final powerband.
Old Nov 22, 2006 | 12:45 PM
That would be a good 13b engine in that car.
Old Nov 22, 2006 | 12:49 PM
ZoomZoomH's Avatar
Mulligan User
944 = FC RX-7's richer piston-based twin brother
Old Nov 22, 2006 | 12:51 PM
before we answer any more questions, we'll need that picture request fulfilled....
My first impulse on this was, "ABSOLUTELY NOT". BUT.... it might be an interesting project. Other then just to be different, any reason you want to do the swap?
Old Nov 22, 2006 | 01:11 PM
Phantom Menace's Avatar
II SOCIETY
Cool
I second Raptor-man...more pics of your Avatar!
P.S. Is that you??? *sigh* If so, "How you do'in?"
Old Nov 22, 2006 | 01:25 PM
RotaryP7's Avatar
Seriously.. FML..
Heh, remove that Audi engine.. I would go with the rotary. Whatever it is, RX7 or 8.
Old Nov 22, 2006 | 03:52 PM
p-trix's Avatar
that is the price installed..with transmission.. i got the car for free ( just payed to tow it) it works fine.. looked like and rx7 in a way so i asked my rotary mechanic about putting one in..the car is beautifull re done red interior and suede dash black paint (needs repainting) and 100% dent/ding free...
Old Nov 22, 2006 | 03:57 PM
p-trix's Avatar
and to lost angel...i made the correction...
Old Nov 22, 2006 | 04:11 PM
climacus's Avatar
How do you mate a 13B to the Porsche rear-transaxle?
Old Nov 22, 2006 | 05:25 PM
N rider89's Avatar
^NieL
hey why not it would be just cool to have. just make sure that you wont be spending tons more making sure everthing is set up right
Old Nov 22, 2006 | 06:30 PM
AdRoCK3217's Avatar
Rotary Superstar
If the 944 is rear-engine (I can't really remember..)..
Many a rotary has been mounted to a transaxle.
Old Nov 22, 2006 | 06:37 PM
kartweb's Avatar
My son is putting a Renesis in a 914. The motor cost $2200 but he had to pull it along with stripping out the wiring harness & ECM. He clipped about a dozen wires and snagged a few extra goodies like the go pedal switch.
The biggest challenge has been converting it to water cooled with cutting major holes in the front trunk area. Thats coming along pretty well although there has been some pretty intricate steel fab work to channel air from the radiators to exhaust through the front wheel wells without passing through the trunk. Lots of TIG welding with compound curves. Fenders are handmade steel flares.
Connecting the motor to the gearbox is the easy part. Will have to fab the adapter with a new starter mount and a bearing fork but thats later in the project. Currently he's fitting the heater core and new pedal assembly - Top mounted rather then bottom with a two Brembo master cylinders and a cockpit adjustable balance bar.
It will probably take him another year to finish the car but it's going to be pretty sweet.
Old Nov 22, 2006 | 06:54 PM
ZoomZoomH's Avatar
Mulligan User
the 944 is a front engine, rear wheel drive Porsche....
Old Nov 22, 2006 | 08:32 PM
II SOCIETY
MORE PIX!
Old Nov 23, 2006 | 02:22 AM
p-trix's Avatar
imma guy
Old Nov 23, 2006 | 08:03 AM
TRZ750's Avatar
A company called Kennedy Engineering use to make adapters for many engines, including the rotary. Don't know if they still exist. Many rotarys were installed in dune buggies using their adapters. Biggest issue is that the rotary has the main shaft in the center of the engine. So, even with a special oil pan, is lower than the VW or Porsche engine and needs to be protected (even possible raising the rear vehicle height).
Just did a quick search. Found them. http://www.kennedyeng.com/
Old Nov 23, 2006 | 02:06 PM
II SOCIETY
imma guy
Eeewww! Never mind....my compliments to your surgeon though.
Old Nov 23, 2006 | 04:46 PM
ucleadguitar's Avatar
6 spd Newbie
Where you located...if your in NY i know of a shop that can probably do the whole installation a little cheaper. You want the 13B Turbo2 engine and I would fully build it up before doing the install. Make sure you get some good strong apex seals or you will be shooting them out of your exhausts when you make some major boost. Good luck and would love to see the progress of this project as it goes.
Old Nov 23, 2006 | 09:39 PM
hoosier's Avatar
Oh common man, drop a 20B in it!
