Flashing Airbag light - then solid when driving?
Old Nov 21, 2006 | 01:06 AM
toxin440's Avatar
Hi all
recently was driving around and my airbag light started blinking every now and then. When driving home later it was solid off "normal" the whole trip. TODAY it was blinking for a bit then went solid on.
The only thing ive done recently was run my Amp power wire thru the firewall (down the passenger side) and to the trunk and then even more recently wire up my 6XS audiocontrol crossover hooked into the center console ashtray power and ground wire (and the wires run hidden under the console to the trunk. Currently I have all my back seats out (to where the metal covering the gas tank is exposed while I slowly work on my sound system. I'm partially hoping that once I get everything done the light will somehow go away but I'm always concerned and hope to get some ideas from you guys.
Thanks in advance!
Jeff
Old Nov 21, 2006 | 01:23 AM
Tamas's Avatar
Registered Lunatic
Once your car is together again, take it to the dealer and let them diagnose the problem. Should be warranty work.
Old Nov 21, 2006 | 01:40 AM
BoosTED's Avatar
Check the connectors under the dash for the air bags and under the seats. They can get disconnected and throw a light.
Make sure and disconnect power before reconnecting them to make sure they do not go off.
They are deployed if grounded.
If you aren't comfortable with doing that then the dealer should take care of it as warranty work as long as you didn't disrupt something with the audio install.
Old Nov 21, 2006 | 08:25 AM
MX6_2_RX8's Avatar
A nice step up!!!
Airbag TSB Thread
There is a TSB for this. Mine had the problem and it was corrected with this:
https://www.rx8club.com/showthread.p...verlay+harness
Audio Concepts ATL
Sep 26, 2021 01:59 PM
ShadowDragon78
Aug 21, 2015 03:29 PM
atmd
Aug 19, 2015 12:43 PM
mesaboogie
Aug 7, 2015 10:48 AM
Kim Jong Illest
Aug 6, 2015 02:34 PM
