VIDEO: a perfect TakeOff with MazdaSpeed Exhaust & Intake Sound by CrazySte
Old Nov 19, 2006 | 02:25 PM
CrazySte's Avatar
Thumbs up VIDEO: a perfect TakeOff with MazdaSpeed Exhaust & Intake Sound by CrazySte
HI EVERYBODY,
the other day, i decided to record a couple of Videos of me running with my RX-8, so, i said... let's give the grand opening to my new Kumho tires, so, i stopped at a red stop light, i grabbed my camera, and i self recorded some clips, the firs one, obviously, si a take off... from 0 to 90Mph:
" http://videos.streetfire.net/video/4...7d00ae1481.htm "
Well, i'm sorry if the images are a little bit bouncy, but i was holding the camera while driving, and, it's not that comfortable to hold the camcorder and shift gears, but, i hope you liked it anyway.
I also wanted to test the capability of the Wankel in second gear, so, i putted the second gear and, from standing there, i released the throttole , then, when it was at the minimum rpm stable, a stept on the accellerator, and this is the result:
" http://videos.streetfire.net/video/5...7e00c307eb.htm "
Well, as you can hear, this is the sound of the MazdaSpeed Sport CatBack Dual Exhaust, plus, the MazdaSpeed Sport Cold Air Intake... it sounds great, i love it.
I Did also some other clips at higher speed, but there are some problem with the posting today, so, i will post them in the next days.
Home you likes theese first two.
by
CrazySte
Old Nov 19, 2006 | 02:31 PM
A lot of intake noise.
Old Nov 19, 2006 | 02:33 PM
Lasse wankel's Avatar
Lasse wankel
I just klocked it! 0-60 mph in 7.5s could be better with the mods you have. Anyway cool video!
/Lasse
Old Nov 19, 2006 | 02:36 PM
CrazySte's Avatar
HI Razz,
you know what?
You are right, the Cold Air Intake makes more noise than the Exhaust, but, bhelive me, there is a heck of a difference.
With the only intake, the Car is noisy only when you are pushing the pedal to metal, instead, with the exhaust the sound increases progressivly with the increase of the rpm's, but, the best thing is that when you are cruising ad Highway at costant speed, the noise reduces a lot, close to nothing if you are between 4000 and 5000rpm, ant that's perfect because like that you can even travel a little bit with this car, but at the same time have a very good sound.
BEST REGARDS
Old Nov 19, 2006 | 02:43 PM
CrazySte's Avatar
/Lasse
HI Lasse,
i know, the tires where brand new, just 3 mile on them, and at the take off the slipped just a bit, but then, they where perfect, the thing that influenced the most was that i was going a little uphill, nothing particular, but always something.
I did another video, right before changing the tires, and, i slipped not only at the take off but also between first and second gear, and a little jump with the third... but, it's not bad, Mazda declares 6.4 Sec for the 0 to 60, thinking that it was kind of cold around here and the tires where new... i don't think that i could have done much better than that on that road.
I will post the other video, wich was done on a flat road... just let me wait until they fix the problems with the site... i have some very very nice clips to post
BEST REGARDS
Old Nov 19, 2006 | 03:09 PM
dtorre's Avatar
Ultimate ****** Goderator
that was like a 16 or 17 second quarter mile there ...feather the throttle a little more and launch a little higher you'll be good to go...allthough your tranny won't
Old Nov 19, 2006 | 03:13 PM
Nopstnz's Avatar
Why do you shift so high? Power peaks at 8500, anything over that is just more noise.
Old Nov 19, 2006 | 03:39 PM
Brettus's Avatar
Boosted Kiwi
If you ever saw a chart of acceleration in gears you would not say that . There is still plenty of power after 8500 to get the best out of each gear.
Old Nov 19, 2006 | 03:48 PM
Nopstnz's Avatar
Heh, 2 days ago I was reading through a thread and all they were talking about was where the power peaks and everyone was saying 8500. I vaguely remember it. I think it was one where some guy asked how much hp was the engine making at 7500 rpm or something.
Old Nov 19, 2006 | 03:53 PM
Paul_in_DC's Avatar
Rotary Public
Perfect takeoff?!? Uh................. no.
Old Nov 19, 2006 | 03:57 PM
flomulgator's Avatar
Someone correct me if I'm wrong but I believe air is the limiting factor in peak power not fuel. He has a CAI + exhaust, so logically power past 8500 rpm would be increased if not increasing on his car. It certainly is not engine design/friction. If fed properly a rotary will keep making more power until it asplodes or the world starts spinning backwards.
Plus you have to look at power at 9500 vs 7500. I believe the fall off is less severe than the climb........And you get to shift later.
Old Nov 19, 2006 | 04:13 PM
Brettus's Avatar
Boosted Kiwi
hey crazy ,
just did an interesting comparison - put your vid & mine on the same screen
http://www.youtube.com/watch?v=NzlvSC_8N-Y
If you start yours approx. 2 seconds after the start of mine you will get them at the same point (although I was not doing a drag start)
Note mine is quite a bit quicker through 1st & 2nd then in third about the same but check my speedo - 163 km/hr (101 mph) . I have higher ratio 3rd gear .
Doing this will demonstrate the benifit of a lightweight flywheel & piggyback ems if anyone is interested.
Old Nov 20, 2006 | 01:20 PM
devildog1679's Avatar
Sounds great. My car is currently at the dealer getting the MS CAI, MS catback, and MS flywheel. Cant wait to get it back
Old Nov 20, 2006 | 09:14 PM
Magsz's Avatar
Please pardon my stupidity here but could anyone link to which exhaust you're currently running?
From what i see on the mazdaspeed site there are two aftermarket exhausts available and im not sure which one is better. What exactly is the difference?
Old Nov 21, 2006 | 10:01 AM
TheBri's Avatar
Spastic Monkey
I seem to recall reading on this site that the Mazdaspeed exhaust does nothing but change the sound. If you're going to replace the exhaust why not get something that is actually going to get you some sort of performance gain?
Old Nov 21, 2006 | 10:12 AM
bsteimel's Avatar
Nice !!!
http://www.shodor.org/interactivate/...crosystems_Inc.
opened another window and clocked it, useful little tool for online videos
Old Nov 21, 2006 | 10:28 AM
dynamho's Avatar
Brettus is right. If you shift at power peak, you're not getting the best acceleration... usually. Transmission designers consider many things (more than I can possibly imagine) and one of them is to match up the gear ratios to provide the broadest powerband without losing the car's character. Unless the power curve abruptly drops after peaking, it usually doesn't make sense to shift at peak.
Think of it this way. If you shift at peak, your next gear will usually be in a less than ideal position in the powerband.
Transmission is one of the things amateur tuners neglect. When you boost your engine power, ideally you should change your gear ratios also to take advantage of that power. I see guys making 300+ HPs and effectively convert their vehicles from a 6 speed into a 5 speed because they can't use their first gear (spin out) and their entire power spectrum is all screwed up.
Old Nov 21, 2006 | 10:38 AM
That is a lot of intake noise..
Old Nov 21, 2006 | 10:48 AM
Dremd911's Avatar
Dre's 8 "I started Late"
dam...that youtube video was quick....do you have a blow off valve...sounded like it out of first gear.....how much does a cold air intake and ms speed exhaust run installed?
Old Nov 21, 2006 | 11:13 AM
Renesis_8's Avatar
youtube video is in km/h
________
Effects of depakote
Old Nov 21, 2006 | 11:34 AM
L8APEX's Avatar
Smooth Criminal
umm...there isn't one that gains anymore than 3-4 HP. Unless you start to get illegal and emmisions non-compliant.
Old Nov 21, 2006 | 12:12 PM
peterisurhero's Avatar
peterisurhero
hey crazyste. do you have anything else besides the exhaust and the intake? your revs seem to go by pretty quickly. juss askin to make sure.
Old Nov 21, 2006 | 03:47 PM
Brettus's Avatar
Boosted Kiwi
Assume you are talking about my vid - I can't hear the noise you are talking about . I do get the 'pop' between gearchanges due to having no cat .
GK1707
Dec 2, 2015 10:01 AM
SupraG
Sep 21, 2015 12:09 AM
rx8wankelrotary
Aug 17, 2015 10:42 AM
SupraG
Aug 3, 2015 10:03 PM
AussieGray
Jul 16, 2015 03:58 AM
