Thumping while Driving
Old Nov 19, 2006 | 10:50 AM
deee's Avatar
I need help diagnosing a problem. My car just started making thumping sounds while I am driving in a straight line or while turning. It's exactly like a have a twig stuck on one of my tires and running it over and over again. As I accelerate the intervals between thumping goes increases as if the intervals are related to the car's speed. I check the threads on the tires and nothign seems to be stuck. I did a search already and I didn't really see anything about it. The closest one is the TSB with the clicking while turning, but I don't think that is it. I checked for loose lug nuts earlier and everyone of them is good. I'm about to jack the car up to see if its bad wheel bearings. Thanks in advance.
Old Nov 19, 2006 | 11:03 AM
XRX8X's Avatar
more then a Mazda
there are three ways to go .1.first try and find out if it's right front or right rear etc.2.have someone follow you and look at all four tire's one at a time(try to find a quiet road and no traffic for safety reasons)3.jack up the car on a lift and rotate each tire one at a time with the e-brake off once the car is off the ground and check to see if the tire's are tight,loose lug nuts,or worst case a steel belt inside the tire broke.this won't let the tire go flat but it's not too safe to ride on at highway speeds.(have you hit any pot holes lately?)also check the tread to make sure there is nothing inbeded in the groves.good luck!
Old Nov 19, 2006 | 11:06 AM
ken-x8's Avatar
Take a closer look at the tires, too. It could be a tread separation. When you've got it jacked up to check the bearings, look for a bulge in the tread, or a slight puckering in the sidewall.
Ken
Old Nov 19, 2006 | 11:19 AM
XRX8X's Avatar
more then a Mazda
just thought of something did you have a flat and filled your tire with the goop for flats or did you put on the spare tire?don't know if you have the spare tire or the tire repair kit!if you put that stuff in your tire it is most likely time to buy a couple of tires.
Old Nov 19, 2006 | 12:13 PM
deee's Avatar
Found the problem. I found a really giant screw stuck in inner side tire wall. I had to remove the entire tire to see it. The screw came complete with a giant washer. I guess it new tire time for my 8. I'm glad my worriers are over. I was all thinking it was the differential. Thanks for your help!! It's been a bad week for my car. Someone backed into my car on Wed, this tire thing last night, and to top it off I stepped on dog crap and didn't realize it until it was all over my floor mat this morning, but I am glad things are getting better though.
Old Nov 19, 2006 | 02:50 PM
Glad it was a simple problem.
Old Nov 19, 2006 | 03:33 PM
Paul_in_DC's Avatar
Rotary Public
I often get a thumping sound under my car when I'm in a neighborhood full of cats.
Old Nov 19, 2006 | 04:15 PM
Really? I hear screaming meow!!!!!!!
I think my suspension mod is working. Can't out dodge me now!
Old Nov 19, 2006 | 04:24 PM
RedSheDevil's Avatar
.:. causing mischief
thumping noise can often come from those bodies in the trunk
sorry about the dog poo ...
Old Nov 19, 2006 | 06:46 PM
mdw1000's Avatar
I'll snap his neck.
Sounds like a bad week - you need a vacation!
xAgyex
Jun 3, 2026 03:47 PM
ktec
Jun 26, 2021 10:18 AM
Dokuji
Nov 1, 2016 02:51 PM
wayloco
Sep 1, 2015 09:03 PM
arjunmshah
Aug 6, 2015 10:56 AM
