View Poll Results: Nitrous or Exhaust?
HKS Single sided exhaust
46.67%
Screw exhaust GET THE NITROUS!
53.33%
Voters: 15. You may not vote on this poll
Nitrous or exhaust ( help me decide
Old Nov 17, 2006 | 01:32 AM
kw1k's Avatar
I can't figure out what to get, Do i want nitrous or do i want exhaust 1st..
I know i'm going to get them both eventually it's just which one 1st! help me?
the exhuast im looking at is the HKS single sided one that just came out
Old Nov 17, 2006 | 01:34 AM
phroztbyt3's Avatar
u want good sound first.. then power.
Old Nov 17, 2006 | 03:51 PM
shaunv74's Avatar
Power!!
First: read the exhaust threads and the nitrous threads specifially Charles R Hill. Then you can make your own decision based on what you want.
Here's my summary:
exhaust cost=~$500
HP gain=2
$/HP= $250
Nitrous cost= $2-3K (best guess)
HP gain=55 (conservative starter kit)
$/HP=54
Nitrous gives you better bang for the buck. My $.02
Old Nov 17, 2006 | 03:58 PM
new2me's Avatar
What the...
my nitrous was $450ish plus $300ish for extras ie. remote opener, purge n heater. im holding out on buying a second bottle and setting them up together. i would go with the nitrous first as it gives you the most gain in terms of power. before you jump in it read the "nitrous..." post first. its a lot but it has a ton of info from trial and error of a bunch of guys.
but, if you are looking for that louder 8 then you will want to go with the exhaust but you may have a sleeper with the nitrous on stock exhaust. it all comes down to personal preference. good luck
Old Nov 17, 2006 | 04:03 PM
alnielsen's Avatar
Here's another variable:
RP Supercat = $395
HP gain = 8
$/HP = 49.3
You were just thinking of a catback.
Fanman's Avatar
Jack, what are you looking for right now power or sound ? If it was me, I would do the nitrous. Get the Rp Supercat (and it will make the exhaust louder), and see att hat point if you want it louder. Be aware that a single sided exhaust will be really loud. But also the hp gain is quite a bit more than 2 hp. Because of the design of the (HKS) single sided the exhaust is much more stright thru. On our (& most aftermarket) double sided exhausts the exhaust gasses go thru the cat, and the C-pipe and hits/seprates right in the middle of the 2 mufflers and has to travel sideways, then out. The HKS single sided is pretty much straight out from exhaust. Imagint a upside down "T" for the double sided exhaust vs. an "I" for the single sided. Not to mention the weight savings.
Old Nov 17, 2006 | 04:08 PM
exhaust!! becareful with nitrous...
Xantium's Avatar
Unregistered User
I dont see how you could spend 2-3k on nitrous... maybe direct port but thats not what you want if you're only running a 55shot. A dry kit should be about 500... wet kit 700... you'll want a wet kit if you plan on ever running a reflashed ecu.
Old Nov 17, 2006 | 04:17 PM
shaunv74's Avatar
Power!!
Racing Beat stated they only got 5 hp when they removed the exhaust all together (I assume after the cat) so you shouldn't expect to see more than that at the most. Either way I agree with Fanman. Go with the nitrous. If you want to do the exhaust he's right you're better off doing the high flow cat instead.
Old Nov 17, 2006 | 04:22 PM
shaunv74's Avatar
Power!!
Even better then. You pay about the same price as the exhaust and you get big power on demand!
Old Nov 17, 2006 | 04:41 PM
Former A4'er's Avatar
WTF?
If I could go back to when I got my car, I think I would have gone with a zex wet kit instead of bolt ons.
I do like the sound of my exhaust though.
Old Nov 17, 2006 | 04:55 PM
Fanman's Avatar
Yeah, I'm not saying like 10-15 hp like some of these vendors claim, but like 5 hp (vs. 2-2.5 hp of a dual) on a NA car, and about 15-20 lbs in weight savings.
Old Nov 17, 2006 | 05:16 PM
Phantom Menace's Avatar
II SOCIETY
I'd do exhaust first...then the Nos if you must. But yeah, I second...BEWARE OF THE NOS. Its not kid and play like some merchants may say. You might be cutting serious years off of your engines life...
JimmyBlack
273
Feb 10, 2020 10:23 PM
LB2739
Jul 9, 2019 02:25 AM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
mitchrx8
Sep 13, 2015 08:05 AM
