BS Wheel options
Old Nov 12, 2006 | 10:06 AM
StrokerAce's Avatar
BS Wheel options
I've been doing some research this week. Have I missed any options
BS Wheels
OEM 18x8 50mm 22#? $375 new
Enkei RPM2 18x8 45mm 19.4# $261
Enkei RC-T4 18x8 45mm
Rota Formula 18x8 48mm 22.5# $165
Rota Torque 18x8 48mm # $175
OZ Ultraleggera 18x8 mm 18.4# $325
Mazdaspeed 18x8 ?mm 16# $500
SSR Comp 18x8 ?mm No longer available
STU
Enkei RP-F1 18x9.5 38 or 45mm $309
Old Nov 12, 2006 | 05:43 PM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
There are a few choices on the old style MazdaSpeed wheel.
Gold 5 spoke 16.9 lbs $610ea retail
Gun metal 5 spoke 17.6 lbs $610ea retail
Magnesium gold 5 spoke 16 lbs $1685ea retail
No idea what the new 10 spoke MazdaSpeed wheel weighs..... found this:
https://www.rx8club.com/showthread.p...9&page=3&pp=15
Looks like around $500ea and 20 lbs for the new MS wheel.
Old Nov 12, 2006 | 09:01 PM
I think Clyde is planning to sell a set of 18 x 8 x 44mm offset Kodiak 3 pc wheels he got from me last year, 16.5 lbs each
here's a pic of his car with them mounted:
Old Nov 12, 2006 | 11:19 PM
StrokerAce's Avatar
Found another
WedsSport SA-70 18x8 50mm 18.8# $339
Old Nov 12, 2006 | 11:21 PM
ULLLOSE's Avatar
Why are you listing wheels that are not BS legal in a thread about BS wheel options?
The Weds SA-70 18X8 50mm is 18.8 lbs and $339.
Old Nov 12, 2006 | 11:25 PM
scsi's Avatar
if u want the best grab some Volk CE28N
www.wheelweights.net
Old Nov 12, 2006 | 11:40 PM
ULLLOSE's Avatar
Not BS legal... the 18X8 5-114.3 only comes in a 33 or 38mm offset.
Old Nov 13, 2006 | 01:13 AM
scsi's Avatar
oh i thought any offset would work. what is the offset restriction?
Old Nov 13, 2006 | 02:02 AM
Sparky's Avatar
I talk to cones
Stock class requires stock offset (50mm) +/- 1/4" (6.35mm). So anything down to 44mm will work. You wouldn't want anything greater than 50mm as that's going in the wrong direction (reducing track width).
If you think you might be serious about running autox, even as a remote possibility, make sure and read the rules before making major upgrade purchases for you vehicle. They can be found here:
http://www.scca.org/_FileLibrary/Fil...solo_rules.pdf
It only takes a few minutes to do so and can save you lots of money.
balefire's Avatar
SCCA BS #35
http://www.scca.com/Solo/Index.asp?IdS=0D1A33-8C98740&x=050|070&~=
+/- 0.25 in or +/- 6.35 mm from stock
Old Nov 13, 2006 | 05:48 AM
scsi's Avatar
heh well, i run in STU, so im not too keen on the rules for BS. good to know though, thanks!
Old Nov 13, 2006 | 10:01 AM
you still have a lot to learn, grasshopper
Old Nov 13, 2006 | 11:06 AM
Sparky's Avatar
I talk to cones
One of these days someone's actually going to listen.
Old Nov 14, 2006 | 01:01 AM
F/R track variation can work to your advantage, depending on the overall balance of the car and the limitations of the rules
whether you listen isn't relevant ...
Old Nov 14, 2006 | 01:08 AM
Sparky's Avatar
I talk to cones
Now i'm listening. Kinda interesting though that you would post that comment on the same page as a picture of your 44mm offset wheels for a B Stock RX-8 which is the subject of this thread. Where you just taking it easy on us before
Old Nov 14, 2006 | 09:09 AM
altiain's Avatar
Sparky!
Two other legal Rota options:
P-45F - 18x8, +48mm, ~19lbs
D2 - 18x8, +48mm, ?#
Old Nov 14, 2006 | 12:06 PM
John V's Avatar
Not ******
Jeez, aftermarket wheels are expensive. We should just mandate 17x8's and Falkens for everyone.
Old Nov 14, 2006 | 08:21 PM
lol, add in the word "porsche" and the price doubles
Old Nov 14, 2006 | 08:30 PM
I ran quite a different setup and had no balance issues. Reread the conditional response in my previous reply.
I guess now that you scored a decent Nats finish your convinced you've conquered the world, back at ya' ...
Old Nov 14, 2006 | 09:38 PM
Sparky's Avatar
I talk to cones
Hardly, but if you're telling me that a car with near 50/50 weight distribution and good camber curves on both ends needs to resort to F/R track variation in order to run well, then I'd say you've been dipping back into you're 800lb spring stash again.
Old Nov 14, 2006 | 09:39 PM
mwood's Avatar
It looks like you can get the Mazdaspeed wheels for $516/ea. Not exactly a bargain, but still almost $100 under Mazda's price. Also, a few of the listings for the rims have the weight at 16.0lbs, regardless as to finish, vs. Mazda's claim of 16.98 for gold and 17.64 for grey. I'm not sure I understand how a gold center rim can weigh 3/4lbs. less than a grey center rim, per the Mazda USA web site...
Old Nov 15, 2006 | 08:13 PM
M23RX8's Avatar
So what is the estimated time gain on a 60 second course with, lets say, a 17lb wheel vs. the OEM? I have an idea, just want to see what you guys say.
Old Nov 15, 2006 | 08:59 PM
Do you realize how many variables exist in a single autox run? Even if you can run the exact same time on the same course it's extremely unlikely that you actually made an identical run. There's really no good way to say. Either you run the fastest time or you don't. It doesn't even mean you were the best driver or had the best car. It only means that you went faster than someone else.
Lighter wheels potentially offer a quicker time than heavy wheels. In reality, it just depends.
Old Nov 15, 2006 | 09:26 PM
StrokerAce's Avatar
Ran across another issue to worry about. Found some almost exactly right wheels (even good looking, cheep and a little lighter) but they have too small of a hub centric. Anybody had a machine shop recut a hubcentric for a larger diameter?
Lighter should be faster (little). However I thought my my miata that heavy front wheels were better for times because the extra rotational force cut the inside front lockup a lot.
Ray
Old Nov 15, 2006 | 09:39 PM
M23RX8's Avatar
Hahaha, ya Ive autox'ed a little myself, thanks. And I said estimated, not exact. Im asking the question because if everyone is so gung ho on getting the lightest wheel out there, they must have an idea of what kind of time they are saving. Otherwise why buy it?
I havent autox'ed the 8 but in my 2700lb, 145hp, STS car a 7lb loss per corner was worth maybe .3-.5 seconds on a 40 second course although yes, that could never truly be proven.
