skillmaker
10-26-2006, 04:19 PM
I have Koni 8240-1227 adjustable rear shocks.
However, you must remove and disassemble the shock/coil assembly to adjust the shock damping. I would like to find out if there is a remote adjustment kit available.
I e-mailed Koni NA, and have not received an answer after several days.
Does anyone know if Koni makes a remote adjustment kit for these rear shocks? I know that the rear Tokico shocks have remote adjusters available for an extra cost. I would HOPE that Koni does as well.
Can anyone help me out here?
nycgps
10-26-2006, 04:42 PM
Do NOT go to Koni-NA site, I think their site has been compromised and someone already put a trojan on it. the Downloader Trojan will install to your PC if you use Internet Explorer.
I dont think Koni makes anything like that. Yes its a pain to remove it everytime u want to change something.
swoope
10-27-2006, 02:24 AM
contact phil at dpe. in the vendors forum.. it can be done, but it is not cheap.. if fact it is expensive..
beers :beer:
TeamRX8
10-29-2006, 02:58 PM
nope, can't fit a remote adjuster to the Koni, You can make it externally adjustable with a tab at the top of the shaft so that it can be adjusted with the usual Koni adjustment knob, but that is all and the shock/spring assy still needs to be dropped down to have access to the adjuster
there is no trojan on the Koni website either :hahano:
Red Devil
10-29-2006, 06:46 PM
beers :beer:
Yeah, check in the DPE forum. I posted up some information regarding this there after speaking with Truechoice about the possibility...
olddragger
10-29-2006, 07:26 PM
rear shock never needs adjusting anyway --set it 1/2 up from full soft and leave it alone.
od
nycgps
10-29-2006, 09:49 PM
I told them about it, they removed it after maybe 2 hours :o
The trojan only downloads itself when it detect IE 6.0. Firefox is safe :D
TeamRX8
10-29-2006, 10:04 PM
TC was able to discuss it with you because of prior avenues they explored with somebody else here ;)
the problem is the Koni uses a unique adjuster on this style shock; it gets harder to turn as it moves toward the max stiff setting. The full stiff setting requires more force than a flexible cable can withstand, or the typical 12V electric drive either.
elysium19
05-19-2009, 09:44 AM
Hey I'm bringing this thread back to life as I'm looking into buying Koni's. This is for my road car with occasional HPDE days. If I set something up AS I install, it wouldnt be a big deal...
TeamRX8: How progressive is this rear knob? I will definitely be between full soft and 50% hard; between those settings would it still be too much force for a flexible cable to withstand? It seems like I could whip some cable setup together without too much trouble.
Or should I really just stick with Olddragger's advice to set it to 50% and leave it? I don't know much about suspension tuning, but I'm assuming the front damping settings are more important than the rear?
Thanks everyone....
TeamRX8
05-19-2009, 10:28 PM
fwiw, I believe the 50% setting originated with me ;) that's what works for me and my setups, plus I have double-adjustable which along with some other settings allows me to tune around having to change rear rebound, I last changed my Stock rear rebound setting in mid-2005
others here run them at 100%, but that can be a bit tough on a DD, and again it may ultimately depend on your overall setup
sorry, I know this isn't as concrete of an answer as you'd like to have, but if you're asking me I'd suggest 50 - 60% from full soft
ps: there is no rear knob unless you have the rear shocks converted to externally adjustable or double adjustable, Koni doesn't believe a cable system will work on their shock which is why they don't offer it, I never tried and can't say if it will work or not, you're best bet will be to call Phil Harris @ Truechoice (888) 566-4722 and see if he's willing to help you explore the possiblity, I never felt the need to go there per the previous comments
