will this fit temp?
Old Oct 23, 2006 | 02:50 AM
RXSeven1's Avatar
dorito spinner
will this fit temp?
i blew out one of my rear tires so im wondering if i pull one of the wheels off the fd will it fit? is a 18x9.5 rim. with a 275/35/18 on it.... offset is +48 i think
Old Oct 23, 2006 | 12:51 PM
slavearm's Avatar
Boost Junkie
It will be very tight, probably run inside, if you add a spacer, it might fit, but probably rub on the outside. Probably require you to roll the fender a bit.
Old Oct 23, 2006 | 01:11 PM
mac11's Avatar
Rotary , eh?
make sure whatever you put on your drive axle has the same rolling circumfrence so you dont blow up a diff.
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
hufflepuff
May 30, 2016 10:45 AM
Quiggs321
Sep 30, 2015 05:34 PM
GK1707
Sep 27, 2015 07:33 PM
