13-rew 9.0 CR rotos in rx8, how to?
Old Oct 19, 2006 | 01:13 AM
20bfd3s's Avatar
hi
goal is to archieve 450hp on the renesis turbo engine in rx8.
is it possible to fit 13-rew 8.5 CR rotors to the renesis engine to lower comp. ratio?
is there any porting available for renesis?
i thought to fit 13-rew to rx8 but engine mount is very different... thus probably better is to rebuild renesis.
please advice.
Old Oct 19, 2006 | 07:29 AM
Theres like 10000000 post that the CR is NOT the factor in how many horsepower Renesis is making.
Renesis is a COMPLETELY NEW design with N/A in mind, stop going back to the old design.
Old Oct 19, 2006 | 07:47 AM
RealityRx8's Avatar
Mazdaspeedjunky
S
E
A
R
C
H
I am still a noob to this forum but at least i know how to use the search function.
It can be your friend.
RRx8
Old Oct 19, 2006 | 07:54 AM
rotary crazy's Avatar
renesis with turbo's are making as much as 400hp, with time and lots of $$$ you can make a renesis with all the power a 13b can make.
Old Oct 19, 2006 | 09:30 AM
BaronVonBigmeat's Avatar
Senor Carnegrande
^^^ FD's are routinely making 400hp and more, correct? I think there has been maybe one renesis run at 392, and it was probably running on the ragged edge of disaster (assuming pump gas).
Low compression rotors would be nice and all but you can't use existing ones. So unless you're an engineer with access to a foundry, engineering software, and/or machine shop and lots of spare time, it's not going to happen.
Old Oct 19, 2006 | 09:42 AM
maxxdamigz's Avatar
Baro Rex
450 is doable on 10:1 compression ratio. Instead of inventing a new rotor, it might be more reasonable to just build up the necessary fuel control/engine monitoring system you would need to keep it in check. There just haven't been enough 400 hp stock Renesis internals projects to really say what will give first. It might be seals, it might be the tranny, it might be XYZ other thing. The FD guys know what gives when on their engine and can plan for that.
Old Oct 19, 2006 | 09:53 AM
I dont see why Renesis cant push over 400 hp. Just need time, Someone already hit the 390+ mark, so 400+ is possible.
How many of you can make a Stock FD to go above 400 HP mark WITHOUT major modification ? and without compromising the reliability of the car ?
I dont want a car that can only run on dyno or that 12 seconds drag race, I prefer a car can last me couple of years, and be able to smoke those *stock STi nubs* on the road with easy. Renesis can do that, and its far far FAR more reliable than any 13B-REW can.
Read RG's post, it explains alot about the possiblities of Renesis. (and how to get high hp)
Old Oct 19, 2006 | 10:10 AM
mike1324a's Avatar
Need'd a Turbo
Do some seriously heavy porting on the exhaust. That is one major difference in the REW design. It uses Peripheral ports on the exhaust vs the renesis' side ports. I currently think that the exhaust is a problem right now, but no one seems to do anything about that fact that they suck! Want big power, open those exhaust ports wide open so the engine push all the air into the turbo better.
Old Oct 19, 2006 | 10:13 AM
like MR. Amemiya said, no one realises the potential of the renesis, people need time.
Red Devil's Avatar
The cost of pulling the engine is I'm sure what is holding most back. When I need a new engine, whenever that day comes, that will be one of the things I do for sure.
Old Oct 19, 2006 | 10:19 AM
rotarygod's Avatar
Originally Posted by 20bfd3s
hi
please advice.
Paragraphs 6 and 7 should answer that.
https://www.rx8club.com/showthread.p...7&page=1&pp=15
Old Oct 19, 2006 | 10:37 AM
Aseras's Avatar
the exhaust ports cant get any bigger, heck you can just barely make them flow better. twin 90 degree siamaesed exhaust ports = bad.
Old Oct 19, 2006 | 10:38 AM
mike1324a's Avatar
Need'd a Turbo
Thats my plan aswell. Turbo it then when it comes time for a rebuild, get a heavy port job as an upgrade. I think exhaust is the key to the next power level.
Old Oct 19, 2006 | 10:49 AM
RG, I have being playing around with the idea of a thicker center plate that allows for independent exhaust ports as large as the side housing ones and larger intake port maybe 7ht and 8ht auxiliary intake ports, looking at the renesis it does not have to be more than 1 1/2 inch thicker, of couse the e shaf will have to be soported by a bering to avoid e shaft flex.
what do you think?
sorry for the hijack
Old Oct 19, 2006 | 10:53 AM
rotarygod's Avatar
You don't necessarily have to make them bigger to get them to flow better. There is a lot of work that can be done inside the port runners themselves. You can make them a little larger but that's not what the real problem is.
I agree that the siamesed port design sucks.
Old Oct 19, 2006 | 09:28 PM
Senor Carnegrande
Why did they use a siamesed design anyhow? I wonder how much power they left on the table with a compromised design.
Old Oct 19, 2006 | 09:33 PM
Renesis_8's Avatar
Its cheaper to use the siamesed design. Probably quite a lot of power...
________
Electronic Cigarettes
Old Oct 20, 2006 | 10:28 AM
rotarygod's Avatar
Racing Beat played with different header designs and one of them separated the center runner into 2. They noticed no power difference.
05TR1CH
Apr 18, 2023 04:56 AM
Skyl3r
Dec 2, 2019 04:51 PM
SupraG
Sep 21, 2015 12:09 AM
vetteor8
Jul 25, 2015 11:43 AM
RX7.9
Jul 20, 2015 12:01 PM
