Rumor regarding long time storage
Old Oct 13, 2006 | 11:26 AM
JBinDallas's Avatar
05 Shinka #363
I thought that I read somewhere that said after the car has been stored for a period of several weeks or more, that damage can result from running the engine for long duration.
I just bought an RX-8 in Kansas City from a dealer and am about to drive it back to Dallas. The car has been sitting on the dealer lot for about a month.
Anyone have any thoughts or validity to this rumor
Old Oct 13, 2006 | 11:33 AM
JBinDallas's Avatar
05 Shinka #363
As an additional note this vehicle is used with about 13K miles
Old Oct 13, 2006 | 11:40 AM
therm8's Avatar
Bummed, but bring on OU!
Never heard that rumor.
But I have stored the car twice for 2.5-3 months each time. The only issue I had was a dead battery from the first storage (alarm was armed). The only thing I might recommend is storing it with low fuel and maybe some stabilizer, then filling up as soon as you can.
Old Oct 13, 2006 | 11:43 AM
Ceez76's Avatar
Ceez76
JBIN,
I bought my 2005 8 in May with no miles on it. Car had been sitting their for a few months (leftover). One week later I drove from New Jersey to Indiana. With the exception of nearly hitting "Bambi" on Interstate 80, no problems to report.
Old Oct 13, 2006 | 11:52 AM
i drive mines once every other week for over 2 years, no problems here..
Old Oct 13, 2006 | 12:41 PM
JBinDallas's Avatar
05 Shinka #363
Y'all are great. I appreciate the support. Gonna make this 500 mile run a beautiful thing tomorrow.
Old Oct 13, 2006 | 01:02 PM
Nubo's Avatar
Lubricious
Sitting for a month probably isn't going to do much except maybe drain the battery. But I'd check the intake for any signs rodents (they can make nests or chew up the filter), and a quick visual inspection of wiring and hoses (rats like to chew 'em).
If it had been sitting a year then you'd want to think about fluid changes before your long drive.
Old Oct 13, 2006 | 02:32 PM
Redshift's Avatar
Spinning Dorito Junkie
Yes on the fuel stabilizer, no on the low fuel level. Just the opposite in fact. You want your tank to be as full as possible.
If the fuel level is low you can get condensation on the inside surface of the tank, which will introduce water into the fuel system, and, in extreme cases, cause your fuel system to start rusting from the inside. (If you have a metal gas tank.)
Old Oct 13, 2006 | 10:28 PM
Chrissss's Avatar
#1 -Full fuel tank with stabilizer as already mentioned.
#2 - Pump up fires to 40+ lbs to prevent flat spotting.
#3 -Disconnect the battery so you don't kill it.
#4 -Put steel wool in the exhaust pipes to keep out rodents.
#5 -Apparently putting Bounce sheets on your floor will also keep rodents away from the interior... and make your car smell nice, too.
Chris...
Old Oct 13, 2006 | 10:42 PM
lone_wolf025's Avatar
Future Rotary User
Also a general recommendation is to store it up on jack stands to take the load off the suspension IIRC.
Old Oct 13, 2006 | 11:53 PM
Originally Posted by Chrissss
#5 -Apparently putting Bounce sheets on your floor will also keep rodents away from the interior... and make your car smell rice, too.
Chris...
That's the last thing I'd want my car to smell like! RICE
Old Oct 14, 2006 | 03:13 AM
there's a rumor going around that too many people are susceptible to believing in false rumors ...
Mxttz0r
Jul 5, 2019 03:19 AM
uZu
Dec 30, 2015 12:35 PM
HMSS013
Aug 28, 2015 03:08 PM
MrORAN6E
Jul 24, 2015 09:32 AM
tbiggybig
41
Jul 22, 2015 11:47 PM
