Need Help!!! I Screwed Up My Car!!
Old Oct 11, 2006 | 02:28 PM
peterisurhero's Avatar
peterisurhero
hey guys. todae i jacked my car up to put my 02 sensor back in becuz i didn't have it on. so wen i did that i juss jacked to car up anywhere and i bent my car. like where i jacked my car up, made a bump and i feel it inside the drivers side. anyways i guess all i could do about that is try to hammer it down from inside. but i was wondering guys, where are the jack points??
Old Oct 11, 2006 | 02:34 PM
NgoRX8's Avatar
http://www.hi-impact.org/ryang/modif...ackpoints.html
Old Oct 11, 2006 | 02:51 PM
peterisurhero
how am i supposed to reach that far down into my car with a car jack. that thing is RIGHT in the middle.
Old Oct 11, 2006 | 03:21 PM
TomAssBender's Avatar
Skeet skeet skeet
I borrowed a jack from my dad's car and jacked up both sides. This would at least give you easier access to the center jack points.
Old Oct 11, 2006 | 03:24 PM
NgoRX8's Avatar
i usually jack up one side up with the stock jack. (my car is very low). once that is high enough i stick a floor jack under.
Old Oct 11, 2006 | 03:31 PM
Nubo's Avatar
Lubricious
It's right in the middle so you can raise the entire front or back from just one jack point. Get a low-profile floor jack.
http://www.harborfreight.com/cpi/cta...emnumber=91039
Don't forget the jack-stands.
Old Oct 11, 2006 | 04:38 PM
Red Devil's Avatar
Exactly what I do, and jack from the same points as in those pictures. Works very well.
Old Oct 11, 2006 | 04:42 PM
shaunv74's Avatar
Power!!
I wouldn't get under a car without jackstands. It's really not safe. They're pretty cheap too at Sears.
Old Oct 11, 2006 | 10:59 PM
Silver_Surfer's Avatar
I4NI
Reed yo owners man-u-well
Old Oct 11, 2006 | 11:03 PM
NgoRX8's Avatar
owners manual only tells you side jack points, i believe. not 100% positive.
Old Oct 11, 2006 | 11:04 PM
rotor_head's Avatar
lol some people are just not gifted.
Old Oct 11, 2006 | 11:05 PM
the side jacking points are plenty adequate
Old Oct 11, 2006 | 11:23 PM
Im wondering whats so bad about jacking it one side at a time ?
I jack my 8 up just 2 days ago (change oil) and what I did was I jack it using the side jacking points. sure it bend some of the stuff but I think its ok.
Next time I will try to jack the center point as mention above. Cuz its almost due for Gear and Rear Diff oil change :D
Old Oct 12, 2006 | 01:04 AM
3 lb hammer..
Old Oct 12, 2006 | 01:11 AM
peterisurhero
where are the side jack points?
Old Oct 12, 2006 | 01:17 AM
have you read the owners manual... and did you try the jack that is in the back of the car???
i am trying to help you help yourself.
Old Oct 12, 2006 | 03:54 AM
ken-x8's Avatar
Nothing's wrong with that, if you're changing a wheel or doing something else that doesn't involve getting under the car.
If you're going under the car, use jack stands. The car's jack isn't stable enough to trust your life to. A hydraulic floor jack may be more stable, but does not have a positive locking mechanism.
People do get killed every now and then from trusting a jack.
Ken
Skyl3r
Dec 2, 2019 04:51 PM
MarkX
Jul 31, 2015 07:50 AM
escapedan
Series I Do It Yourself Forum
Jul 29, 2015 10:44 PM
thewatcher101
Jul 27, 2015 09:44 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
