Grinding Gears
Old Oct 11, 2006 | 08:48 AM
dgrx8's Avatar
FN GR8
Angry Grinding Gears
are grinding gears covered under our warranty??
3rd gear keeps grinding and it's driving me crazy!
it goes in smoothly but it makes a crunching noise most of the time when it gets in there.
i always had a hard time getting my 8 into 3rd when i first got the car & i'm guessing i must have damaged something (synchro possibly). can anyone shed some light on what it could be & how i can get it fixed?? thanks...
i searched but only found info on a bulletin issued for problems w/ 2nd gear on older 8's.
Old Oct 11, 2006 | 09:17 AM
lurch519's Avatar
www.evoperform.com
take it to the dealer. i took mine in for grinding 2nd and 3rd, they ended up replacing most of the internals.
https://www.rx8club.com/series-i-trouble-shooting-95/tranny-issues-ver-2-0-a-91357/
Old Oct 11, 2006 | 11:08 AM
dgrx8's Avatar
FN GR8
ok gonna take it in. so, as long as they can duplicate the grinding, they'll fix it?
Old Oct 11, 2006 | 11:20 AM
NgoRX8's Avatar
yea, if they notice it, they should replace the parts.
Old Oct 11, 2006 | 11:23 AM
no dice's Avatar
I bomb atomically
Its not the transmission, its the clutch line. Get them to swap clutch lines to a MS stainless steel and also have them perform the clutch release cleaning.. Its a TSB..
Old Oct 11, 2006 | 11:46 AM
dgrx8's Avatar
FN GR8
ummmmmmmmm...
i don't think it has anything to do w/ the clutch. i'm positive it has all to do w/ the gears...
Old Oct 11, 2006 | 09:19 PM
mazda8guy's Avatar
My 8 is geting the 2nd and 3rd gear synchros and a bent shift forks done right now. They also replaced my clutch. It wasnt worn out but it looked like it got hot, so I was told. No charge to me. Only 28000kms on it.
Old Oct 12, 2006 | 12:52 AM
if it was the clutch it would do it on all shifts..
Old Oct 12, 2006 | 08:42 AM
dgrx8's Avatar
FN GR8
that's what i was thinking as well... it's really just 3rd gear.
i'm gonna take it in & hope i get some new parts put in w/out a hassle...
thanks
Old Oct 12, 2006 | 04:11 PM
Lasse wankel's Avatar
Lasse wankel
I have big problems with my 4th gear. Can't shift fast becausse then it schratches badly and take say 1 sec to get engaged! I have Motuls new 75W-140 trans oil in gearbox.
/Lasse
Old Oct 12, 2006 | 05:42 PM
Jax_RX8's Avatar
Got Another Rotary
/Lasse
No wonder you can't shift - 75W140 is way to thick for any climate. The thickest you should use is a 75W-90 GL-4 gear oil and you could probably do a thinner 70W80 in Sweden's cool climate.
I use a GL-4 70W80 (BG Syncroshift II) in VA area of the US and it works great. Make sure you use a good GL-4 only gear oil and try to avoid GL-5/GL-4 combo oils as the GL-5 additives are more for differentials and are not so good with transmission syncros.
Old Oct 13, 2006 | 02:57 PM
dgrx8's Avatar
FN GR8
/Lasse
you really have a whole other problem, dude. i don't know why u put that weight in your box...
anyways, i'm gonna take it in soon & see what they can do... would this be a good time to have them install a flywheel? or would i get raped regardless of the warranty work being done???
Old Oct 13, 2006 | 05:56 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Then start using Royal Purple Max-Gear for the transmission and diff.
Old Oct 13, 2006 | 05:57 PM
no dice's Avatar
I bomb atomically
i still say its a clutch issue.
Old Oct 13, 2006 | 09:06 PM
lurch519's Avatar
www.evoperform.com
they have to pull the tranny to fix it, so you shouldnt be charged much if anything to get the flywheel installed. i had mine in last year for some tranny work, they had to pull the clutch because they were covering it under warranty, and they threw the flywheel in for just the price of the flywheel.
Old Oct 13, 2006 | 11:57 PM
mazda8guy's Avatar
Just got mine back for the dealer. They replaced 1st, 2nd and 3rd gears and synchros. Plus the clutch assembly. Shifts smooth so far.
Now my slave is leaking. 50km drive home and the reservoir is half full. Big puddle on the garage floor. Going back tomorrow.
Old Jun 1, 2007 | 07:00 PM
glad to hear they replaced those internals! Did they ever fix the leak?
(haha, nothing like bringing back threads from the dead...)
theblinkof
Oct 4, 2023 05:24 PM
nowakm99
Oct 9, 2015 07:10 AM
Luke.s
Sep 30, 2015 05:57 PM
Zube6115
Sep 30, 2015 12:57 PM
juicemantwon
Sep 26, 2015 12:30 PM
