Use Mazda apex seals!!!
Old Oct 9, 2006 | 09:27 PM
rotarygod's Avatar
I have always been a believer that when rebuilding a rotary engine, you should only use Mazda apex seals. Of course if you can afford them, use the Ianetti Ceramics. They are only $1600 a set!!! Many 13B people use aftermarket seals such as Atkins, Hurley, Rotary Aviation, etc rather than Mazda seals due to price. Typically the difference is around $200 a set for aftermarkets vs around $400 a set for Mazda seals. I have heard good stories and bad stories for each seal. Some seals are so strong that you can't break them. Sounds good doesn't it? You'll just break something else in your engine which will still require a complete teardown and those extra hard seals are murder on your housings when they do work good. But they won't break! Why does that make sense to some people? We are at the point now where we are going to start seeing more and more aftermarket seals appear for the Renesis. It's only a matter of time. Someone always has the latest and greatest seal that can live through even the most careless tuning sessions. Do you really know how well your seals are made?
I've seen stock Mazda seals live on a 13B under 26 psi plus a 75 shot of nitrous to give 620 rwhp. That's tuning right there. I've seen stock seals blow up at 300 rwhp. That's bad tuning. What seems to be the issue? Is it the seal strength? Nope! I've seen aftermarket seals with both scenarios as well. Is it worth saving $200 over? Some people will contend that if it is going to blow up anyways, they may as well spend as little as possible. I contend that if you do everything properly you won't have to worry about it and a good seal will give you years of trouble free service. That is one thing I have yet to see in an aftermarket seal. No one seems to get that far. You can place blame wherever you want it but you need to be shown some actual proof that you should just trust Mazda when it comes to your seals. Here's why.
The first picture is a shot of 2 apex seals. Admittedly the one on the left is a 2mm seal and the one on the right is a 3mm seal. The one on the left is aftermarket and the one on the right is Mazda. See a quality difference? Which one is rougher? Which one do you want rubbing against your housings? It's not to say that all aftermarkets are this rough but all Mazda seals are this smooth. Do you think you should really risk it? These photos are courtesy of rotaryeng.net. I need to give credit where it is due.
http://www.rotaryeng.net/good1.JPG
Do you want to see a graphical representation of how important a smooth finish on an apex seal is?
http://www.rotaryeng.net/smooth.jpg
Here is a picture of an engine that had the above rough aftermarket seals. This engine ran for 3 hours on a dyno. The rotor housings were well within spec at the beginning of the test so no they weren't brand new. Either way, they aren't in spec now.
http://www.rotaryeng.net/Damaged-rotor-house.jpg
This is a housing that was in a well taken care of engine. It had over 150,000 miles of road use and then went into an airplane where it had about 165 hours of use. Keep in mind that the engine is usually at full throttle and at about 6000 rpm in an airplane. I personally rebuilt a 13B at 103,000 miles that looked practically new inside. I kept the original parts, ported it, and put it back together. Even the same seals. It is still in my RX-7 4 years after the rebuild.
http://www.rotaryeng.net/Perry-rotor-house.jpg
It's amazing what a little seal can do. Now, was the $200 savings worth it?
Old Oct 9, 2006 | 09:48 PM
great info thanks.
Old Oct 9, 2006 | 09:50 PM
Gomez's Avatar
Shifty Bastard.
No joy on pic two, RG. Pics one and two are the same.
Old Oct 9, 2006 | 09:54 PM
rotarygod's Avatar
I fixed that while you were posting.
Old Oct 9, 2006 | 10:03 PM
9291150's Avatar
Got to spend more time in this section...nice post RG!
Old Oct 9, 2006 | 10:23 PM
Gomez's Avatar
Shifty Bastard.
So I see.
That last pic is amazing. I have a 12B in bits in the garage that has done less miles than that.....the housings are shagged in comparison.
Old Oct 9, 2006 | 10:38 PM
rotarygod's Avatar
My own 13B blew me away when I opened it up at 103,000 miles. It looked like my 30,000 mile Turbo II engine. Both engines were very well taken care of. I have no doubt mine could easily go another 100,000 miles with room to spare if it is still well taken care of. Mine had zero signs of chrome flaking anywhere. Not even on the edges.
Old Oct 10, 2006 | 11:28 PM
8 Maniac's Avatar
Senior Member
great post... starting to think the tech garage might need a sticky of all RG's threads like this lol
Old Oct 10, 2006 | 11:48 PM
Gomez's Avatar
Shifty Bastard.
Don't go 'round thinkin' sucking up to the Mods is going to get you a long way, Tiger.....
Old Oct 11, 2006 | 09:13 AM
mikeschaefer's Avatar
I wanna rock! Rock!
I'm going to go out on a limb here..
Here's a list of things that I suppose will keep a stock engine in good condition:
1) change the oil often and keep the level up
2) keep the cooling system in good condition and change the coolant yearly
3) make use of the upper rev range regularly
and for modified engines:
1) make sure the air/fuel ratio and timing are set right to help prevent detonation
2) increase cooling capacity
Is it that simple or are there other, more specific things we should be looking at?
Old Oct 11, 2006 | 10:31 AM
Great post RG ! You
Hmm ..... those cermaic Apex seals are quite expensive .... Im sure they're good (better be good!) but thats like what 1/2 the price of the engine itself ? .....
Use good engine oil ? Synthetic.
Old Oct 11, 2006 | 11:12 AM
ZoomZoomH's Avatar
Mulligan User
don't underestimate high quality traditional oil w/ frequent change
Old Oct 11, 2006 | 11:23 AM
rotarygod's Avatar
Don't overestimate a good synthetic!
Old Oct 11, 2006 | 11:35 AM
Don't under estimate Mazda's Wrath !
Old Oct 11, 2006 | 11:51 PM
RX8PDX's Avatar
Didnt you mention somewhere else also, that mazda seals have a Diamond Like Finish in the Renesis?
Old Oct 12, 2006 | 12:33 AM
rotarygod's Avatar
The Renesis corner seals have a coating called DLC which stands for Diamond Like Carbon. It is extremely hard.
Old Jul 18, 2016 | 08:47 PM
xKp5609x's Avatar
MAJOR THREAD REVIVAL!!!
Glad i went OEM Seals, my builder who is used to 7s have no faith in them but with 2 new housings, the only option for me was to keep it OEM all the way!
How well have these builds held up over the years RG?
Old Jul 18, 2016 | 10:00 PM
atl8's Avatar
To be clear, you are listening to the advice of someone who...
A. never owned a RX-8
B. recommended the Hymee supercharger
kthxbye
Old Jul 19, 2016 | 12:14 AM
Brettus's Avatar
Boosted Kiwi
After many engines and many years following Rx8 issues my conclusion is :
OEM seals for NA and light boost (up to 10psi max.)
Aftermarket unbreakable for 10psi plus
Old Jul 19, 2016 | 12:33 AM
TX
kthxbye
Perfect
Oh and I concur on using OEM seals. But what seals you use doesn't mean **** if your builder sucks and uses other out of spec parts.
Old Jul 19, 2016 | 02:29 PM
mazdaverx7's Avatar
RX-Heaven
^^^ very well said! I am all for the oem seals as well fwiw.
Old Jul 28, 2016 | 11:45 PM
kthxbye
charlie?
Warrior777
Jun 24, 2019 04:47 PM
uZu
Dec 30, 2015 12:35 PM
Quiggs321
Sep 3, 2015 04:28 PM
shashumba
Aug 26, 2015 02:09 PM
Modern2Strokez
Aug 16, 2015 01:07 AM
