Fuel Injector upgrade!
Old Oct 9, 2006 | 10:34 AM
MazsportScott's Avatar
Mazsport.net
Mazsport is proud to offer high performance fuel injectors for the RX-8. We are offering 650cc and 720cc injectors that have been designed to be installed using the factory fuel rails eliminating the need to reconfigure fuel lines or connections. Our injectors include all required o-rings, grommets and connectors to help promote a clean, professional installation. For customers with the Interceptor-X E.M.S. mapping is available to allow you to install the upgraded injectors and drive away. Please checkout Mazsport.net for more information.
Old Oct 9, 2006 | 02:57 PM
mazsportmantis's Avatar
this is a great install for you turbo owners and applicable for NA owners as well....
Old Oct 9, 2006 | 03:28 PM
rotorocks's Avatar
RotoRocks Powered
Guys what would be the pros/cons of upgrading the injectors vs upgrading the entire fuel system?
Old Oct 10, 2006 | 09:52 AM
Mazsport.net
If you use our 650cc/720cc injector setup in conjunction with our pump kit your fuel system requirements will be complete for 400+rwhp. If you just upgrade the injectors you will at some point exceed the flow capacity of the stock pump.
Old Oct 10, 2006 | 10:21 AM
rotorocks's Avatar
RotoRocks Powered
What is the approximate HP at that point?
Stock fuel system is capable of 280-300 and in some cases even higher HP rates.
How high can it go with just the upgraded Injectors, if at all?
I am curious, because at some point I'll be upgrading my system, right now, I don't know what the turbo is going to be capable of, so I am just asking questions.
Old Oct 10, 2006 | 11:06 AM
zoom44's Avatar
my best guess is around 350whp
Old Oct 10, 2006 | 11:09 AM
Red Devil's Avatar
This is 650 primaries and 720 secondaries as the recommended setup?
Old Oct 10, 2006 | 02:09 PM
yes, that is correct....
if you are NA you can use just the primary injectors.....primary and seconary are recommended for turbo applications.....
Old Oct 10, 2006 | 02:23 PM
brillo's Avatar
Go Texas Longhorns!
would there be any advantages to upgrading the primaries if you are just NA? Do they have the same piezo hole count like the stock ones? Would the car still idle ok?
Old Oct 10, 2006 | 02:29 PM
shaunv74's Avatar
Power!!
^^ ditto?
Old Oct 10, 2006 | 10:31 PM
epitrochoid's Avatar
Riot Controller
300 is about max. you're pushing 100% duty cycle at that point.
my fuel system couldn't support 275 under it's operating conditions (high heat, prolonged heavy load) and I leaned out and detonated
Old Oct 10, 2006 | 10:36 PM
check pm..
OnebaddRx8
Aug 25, 2019 11:34 PM
FubarI33t
Sep 28, 2015 08:45 PM
drlubell
Sep 26, 2015 11:58 PM
Shumster
Sep 10, 2015 11:05 PM
