Won't even make a sound!!
Old Oct 8, 2006 | 11:28 AM
ebswest's Avatar
My 2004 RX8 won't start. When I turn the key, nothing happens. No noise, no clicking, nothing. The dash warning lights come on. Everything electrical is working, the headlights come on and are strong. I make sure I have the clutch pushed all the way down when I turn the key, but nothing happens. I have tried using both of the keys that came with the car. When I put the key in ignition and turn the key to on, the security key indicator light comes on for 3 seconds and then goes off as it is suppose to when the key is ok.
I have tried eveything I know of to get the car to start. For the heck-of-it, I tried jumping the car with cables, nothing.
The same exact thing happened a month ago. After turning the key several times, the car turned over and I immediately took the car to the dealer. They kept the car all day and could find nothing wrong.
Now, the same thing is happening and I am probably going to have to have the car towed back to the dealer.
Any ideas or suggestions??
EW
Old Oct 8, 2006 | 11:29 AM
lurch519's Avatar
www.evoperform.com
bad key cylinder?
Old Oct 8, 2006 | 11:41 AM
therm8's Avatar
Bummed, but bring on OU!
Immobilizer? Blown fuse? Dead starter? Hard to say.
Old Oct 8, 2006 | 11:52 AM
ebswest's Avatar
I checked the fuses and they are OK...
Old Oct 8, 2006 | 12:15 PM
Easy_E1's Avatar
is it a manual or an AT?
Sounds like,,,,
Manual, clutch depression safety switch malfunction. Wire came off? bad switch?
AT, shifter in gear? Neutral safety switch?
Old Oct 8, 2006 | 06:03 PM
ebswest's Avatar
It is manual transmission. Thanks for the suggestions.
Old Oct 9, 2006 | 11:57 AM
corners's Avatar
An RX ate my baby
Can you roll-start it with the key on?
Old Oct 9, 2006 | 12:11 PM
no dice's Avatar
I bomb atomically
Try starting a car that you are the owner of, that immobilizer is tricky :P
...kidding.
Take it to the dealer.
Old Oct 9, 2006 | 03:25 PM
ebswest's Avatar
I had it towed to the dealer this morning. They called a few minutes ago and told me the problem is with the clutch switch. Evidently, the switch is broken and the car can't tell that the clutch is pushed in. They have to order the part. Luckily, the car is still under warrenty and all is covered. Even the tow.
Skyl3r
Dec 2, 2019 04:51 PM
Dokuji
Nov 1, 2016 02:51 PM
dbarber
Jul 25, 2015 01:34 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
