DAC17
08-31-2003, 09:59 AM
Does anyone have the issue where the engine surges upon first starting in the morning? When I start mine (6-speed), I get a variable idle between 1K and 2.5K that seems to cycle almost like with the A/C on (but it's not)
Any ideas?
Thanks.
Rev It Up
08-31-2003, 10:15 AM
My car recenly started to do the same thing, but it only seems to do it as I back down my driveway and I have a fairly steep pitch, and it is only in the morning when it is first started.
RX8Lover
08-31-2003, 10:45 AM
i have that too, with my 6spd. its starts up and immediately goes to 2500 RPMs, and then slowly works its way back down to 1000. I have seen ither cars do this as well, and not sure it is anything to worry about.
rotary_it_up
08-31-2003, 10:59 AM
I've got the same behavior with my car. Nothing to worry about.
Aratinga
08-31-2003, 12:55 PM
Mine too. On the first (cold) start of the morning, the idle does search around. I'm betting it's perfectly normal.
By the time I back out of the garage, close the garage door, and start moving forward down the street (accompanied by the reassuring clunk of the ABS) all is well. ;)
BillK
08-31-2003, 10:45 PM
It's also definitely not new; the 1989 RX-7 GTU I drove for a while did the exact same thing...
I get a similar surge of idle, but from 1,000 to about 2,000 rpms. However when I put the clutch in the engine goes back to normal idle. It returns to the surge mode when I let the clutch back out...all is normal once the engine warms up to normal.
Anyone else experience this?
zoom44
02-03-2006, 08:38 PM
when you first start and it goes to 2-3k then slowly goes down - thats normal. surging from normal idle to 2-3k then back down then back up- abnormal. it could be an indication that the neutral sensing switch is stuck so that when you move the shifter to neutral the pcm/tcm doesnt know it and is confused.
zoom44
02-03-2006, 08:39 PM
also moving this to teh problems section
