canzoomer
Old Oct 2, 2006 | 08:48 AM
VRRX8's Avatar
canzoomer
sorry i didnt seach this, i just need help asap, im trying to hook up the canzoomer to my laptop, but when i try to run the program it says that it cant comunicate with the unit, now, does it hook up to the laptop just with the cable, or do i need the canscan for it to work, thanks for ur help
Old Oct 2, 2006 | 12:07 PM
VRRX8's Avatar
k, thats fixed now, but now i get a communication error, check the connection...i check the conections and everything is fine.......
Old Oct 2, 2006 | 11:38 PM
musclecarconvrt's Avatar
Do you have the right COM port selected?
Old Oct 3, 2006 | 10:41 AM
VRRX8's Avatar
now i dot, and now my usb cable is broken, i heard is not a normal usb cable, but u think i can find something that works at a computer store?
Old Oct 3, 2006 | 10:46 AM
I believe it is a Serial to USB cable. You will also need a Serial to USB converter driver for your laptop. Let me see if I can dig my old ones up and PM you. I'm at work now so it wouldn't be until this evening.
Old Oct 3, 2006 | 11:08 AM
VRRX8's Avatar
that is fine, thank you for your help
Old Oct 3, 2006 | 10:48 PM
I found the USB drivers for the Canzoomer software to talk to the box, but to get them to you I'll have to email you. It's several files of about 2 megs.
PM'ed you about it.
Old Oct 5, 2006 | 04:53 PM
Ok, for anyone else looking, Yes. The cable for the Canzoomer box is special. Greddy made the box so thatb it puts out a serial signal but gave it a USB port to make it harder for people to pirate their software. Canzoomer has the cable made special to convert the signal to USB inside the cable. Thats what the little circuit board in the end does. If yours is bad, you'll have to order another one from Canzoomer.
MichRX7
Mar 9, 2004 07:44 PM
93rdcurrent
Series I Engine Tuning Forum
Mar 1, 2004 01:16 PM
RX8Z
70
Feb 21, 2004 06:51 AM
RXhusker
Jan 16, 2004 06:10 PM
rotarygod
16
Dec 20, 2003 06:18 PM
