Rattles are driving me crazy!
Old Sep 30, 2006 | 08:42 AM
willsrx's Avatar
I love everything about my car except the fact that I have so many rattles that I don't like giving anyone a ride because its embarrasing. I have rattles in both front doors, from the radio area and from the tachometer/speedometer area.
My little brother laughs at me because he has a 06 civic si with more mileage and his car is rattle free. I have taken it to the dealer twice and all they say is that they could not recreate the problem even after I testdrove with the service advisor. I am considering finding them myself but I am afraid of doing more damage than good. Anyone have any suggestions?
Thanks in Advance.
Old Sep 30, 2006 | 10:37 AM
theres a rattle diy somewhere, you might want to look for it.
I have a friend who has a G35 and it still rattles like a ****, it all depends on your luck. Some people never got any rattle, it just depends.
and you can laugh about your brother's Civic that no one on earth gives a rat *** about it ever. Girls will turn their heads for Rx8, not Civics.
Old Sep 30, 2006 | 10:56 AM
SmokeyTheBalrog's Avatar
Thread Pirate, Ahhrrrrr
DIY Rattle Hunt
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-rattle-hunt-79235/
Old Sep 30, 2006 | 08:32 PM
CosmosMpower's Avatar
1935 lbs. FTW!
Get used to it, I have about 2-3 on going ones. The dealer already took my drivers door apart and filled it with foam to no avail. If you have a rattling coming from the drivers door it's probably the corner of the door rubbing on the side of your dash. I stuck my hand in the gap the other day and it went away. Now I just have to figure out how to rid it permanently.
Old Oct 1, 2006 | 02:46 AM
You probably could put some foam there. I would first tape it in place before using any kind of real adhesive.
If the rattles are really driving you nuts and you a technically inclined or you have a mechanic or body shop you trust print out the parts of the DIY that I linked too that talk about your rattles and follow it.
Old Oct 1, 2006 | 05:51 AM
RX8Maine's Avatar
Anyone else's driver's seat squeek when entering a corner?
Old Oct 2, 2006 | 09:22 PM
kazisdaman's Avatar
Just make sure whatever you use, doesn't really asorb water.
If its your door panels, and u are placing stuff inside the door panels behind the plastic, you will need to make sure you have water proof whatever, or else you'll get mositure stuck in your panels.
Although if its the inside, where nothing will get wet, then use foam, or stuff from a pillow, or anything. I insulated my other car with stuff from a couch. It was like cotton, but diddn't absorb water, and stoped all rattles.
Old Oct 7, 2006 | 08:50 PM
DaveCM203's Avatar
DaveCm
The stock seats suck. I am planning on replacing them with aftermarket. After a few miles of hard driving, they seem to wiggle around. They did replace the seat frame on mine and it seems ok after about 3,000 miles. But so did the original until I started getting over about 20,000 miles. I do not think that the seats were intended to cope with the cornering forces that the 8 is capable of on a regular basis. The seat frame alone is $900. Not worth it to replace it yourself. You can get two decent aftermarkets for around that.
Old Oct 8, 2006 | 09:44 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
For only 13K miles on my car, it sure does have a symphony of rattles at different speeds and surfaces. I think the quality of the materials is good, but perhaps they didn't put them together that well or something. I'd hate to see what the car would be like with an even stiffer suspension knocking things apart.
Skyl3r
Dec 2, 2019 04:51 PM
extreme_rotary
Jan 22, 2019 11:53 AM
tgaffner
Aug 20, 2015 10:55 AM
MolsonB
Aug 18, 2015 08:42 PM
rx8wankelrotary
Aug 17, 2015 10:42 AM
