DIY: Radar Detector Mount Bracket
Old Aug 5, 2006 | 10:27 AM
j330i's Avatar
I have a Passport 8500 Radar Detector and didn't like the suction cup mounting option that came with the detector and didn't want to place it on the dash either. I wanted something that was NOT permanent, somewhat hid the detector and power cord as well as being fast and easy to remove. After looking around the interior for a good way to mount the detector I decided to use a simple bracket that attaches under the plastic clip that holds the visor (closest to the rear view mirror). This plastic clip easily pops out if you insert 2 flat head screw drivers on each side to move the plastic clips that hold it in place out of the way. I had a friend of mine who has access to a metal shop to make the bracket. The bracket needs to be thin (mine is a little thicker than the metal suction cup mounting bracket that came with the detector) but still strong. I have a direct wire cord on order that I will run behind the A-piller molding to hide the cord. This detector is 3 years old and the plastic portion of the housing that holds the upper and lower pieces together have broke and that's why I have electrical tape holding them together. I've had it in place for about two weeks now and think it works great. I assume something like this could be use for other radar detectors too. Check out the pictures.
Attached Thumbnails DIY: Radar Detector Mount Bracket-dsc00519.jpg   DIY: Radar Detector Mount Bracket-dsc00520.jpg   DIY: Radar Detector Mount Bracket-dsc00521.jpg   DIY: Radar Detector Mount Bracket-dsc00515.jpg   DIY: Radar Detector Mount Bracket-dsc00517.jpg
Old Aug 5, 2006 | 10:30 AM
j330i's Avatar
More Pictures
More Pictures ...
Attached Thumbnails DIY: Radar Detector Mount Bracket-dsc00518.jpg   DIY: Radar Detector Mount Bracket-dsc00524.jpg   DIY: Radar Detector Mount Bracket-dsc00527.jpg
Old Jan 22, 2008 | 02:42 PM
goofydragon's Avatar
This is pretty sweet. Any chance of being able to make another bracket and selling it to me?
05rx8mazda
Nov 28, 2015 09:42 AM
ShellDude
Oct 1, 2015 09:55 PM
pjwermuth
Sep 28, 2015 11:36 PM
