DIY: cup holder insulation
Old Jun 26, 2005 | 06:55 PM
PUR NRG's Avatar
I just finished the install and it will be a couple weeks before I can say whether this actually works or not. I removed the stock insulation and replaced it with a heat barrier from ThermoTec. http://www.hi-impact.org/ryang/modif...8_console.html has the full write-up if you want to try doing it yourself.
You can also see a complete list of DIYs I have at http://www.hi-impact.org/ryang/modify/modify.html
________
Love Quotes Forum
Attached Thumbnails DIY: cup holder insulation-rx8_console_8.jpg
Old Jun 26, 2005 | 08:25 PM
Student Driver
Cool.... I mean Kool...I'll have to try this one!
PS: Linky no workie...
Old Jun 27, 2005 | 09:56 AM
PUR NRG's Avatar
The entire site is down for an unknown reason. I'll check into that this evening. Thanks.
________
Vapor Info
Old Jun 27, 2005 | 07:15 PM
PUR NRG's Avatar
Okay, site is back up. Enjoy.
________
Vaporizer Wiki
Old Jul 1, 2005 | 10:03 PM
You went all out with that.
How do you keep you coffee warm?
Old Jul 2, 2005 | 12:48 AM
PUR NRG's Avatar
What makes you think I drink hot coffee?
________
Ford rheinland picture
Old Jul 26, 2005 | 01:48 PM
RedLineShinka's Avatar
OK, it's been a while... DOES IT WORK? I'm thinking about pulling my center cup holders apart and doing this.
Thanks!!
Old Nov 5, 2005 | 01:24 AM
iRX-8's Avatar
Any word on how well this mod works? I know it's been a few months since the last post on this thread but I'm curious...
Old Dec 10, 2005 | 03:18 PM
LiL BenNy's Avatar
Bubblicious? DEF.
um is this neccesary? cuz mine cup holders are warm as hell from the tranny?.. i leave my phone in the cup holder and when i get out its really warm...
Old Dec 10, 2005 | 04:13 PM
Gray-8's Avatar
The insulation is to deflect heat from the cup holders, not keep them warm.
Old Dec 11, 2005 | 01:57 AM
LiL BenNy's Avatar
Bubblicious? DEF.
ohh the whole time i though it was to actually keep drinks warm when you turn on a button? lol...
Old Dec 12, 2005 | 01:16 PM
poker's Avatar
On sort of an off-topic thing:
Has anyone found a cup holder liner that fits into the RX8 cup holders? Mine get dirty on the bottom often and I wish I could just pull em out and rinse instead of digging the dirt out.
Old Dec 13, 2005 | 03:49 PM
poker's Avatar
Haven't found such a thing. I'd suggest a napkin or paper towel in the bottom.
...or you could do what I do: don't drink in your RX-8.
Ha I wish! I pretty much live in my RX8 and I have a severe coke (a-cola) problem. I've tried the napkin before but it just looks messy and unkempt to me. Guess I'll keep searching....
Thanks for the response, though!
Old Aug 10, 2006 | 05:57 PM
kevsRX8's Avatar
We never did hear if this works. The site is down also. Any word PUR NRG
Old Aug 16, 2006 | 03:47 PM
jus7o's Avatar
good DYI ill have to try it some time after i do the A/C hose heat wrap DYI
good job let us know how well it works!!
Old Aug 16, 2006 | 04:10 PM
ritchjp's Avatar
I did the insulation a few weeks ago. I can notice a difference. I haven't taken any temp readings with a thermometer or anything but the ice in my drink doesn't melt as fast and I don't feel any major heat radiating into the cabin
Old Aug 26, 2006 | 04:15 PM
El Kabong's Avatar
Off topic, I know, but would using Thermo-tec or similar material to insulate the cold air intake box help keep air temps down?
Seems like an easy mod.
-Kabong
Old Aug 30, 2006 | 10:34 PM
elf's Avatar
elf
What pointy ears?
Did the cup-holder insulation last week ... with mixed results. It certainly delays the cup-holder compartment from getting hot, but eventually it does. I think the best solution would be to prevent radiant heat from getting to the bottom of the center console in the first place. I don't know how much space is available between the tranmission housing and the bottom of the console (to install the heat barrier there) --- I'll check the next time I'm underneath the car.
Old Aug 31, 2006 | 10:12 AM
Shifty Devil's Avatar
I've seen some single-cup/can pelteir coolers I'd like to try and mount in there to actively cool the drinks.
Old Nov 16, 2007 | 10:44 AM
mannerofspeakin's Avatar
Originally Posted by elf
Did the cup-holder insulation last week ... with mixed results. It certainly delays the cup-holder compartment from getting hot, but eventually it does. I think the best solution would be to prevent radiant heat from getting to the bottom of the center console in the first place. I don't know how much space is available between the transmission housing and the bottom of the console (to install the heat barrier there) --- I'll check the next time I'm underneath the car.
Any feedback on the underside possibility ? I always believed it easier to install reflective heat barrier between underside of vehicle between it and the transmission housing. Have not heard anyone indicate it was physically (and reasonably) possible although from my brief look under the vehicle it would appear it can work in that way.
Old Sep 7, 2008 | 02:46 PM
Blackout04RX's Avatar
Need for Speed Satisfied
it has been a long time since anyone posted on this, but I definately like this idea. I think the heat in the cup holders is killing the battery in my Ipod. And if not, it still is mad hot. Useful if you are drinking coffee or hot chocolate, but otherwise a major pain in the ***. Any word on how to help this short of thermal taping the body above and around the cat?
Old Sep 19, 2010 | 12:14 AM
aaiceman's Avatar
I just did this, sorta. I don't know how much of a difference it will make, but anything has to be better. The default insulation was so inadequate that it was charred in place. I pulled out the center console and wrapped the front cup holders in a cut out from the sunshade and secured it with the tape. I also did a flat cut out that I placed under the front storage compartment and secured that with tape as well. Make sure to not leave any holes. It needs to be a solid shield.
Supplies:
1x Aluminum Tape
1x Cheap ($6) Sunshade (Similiar to http://www.bestautobits.com/images/Silver_Sun_Shade.jpg)
Old Oct 12, 2010 | 03:56 AM
Maui's Avatar
Wow, I'm glad to hear this is normal. I was really freaking out when I found out how hot the cup holders get. I could really feel the heat radiating from them.
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
vapor2
Jul 9, 2016 07:35 AM
Sep 6, 2015 01:04 PM
IB Cristina
West RX-8 Forum
Aug 20, 2015 08:52 PM
