DIY: Trunk Keyhole Camera Installed
Old May 26, 2005 | 12:45 AM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Even though most people said our key hole was too small for a camera, I thought I'd try it anyway. So, I bought the $50 ebay special and gave it a shot.
Attached Thumbnails DIY: Trunk Keyhole Camera Installed-img_0741.jpg   DIY: Trunk Keyhole Camera Installed-img_0737.jpg   DIY: Trunk Keyhole Camera Installed-img_0739.jpg   DIY: Trunk Keyhole Camera Installed-img_0742.jpg   DIY: Trunk Keyhole Camera Installed-img_0743.jpg
Old May 26, 2005 | 12:48 AM
I had to do a lot of grinding to make the camera fit. I did not have to do any cutting on the car.
I had to make a bracket to hold the camera in the key hole and keep it nice and tight.
Attached Thumbnails DIY: Trunk Keyhole Camera Installed-img_0744.jpg   DIY: Trunk Keyhole Camera Installed-img_0745.jpg   DIY: Trunk Keyhole Camera Installed-img_0746.jpg   DIY: Trunk Keyhole Camera Installed-img_0747.jpg   DIY: Trunk Keyhole Camera Installed-img_0748.jpg
Old May 26, 2005 | 12:49 AM
Some pictures of it after I installed it.
Attached Thumbnails DIY: Trunk Keyhole Camera Installed-img_0750.jpg   DIY: Trunk Keyhole Camera Installed-img_0751.jpg   DIY: Trunk Keyhole Camera Installed-img_0752.jpg   DIY: Trunk Keyhole Camera Installed-img_0762.jpg   DIY: Trunk Keyhole Camera Installed-img_0765.jpg
Old May 26, 2005 | 12:51 AM
Pictures of the wires tapped into the reverse light.
Attached Thumbnails DIY: Trunk Keyhole Camera Installed-img_0754.jpg   DIY: Trunk Keyhole Camera Installed-img_0755.jpg   DIY: Trunk Keyhole Camera Installed-img_0756.jpg
Old May 26, 2005 | 12:53 AM
Here are some pictures of the image at night. The day time picture is 1000 times better, but I forgot to take pictures of it. I will tomorrow .
Attached Thumbnails DIY: Trunk Keyhole Camera Installed-img_0757.jpg   DIY: Trunk Keyhole Camera Installed-img_0758.jpg   DIY: Trunk Keyhole Camera Installed-img_0760.jpg   DIY: Trunk Keyhole Camera Installed-img_0759.jpg   DIY: Trunk Keyhole Camera Installed-img_0761.jpg
Old May 26, 2005 | 12:54 AM
Mobile-Effects.com's Avatar
Oh hell yeah. that's what I'm talking about!
How do you get into the car without a key? do they have hatch pop buttons for RX8s?
Old May 26, 2005 | 12:59 AM
Yes they do, I don't think i've ever used the key to open the trunk.
Old May 26, 2005 | 01:01 AM
The camera comes on and switches the display when the car is put into reverse, then goes back to my computer after the car is taken out of reverse.
Old May 26, 2005 | 01:09 AM
Lock & Load's Avatar
Nice touch is it infrared ??
cheers
michael
Old May 26, 2005 | 01:32 AM
cheers
michael
nope,
no room for IR.
Brighter reverse bulbs will have to do.
Old May 26, 2005 | 02:17 AM
StealthTL's Avatar
Camera....
Great write-up!
Moved thread to the DIY forum, for future reference.
S
Old May 26, 2005 | 02:25 AM
truemagellen's Avatar
Attracts tree branches
shoot beat me to this DIY RR :P can you change the title to 'backup keyhole camera installed'?
mine has a different mounting position...yours is sweet mine requires no fabrication or cuting of camera or car or anything for that matter
I'll still post it after I get from out of the country
Old May 26, 2005 | 02:36 AM
You'll have to get a mod to rename the thread. I tried but it only renamed my post.
Old May 26, 2005 | 02:38 AM
hey no problem...when I upload the DIY then if need to change it still exists I can ask...thanks RR and again great job
Old May 26, 2005 | 05:53 AM
LiL BenNy's Avatar
Bubblicious? DEF.
[QUOTE]
THAT IS NUTS. do you think it will work with the NAV?
Old May 26, 2005 | 08:27 AM
[QUOTE=LiL BenNy]
I know for a fact it does :D
I promise I'll finish the DIY Backup Cam for NAV :D
Old May 26, 2005 | 08:38 AM
If you have the AVElectronics unit it will auto switch for you.
Old May 26, 2005 | 09:12 AM
foxman's Avatar
Torque is Good
Nice project, looks really cool. I always wondered about car cam on the NAV. Sounds like a great project. Where is flyboyindy, he needs this too! :D
Old May 26, 2005 | 09:20 AM
khtm's Avatar
I like rusty spoons
Hey Rotary, you should sell these kits (pre-grinded) with the bracket and instructions...I think you'd make a killing.
Old May 26, 2005 | 09:52 AM
flyboy already installed his a couple months ago :D
he decided to install it in the middle of the rear rotary accent, I chose right license plate post
Old May 26, 2005 | 09:56 AM
The one thing I like about this mounting place, it cannot be seen. Even if you're looking for it, you pass right over it because you think its the trunk key. I took some day pictures this morning, they look real good. I'll post them later.
khtm- The bracket is pretty simple to make. The only problem is for nav people you'd need to either buy the AVElectronics kit ($500) or replace the screen with this Xenarc and install a RBG to VGA converter (about $400 for both). The second choice would be the better way to do it because you'd have a better screen and the option of rca/vga input. But, for that reason alone, I doubt very many people will want to fork over the money for a back up cam. I already had the screen for my computer, so it was only another 50 bucks for the camera.
Old May 26, 2005 | 10:05 AM
foxman's Avatar
Torque is Good
You know what, I forgot about that...a good project would be in car video, recorded to the X-BOX, that could be played back on the NAV, that would keep him busy for a while.
Old May 26, 2005 | 10:12 AM
hmmm I believe that is doable...but need a camera that does the recording to a hard disc and is also attached to the xbox as an 'external drive' then have media center play it from the 'drive' or copy it an internal partition
flyboy is kind of giving up on his xbox...but I'll stop that since I cured our powersupply issue (I'm inverter free :D :D :D)
Old May 26, 2005 | 10:25 AM
khtm's Avatar
I like rusty spoons
Ahhh...very good point. I guess it's a bit more involved that I thought
Old May 26, 2005 | 11:34 AM
Nemesis8's Avatar
Bigus Rotus
Awesome! I gotta get this project started soon....
I wonder if USB cameras would work if you had the carputer setup for them?
