{WTB} Random parts
Old Feb 16, 2023 | 09:17 PM
jmauld's Avatar
NC Random parts
Location (US State/Canada/Int): NC
Recently picked up an RX-8, that I intend to race in the local autocrosses. I'm not a stock kind of guy so I'll be slowly prepping it for DSP (locally, not a nationally prepped car)
Looking for the following parts in good condition:
- AEM Intake (not looking to make power with this, just want to remove some weight and clear out room in the engine bay)
- Stock low-mileage shifter. (mine has 100K miles and is worn out, I have an aftermarket one, but it puts a lot of noise into the cabin)
- lightweight aftermarket wheels 17 or 18 x 9 or 10
- Wilwood front brake calipers
- Ground Control type sleeves to fit over Koni Double adjustable shocks
- non-cracked passenger side dash
Old Feb 16, 2023 | 10:46 PM
Loki's Avatar
Please don't do the coil sleeve thing. No good manufacturer makes a set for the 8 (or at all?) and you don't want what other manufacturers make. Get a proper suspension or keep it stock, you'll go faster.
I have an original shifter (without the ****) I could let go, but the noise issue could just be missing padding in the shift boot?
Old Feb 16, 2023 | 11:34 PM
jmauld's Avatar
ground control never made a sleeve kit? I’ve always had good luck using their sleeves on custom valved bilsteins for my previous cars. This car came with koni DAs, I would hate to ditch these, they seem pretty good.
I’ve swapped the stock sloppy shifter back and forth with the aftermarket shifter that came with the car, and the noise follows the aftermarket shifter. How much are you asking for your stock shifter?
Old Feb 16, 2023 | 11:52 PM
Loki's Avatar
Ground Control skipped the RX8 and NC Miata for some reason.
Which Konis are they? If it's the basic adjustable Yellows, they're fine but without a matched spring you're not going to get great results. You could do Eibach springs, they used to come as a combo. But all this is still OEM+ territory not race material.
Shifter - I dunno 40+ shipping? Where are you?
Old Feb 16, 2023 | 11:53 PM
jmauld's Avatar
they are the double adjustable Konis. Rebound on the top adjustment and compression on the bottom adjustment. These would’ve been more valuable when the car was competitive in stock class.
I’m in NC, zip code 28428. Check shipping please.
Old Feb 17, 2023 | 09:49 AM
they'd be better suited for STX than DSP, but if you can find sleeves that fit then it should be fine given the known limitations.
Old Feb 17, 2023 | 10:39 AM
So I verified that Koni was offering sleeved kits with 42mm ID and 50mm ID for their shocks out of the Koni Motorsport catalog I have from 2017. It would likely be best to call Koni NA in Kentucky and ask them about it and if they still offer them. The go-to guy there used to be Lee Grimes, but I think he was promoted into upper management. You could still ask though.
edit: it's online now it seems
https://www.koni-na.com/en-US/NorthA...ries/RR_Parts/
Old Feb 17, 2023 | 12:26 PM
jmauld's Avatar
Are you thinking the Koni's can't handle the higher forces? (Admittedly, I'm more of a monotube fan, but wanted to use these since they are on the car already)
Old Feb 18, 2023 | 11:52 AM
jmauld's Avatar
do you happen to know the shaft diameter for the top caps?
Old Feb 18, 2023 | 12:54 PM
12mm is what I recall, but not 100% sure. There may be enough sticking out from the top on the front shocks to measure.
it just depends on what spring rates you run.
ps: threaded sleeve comments vs Koni offering them for sale directly 🤔
RX8onside
Jun 9, 2015 08:06 AM
leep133
9
Oct 3, 2011 06:03 AM
chickenwafer
Feb 27, 2010 04:06 PM
padilla08
Jul 2, 2009 12:35 PM
kwescott
Sep 3, 2008 12:16 PM
