{WTB} Racing beat headers
Old Apr 2, 2022 | 10:59 AM
Fiftyfifty's Avatar
Racing beat headers
Have the engine out. Would love to overnight some racing beat headers before it goes back in within the next few weeks. Thanks
Old Apr 28, 2022 | 10:06 AM
Fiftyfifty's Avatar
Bump
Old Apr 28, 2022 | 11:42 AM
it’s actually a blessing to keep you from wasting your money.
Old Apr 28, 2022 | 12:28 PM
Fiftyfifty's Avatar
Haha you're hilarious sir. Always fun reading your old posts. I mean I did hear you can bang out at least 4whp and a nicer sound no? I got the motor out now so thought it couldn't hurt. No? Cause I for sure won't do it later when it goes back in.
Old Apr 28, 2022 | 02:28 PM
MincVinyl's Avatar
CEO of Morons Inc.
Team does have a good thread on header theory, a quick sum up is that since the renesis has no overlap, there is no point to separate header tubes. Which could also be seen by early attempts at making long tube and short tube headers and seeing no performance jumps. I'm fairly certain the stock log is really the best you can get OTS, unless you want to fabricate a larger log collector.
In terms of the rest of the racing beat exhaust, while it is heavier and necks down to 2.5in flanges, its sound and no drone is well worth it for street applications. Any actual power gains are probably offset by the weight in the end.
I did talk with the guys at racingbeat and asked them if they would be willing to manufacture their exhaust with 3in flanges instead. They said they could, however due to demand and shortages they do not have the time to change around their jig.
Old Apr 29, 2022 | 08:04 AM
Fiftyfifty's Avatar
Gotcha.. well according to this message from them to me not too long ago, it seems they aren't the ones making it
Old Apr 29, 2022 | 02:32 PM
MincVinyl's Avatar
CEO of Morons Inc.
Well that is just the flange that changes the exhaust ports to the header tube size, I would assume they weld up the tubes themselves in a jig.
Old May 1, 2022 | 06:58 PM
well again, you can get that out of the OEM manifold by cutting it off just past the last engine port pipe and going to 3” from there all the way out the back. Let me tell you if for some reason the RB header needs to come off it’s a big pain with the engine in the car. Not impossible, but aggravating. Sounds like you may recognize that already, but posting it for other people who don’t.
Old May 1, 2022 | 07:12 PM
0913B's Avatar
Rb headers
Yea when I installed the rb headers I had to lift and lower the engine slightly with a jack to be able to shimmy it in there, ID assume it would be the same to get it out
Old Jun 23, 2022 | 05:35 PM
slipshoddon's Avatar
Me Too
I would like one of the Racing Beat Headers too
Old Jun 23, 2022 | 05:50 PM
you will be better served modifying the OE manifold instead with a full 3” exhaust system.
Old Jun 24, 2022 | 07:59 PM
BigCajun's Avatar
It's been a while since I've been under my 8.
What's involved with that?
Old Jun 24, 2022 | 08:45 PM
cutting the OE exhaust manifold off just past the last exhaust port and enlarging it to 3” OD tube all the way out the back. I don’t think there’s any catback exhaust with 3” tube size though, but just dropping it back to the likely 2.5” tube size using a reducer right where it splits off to each muffler is not going to result in much restriction.
It is pretty much a custom job though going from the manifold to there. The usual 3” tube catpipe such as the BHR etc. can be used though by just cutting the reduced end sizes off of it. So then it’s custom from the rear manifold cut to the front catpipe cut and then also from the rear cat pipe cut to the muffler split flange. That would also necessitate a 3” tube size cat converter for emissions legality where required.
the header is just throwing cash into a hole in the ground with some gasoline and setting it on fire; being both undersized and all around useless.
Old Jun 26, 2022 | 10:53 PM
ritual's Avatar
Thanks for the header info
L.Morrison
Sep 3, 2022 04:13 PM
Clown man
Dec 8, 2007 03:33 PM
youpey
10
Jan 2, 2006 10:05 AM
toca
188
Dec 27, 2005 04:05 PM
Im_DANomite
49
Sep 6, 2005 04:58 PM
