{ FS } Lightweight flywheel with counterweight (resurfaced ready to use)
Old Feb 3, 2021 | 08:56 AM
rotoryfan1991's Avatar
I have a lightweight flywheel here I won't be using, just had it resurfaced. Ready to drop in. Comes with an exedy counterweight needed for the install.
$195 for the full setup.
Located in Ky.
Old Feb 10, 2021 | 01:03 PM
axiomatik's Avatar
Hi, I'm interested. What brand is the flywheel? Also, is the counterweight Exedy or Mazda? Are the teeth all still in good shape? It looks like the face of the teeth have been resurfaced as well.
Thanks.
Old Mar 12, 2021 | 03:26 PM
RotaryResurrection's Avatar
kevin@rotaryresurrection
These are 2 step flywheels, and the relationship between the 2 has to be maintained for proper clamping force, so both surfaces get cut even though only one is a friction surface. Sometimes to get the raised friction resurfaced well and remove all defects, the lower step also has to be cut a lot, and it goes into the teeth slightly. It has no impact whatsoever and I've run them this way (both stock and aftermarket) with no issue.
Espo
Aug 14, 2011 02:13 AM
Rx8_rotory_Noobie
May 5, 2010 02:23 PM
limpy81
Jan 16, 2006 05:36 PM
EZZY
Australia/New Zealand Forum
Jun 8, 2005 05:24 AM
Sociopath
Dec 2, 2004 11:04 AM
