{ FS } random motor parts for sale
Price: $2
Most parts are from a 2005 motor with 60k miles some others are from a 2007 motor
Pm me for pictures or txt, 772-828-1490
front stationary gear -75.00
rear stationary gear - 100.00
(i would install new bearings if purchased, but that's your OWN decision)
OEM toe control arms rears - 75.00 (2007)
OEM camber arms rear - 75.00 (2007)
OEM knock sensor - 45.00
OEM oil pressure regulator - 25.00
OEM struts Front - 65.00
OEM coils/springs Front - 30.00
OEM coils/springs Rear - 30
lower intake manifold - 75.00 (VDI and SSV are not included)
OEM (red) secondary injectors- 25.00
OEM oil metering lines -100.00 (60k, from 2005)
OEM oil injectors - 35.00 each (60k, from 2005)
OEM oil metering pump -75.00 (no sensor hooked up to it) just the unit
OEM shifter -25.00 (no ****)
OEM temp.sensor engine coolant (b593-18-840A) (30.00 shipped) NEW!
OEM rim center cap (NEW still in bag) 10.00
VFAD solenoid and vacuum chamber -40.00 (i have 2)
VFAD actuator and intake part -40.00 shipped (i have 2)
OEM water pump 50.00 shipped (60,000 miles from 05)
OEM thermostat housing neck - 25.00
OEM primary fuel rail -30.00
OEM secondary fuel rail- 15.00
VDI actuator -60.00
OEM flywheel- 50.00 (pm for shipping quote)
OEM oil pan used but good condition - 70.00 Sold
New rotor housing - Sold
APV motor - Sold
air pump- Sold
SSV acuator - sold
SSV solenoid valve -Sold
SSV solenoid valve= Sold
VDI solenoid valve -Sold
OEM primary injectors yellow - Sold
upper intake manifold -Sold
OEM struts Rear - 75.00 shipped Sold
oil filter neck- Sold
OEM throttle body - Sold
OEM front rotor housing - Sold
Race roots oil relocation - Sold
Car pc computer - Sold
OEM front iron- (not usable needs to be refinished) give me a price
OEM middle iron- (not usable need to be refinished) give me a price
OEM rear iron- (could use some extreme lapping)
OEM rear rotor housing - not usable give me price
added parts, any offers will be considered.
Thanks,
Mark
Would you mind sending me a picture of the scored-up rotor housing? polaris09@sbcglobal.net Thank you
