FS: Beefy Rear Sway bar end links
Old Jun 17, 2009 | 12:19 AM
Lebren's Avatar
RX8club group buy vendor
Adjustable Rear Swaybar Endlinks, bolt right in (15 minutes or less) I did mine without even lifting the car and it's tucked in the back. Quiet so far, weather resistant, noticeable difference in feel! Ive got a few more of these made I need to sell, price is $55 Shipped in North America. Paypal lebren@gmail.com OEM's are $43+ each plus tax! Fronts also available.
PICS
BTW, Check out my LED Dipstick Lights in the GB or click the link below!
Old Jun 17, 2009 | 08:01 PM
magikone69's Avatar
im interested in a set but id like more info, i tried searching but i found no information on these links. How long have you had them on your car,
anyone else have these who can vouche for them
im interested in a great product?
Old Jun 17, 2009 | 08:56 PM
JinDesu's Avatar
went back to srsly broke
Are these to stiffen the connection from the stock (or any aftermarket) sway bar to the body?
Old Jun 17, 2009 | 09:20 PM
Look solid what type of mounts are those?
Old Jun 17, 2009 | 09:34 PM
Lebren's Avatar
Each pair of these end links are crafted by myself and a set has withstood much abuse on my RX-8 SE3P with great results! The idea is to have the strongest link possible for the lowest cost and I can deliver both.
If you're looking for a weather resistant and very strong solution to the stock end links then look no further.
$55 (pair) Payment is via Paypal, lebren@gmail.com
Old Jun 17, 2009 | 09:41 PM
JinDesu's Avatar
I'm interested, just short of money this month. Will these end links work with other sways?
Old Jun 17, 2009 | 09:49 PM
Tomorrow is Pay Day!! Yippy!
Old Jun 17, 2009 | 09:59 PM
Lebren's Avatar
I am 99% aftermarket sways will work with these in that they are typically beefier versions of the stock sway. Racing Beat and Agency power are very promising!
Old Jun 18, 2009 | 02:13 AM
what is the length end to end?
looks like it would be fine for the front, but for the rear of a car that is dropped. not so much..
Old Jun 18, 2009 | 09:52 AM
shadycrew31's Avatar
WENTGERMAN
Correct me if I'm wrong but the bolts in the middle of the Endlink look adjustable so the drop of the car should not matter.
Pm'D for questions.
Old Jun 18, 2009 | 07:27 PM
magikone69's Avatar
also want to know if these are short enough to fit sways on a dropped car, i am about an inch and a half shorter and i have aftermarket sways...please let me know...can pay tonight
any chance u have a pic of the endlink side by side with a stock link to show true length?
still very interested
Old Jun 18, 2009 | 10:03 PM
Lebren's Avatar
I have measured and attached pics of the comparison but keep in mind I had done some stress testing on the stock sway bar end link so it is bent. My end links are a gnat's *** over 3.25" center to center when fully tightened which I feel is perfect for my car (very close to 25" from bottom of tire to fender all around.)
I understand concerns that lowering the car should require shorter end links but I can swear that these being nearly one fourth of an inch shorter than stock they feel fantastic! I must mention the nuts used are a quarter inch each, the first set I made in the first pictures had thicker nuts making them greater in length. Thanks guys and gals!
Old Jun 19, 2009 | 12:00 AM
magikone69's Avatar
kool, im down for a set, the fact that you responded so quickly with pics makes me feel confident, paypal sent, cant wait to put them on.
Old Jun 19, 2009 | 05:39 PM
Lebren's Avatar
Some of you would probably like to see the fronts so I will deliver! These are only $50.00 (pair) First 4 to Paypal will get a set:
Old Jun 21, 2009 | 01:07 AM
ok,
i am really confused.
you are making adjustable endlinks that are not short enough for cars that are lowered?
if the car is at the stock height the stock endlinks are fine.. and if you bent them the bars were installed wrong..
so if you dont offer adjustable endlinks for the rear. i dont understand on why you are targeting the rx8 market?
Old Jun 21, 2009 | 12:51 PM
Lebren's Avatar
Wow swoope please lets keep this thread nice ok?
For JDRX805, these turned out to be in my opinion ideal length, this is with an aggressive spring setup that drops the car to exactly 26" all around from ground to fender. My car is a different story, an example, Ive been told "That's the lowest RX8 I've ever seen" by someone that sees RX8's every day. With that in mind, I would be the first to admit something with such an aggressive stance MAY need more adjustability.
You must have some frustration, but also knowledge you're possibly willing to share? In your opinion, what is the MINIMUM length Center to Center from the endlinks that you'd like to see? Let me know and I'll make it happen.
Thanks,
LEBREN
Old Jun 23, 2009 | 07:30 PM
Lebren's Avatar
Still have more sets for sale, BUMP!
note, with the car fully on the ground there is NO preload, and they are even with one another.
Old Jun 23, 2009 | 09:30 PM
TX
Thanks for the tracking info!!! Can't wait!
Old Jun 23, 2009 | 10:37 PM
Lebren's Avatar
Yours will arrive probably the earliest!
THANKS!
Old Jun 23, 2009 | 10:40 PM
Woot!! Woot!!
Old Jun 25, 2009 | 12:35 AM
Thanks,
LEBREN
was not my intent to be mean. i was just asking a question and making people aware to the problems.
as to what length i would recommend, well there is a great diagram floating around here right now.. it shows a drawing of how the sway ends should stay parallel to the ground when the car has been lowered..
it does not look like your photos..
btw, my fender height is at 25.5 all around. and my car is not that low..
have been offline for a couple of days. if i need to dig it up, let me know.
Old Jun 25, 2009 | 01:06 AM
Lebren's Avatar
Thanks swoope,
I appreciate your input because it helps me make better products for everyone (at a great price too) It seems the most critical aspects of the sway bar end links are parallelism, they must both be equal unless weight balancing for a track ie that has many right hand turns and the need to enhance the response to that side is needed. This of course will sacrifice response to the other side. It's a give and take.
The same source mentions for a daily driver there is no need to adjust length if lowering less than 1.5 inches. This was of course form a Neon forum and the dynamics may be different with FWD.
I have concluded that I will modify per request, one of the end link Rod Ends up to 1/3 inch to allow more flexibility for track tuning. I was also considering effects of removing one of the nuts and adding Loctite to one Rod End will remove up to an additional 1/4 inch... shortening up to 35/64 (over 1/2 inch.) These modifications will make center to center closer to 2.75 inches, offering more flexibility to lowered vehicles that see track use.
Thanks,
LEBREN
Old Jun 25, 2009 | 09:50 PM
magikone69's Avatar
got them today, initial quality seems great...cant wait to put them on
Old Jun 25, 2009 | 10:04 PM
TX
Me too!!!
Old Jun 25, 2009 | 10:05 PM
Spinning Sushi's Avatar
I <3 Sushi
Dude... this is not because the OEM endlink was weak, it was because when you lowered your car, you installed them backwards.
