Tanabe Racing Springs! Coilovers! Exhausts! Stabilizers!
Old Mar 11, 2009 | 10:52 PM
Race Roots's Avatar
Former Sponsor
Arrow Tanabe Racing Springs! Coilovers! Exhausts! Stabilizers!
Best of all it is Free shipping!!!
Sustec Pro FIVE [/B] MSRP: $1,550
Race Roots Price : $1,495
Sustec Pro FIVE
is an all new adjustable coilover suspension that features a wide array of all new circuit developed technology that is similar to Tanabe's Sustec Pro SEVENS.
Sustec Pro FIVE delivers broad performance for the track to the streets. Featuring 12-way(16-way with TEAS) front & rear adjustment, FIVE allows drivers to fine tune height, dampening and rebound based on street conditions and driver preference.
The new slide valve technology allows a great range of adjust ability and function for street and track use.
Spring Rate F/R: 8.0/6.0
When used with the new TEAS electronic active suspension controller, the wide range of dampening force is accessible through the touch of a button, and is fully programmable to automatically adjust dampening rates according to the speed you drive.
TEAS MSRP: $648
Race Roots Price: $595
TEAS stands for "Tanabe Electric Active Suspension" and is the counterpart of the Sustec Pro FIVE & Sustec Pro SEVEN suspensions. This compact unit is the 'brain' behind the highly sophisticated new Tanabe suspensions. TEAS is a fully programmable dampener controller that allows for dampening force to be automatically adjusted while driving. TEAS accomplishes this by connecting and using the signal from the vehicle's Speed Sensor.
Remote dampening control from within the vehicle is not a new concept by any means. In fact, many Japanese vehicles from the 1980's including the FC3S RX-7 and MA70 Supra had buttons to change dampening from "Normal" to "Sport." Unlike other controllers that are simply an update of this older 'analog' technology, TEAS is a much larger step towards highly digital advanced suspension control and tuning through it's speed sensing "Active Mode"
TEAS active dampening control is uniquely possible due to the use of the specialized valving of the FIVE & SEVEN, in conjunction with TEAS' slim, high speed actuators. These actuators change dampener settings in 1/100ths of a second, which is necessary as TEAS can continuously change settings at different speeds.
SUSTEC PRO S-0C MSRP: $990
Race Roots Price: $925
SUSTEC PRO S-0C is for those who desire both high performance and maximum comfort from a suspension system. S-0C is ideal for performance or street applications.
Dispelling a popular belief that a firm or harsh ride is a sign of a performance suspension, the short stroke, shortened case dampener of the S-0C is extremely unique in that it’s internal construction allows it to deliver superior handling without sacrificing strength or ride comfort.
Unique double-cylinder design allows for full suspension stroke within the shortened shock body while Low-pressure gasses ensure smooth rebound characteristics for additional ride comfort.
Spring Rate F/R: 8.0 / 8.0
Front Height Adjustment +1/4~-2 1/4in
Rear Height Adjustment: +1/4~-2 1/4in
Sustec GF210 Springs MSRP: $260
Race Roots Price: $220
The GF210 coil spring is geared towards maximum performance, without compromising daily drive ability. A subtle drop provides an aggressive stance, while the higher spring rates (+20% - 30% over stock) provide excellent handling and vehicle stability characteristics. These springs provide a very noticeable gain in performance when installed.
The GF210 is well mated with a performance shock upgrade to extract the full potential of the coil spring, but will also work with factory equipment.
Each coil spring application is tested for fitment and optimal weight distribution for sportier handling.
Spring Rate F/R: 3.2 / 2.6
Ride Height Drop F/R: 1.4
/ 1.2
Sustec NF210 Springs MSRP $260
The NF210 coil spring features a tasteful drop, and produces the best overall ride quality and comfort for a performance lowering spring. The lowered stance of the NF210 gives the car an elegant pose, while the spring rates, which are only slightly raised (up to 5% over stock) retain factory ride quality settings.
This coil spring is extremely popular with luxury tuned vehicles, as well as those with larger diameter wheels that want to eliminate fender gap, but maintain excellent drive ability while reducing the risk of damage to wheels that is associated with stiffer suspensions.
Comfort especially important on daily driven vehicles, and their passengers. The NF210 provides the best driving experience for all types of roads.
Spring Rates F/R: 2.9 / 2.0
Ride Height Drop F/R: 1.4 / 1.2
Ride Height Look for both springs:
Sustec Stabilizer bars
MSRP: $215
Race Roots Price: $195 each
Built for the driving enthusiast, the Sustec Stabilizer eliminates roll for exceptional stability and maximum tire contact patch and grip. Unique to the Sustec Stabilizer is it's FULL CHROMEMOLY steel alloy construction. Chromemoly's strength is such that a small diameter chromemoly anti-swaybar is significantly stronger than the standard steel anti-sway bars that are larger in diameter.
The Sustec Stabilizer has a carefully calculated OUTER and INNER diameter, for the proper amount of rigidity. The diameter and strength cannot be compared to other commonly available anti-sway bars due to the vast difference in material construction.
Chromemoly anti-sway bars have typically only been readily available to race users. The Sustec Stabilizer makes this lightweight, extremely functional race material technology available to all motorsport enthusiasts for a reasonable price!
Front Sway Bar Size: 30.4mm
[B]Rear [B]Sway Bar Size: 20.4mm
Medalion Touring Exhaust System MSRP:
[/SIZE]$990
Race Roots Price: $895
The elegant, well defined appearance of MEDALION TOURING is mature, and matches the artistry of a tastefully built, highly tuned machine.
Using the all new 'continuous strand' ADVANTEX packing material technology, MEDALION TOURING achieves extremely high levels of exhaust system efficiency, while maintaining a street drivable, extremely low frequency and deep tone that is well under 93db for discreet sports driving.
This system requires no removable silencer for under 93db operation. The extremely deep, low frequency tone keeps in-cabin noise to a minimum.
The full SUS304 stainless MEDALION TOURING features a slim-line oval canister, and a special dual wall, angle-cut tip.
Pipe Size: 70-60mm
Tip Diameter: 90mm
Old Mar 24, 2009 | 01:29 PM
Race Roots's Avatar
Former Sponsor
Springs in stock and ready to ship!
Old Apr 28, 2009 | 10:02 PM
Race Roots's Avatar
Former Sponsor
Sustec Pro S-OC Coilovers stocked and ready to Only $700 plus shipping
Old May 12, 2009 | 04:55 PM
renesisking's Avatar
you wouldnt happen to know the weight of the ultra medallion exhaust would you? Also if you have one laying around for like 600 which i doubt but i hope you do
Old May 12, 2009 | 09:46 PM
Race Roots's Avatar
Former Sponsor
You should just buy the springs from me here
13 lbs for the exhaust and no where near that price
Old Jun 2, 2009 | 10:48 PM
tbk's Avatar
tbk
ლ(ಠ益ಠლ)
just got my gf210 springs, cant wait to install :D
Old Jun 3, 2009 | 12:14 AM
Race Roots's Avatar
Former Sponsor
Enjoy!
Old Jun 3, 2009 | 01:11 PM
Jim UK's Avatar
how much for the Ultra Medallion Racing Exhaust shipped to the UK near london
yes its me again lol
thanks
Old Jun 3, 2009 | 06:08 PM
Race Roots's Avatar
Former Sponsor
Jim
You have been PM'd your answers
Old Jun 16, 2009 | 07:46 AM
Race Roots's Avatar
Former Sponsor
Ultra Medallion and Medallion Hyper Spec have both been discontinued!!
Old Jul 28, 2009 | 12:26 PM
Race Roots's Avatar
Former Sponsor
Tanabe Pro Sevens are now SPECIAL ORDER!
I have two sets of Pro-Fives instock!
Old Aug 11, 2009 | 09:30 AM
Race Roots's Avatar
Former Sponsor
Springs and coil overs in stock and ready to go!
Old Sep 20, 2009 | 11:00 AM
klanham08's Avatar
Blackin' Out The 8
Are the GF210 and NF210's price for a whole set of springs ($190)?
Old Sep 21, 2009 | 10:11 AM
Race Roots's Avatar
Former Sponsor
Price went up but I can honor that old price.
Old Sep 21, 2009 | 09:23 PM
d j's Avatar
d j
hukbong himpapawid
19.1 lbs. ...unless they have a newer and lighter version. I bought mine for $980 shipped 2 years ago. Last I heard it's been discontinued according to Brice.
How Long would it take for the Pro-Seven to arrive at my doorstep after sending the payment? and any specials deals for the Pro-Seven + TEAS?
Old Sep 21, 2009 | 09:29 PM
Race Roots's Avatar
Former Sponsor
You have a pm coming your way.
Old Sep 21, 2009 | 11:59 PM
@!!narotordo's Avatar
FLAME ON!
Killer stuff. I love Tanabe parts
Old Jan 14, 2010 | 11:16 AM
tbk's Avatar
tbk
ლ(ಠ益ಠლ)
Is anyone running the sustec pro s-oc on their car? I might be interested in getting it soon
Old Jan 21, 2010 | 12:37 PM
Race Roots's Avatar
Former Sponsor
Someone just ordered so maybe they will chime in
Old Jan 23, 2010 | 09:10 AM
tbk's Avatar
tbk
ლ(ಠ益ಠლ)
Actually that was me. :p waiting to install it soon
Old Jan 23, 2010 | 11:07 AM
FLAME ON!
So you did'nt buy the gf210 springs? post 6
Old Jan 24, 2010 | 01:49 AM
tbk's Avatar
tbk
ლ(ಠ益ಠლ)
Ya I did but that was a couple months back. Now I'm moving on to this.
Old Feb 7, 2010 | 07:11 PM
L337fpc's Avatar
ლ(ಠ益ಠლ)
Hey brice, can I get a quote on SUSTEC PRO S-0C shipped ground to 19440?
Old Feb 17, 2010 | 01:47 PM
DRKSYDE's Avatar
Vagitarian
Price quote on Pro 5s with TEAS shipped to 03743 please.
Old Feb 25, 2010 | 10:41 AM
Race Roots's Avatar
Former Sponsor
Our Tanabe shipment just landed yesterday we have more GF and NF Springs as well as some Pro 5 Coilvovers!
PM for a combo special on the Tanabe Pro 5 and TEAS together for an unbelievable price!
