{WTB} Need cat and exaust oem
Old 11-02-2017, 09:38 PM
Bullsinn's Avatar
Moved to MA and it won't pass inspection. Need a cat and everything. Let me know! I'm in Chicopee...can travel, I have a truck.
Bullsinn is offline
Old 11-05-2017, 04:17 PM
NorthShoreRotary's Avatar
I may be willing to part with my stock exhaust, depending on what you had in mind to spend. The exhaust has 51,xxx miles on it- it's the original system on my 2009 Touring.
Let me know what you were thinking!
NorthShoreRotary is offline
Old 11-06-2017, 09:50 AM
What am I doing here?
NotAPreppie's Avatar
S1 or S2?
Are they actually requiring you to get a full OEM catback or is it just the cat they're concerned about?
Shipping will be murder on the catback but I do have both for sale:
https://www.rx8club.com/rx-8-parts-s...4/#post4842239
https://www.rx8club.com/rx-8-parts-s...atback-266605/
NotAPreppie is offline
Old 11-07-2017, 08:03 AM
Bullsinn's Avatar
Working it
The dealership is working on the steering recall right now so when I get it back I’ll figure out what I really need. The guy doing the inspection just said the exhaust can’t be modified. I’m going to get the dealership to tell me what the min is for MA. My understanding is that it can’t be louder. Mine is fairly loud if you get on it!
Bullsinn is offline
Old 11-07-2017, 08:04 AM
Bullsinn's Avatar
S1 2004
It has a Mazda reman engine with about 12k on it. Nordic Green, GT. Love it.
Bullsinn is offline
Old 11-07-2017, 12:52 PM
Smoking turbo yay
UnknownJinX's Avatar
Originally Posted by Bullsinn
My understanding is that it can't be louder. Mine is fairly loud if you get on it!
Which mid-pipe do you use?
RX-8s are pretty loud even when stock, really.
UnknownJinX is offline
Old 11-07-2017, 02:10 PM
Not having a cat will definitely change the sound and make it louder. If you midpipe doesn't have a resonator then it's even worse.
Mine wasn't. Heck, even with a high-flow cat in my midpipe and Tanabe exhaust it's still pretty quiet.
Old 11-07-2017, 02:59 PM
Smoking turbo yay
Maybe I am exaggerating, or I just drive the car hard. The car is a bit louder than the V6 Accord I had, but it's definitely not ricer loud.
Anyway, most cheap resonators won't last in our exhaust. If a resonator uses packing, then it will be blown out over time.
Old 11-10-2017, 02:42 PM
Bullsinn's Avatar
Here is what I have
so I think a have a CAT and mufflers, I’ve never really looked at it before because well I never needed to. Looks like something was here
CAT? It has an o2 sensor on it
Part of the manifold?
Bullsinn is offline
Old 11-10-2017, 02:46 PM
Bullsinn's Avatar
Last one
Mufflers
Bullsinn is offline
Old 11-10-2017, 05:07 PM
Smoking turbo yay
Yeah, that's an aftermarket setup and a bad one at that.
There is no resonator as far as I can tell; it looks like a straight pipe with a cat welded on. Your car probably doesn't sound all that great and is loud as hell.
OEM cat looks like this(from my S2, S1 is similar):
Here is a proper mid-pipe setup with a single resonator(BHR mid-pipe + HJS Tuning cat):
This is what it looks like installed:
Read this page for more info on mid-pipes for our car.
Is there any indicator of which brand of cat it is? Cheap cats either will get melted by the heat our engines generate, or they simply don't contain enough of precious metal to eliminate the stank.
Old 11-14-2017, 07:46 AM
Bullsinn's Avatar
a picture is worth a thousand words! Thank you for the info. I would like to quiet this car down a bit so if I decide to not go back stock, do you guys have any suggestions for a good “ silent” system?
Bullsinn is offline
Old 11-14-2017, 01:07 PM
Smoking turbo yay
BHR mid-pipe is considered the best exhaust system for RX-8 here. It uses an unique resonator design that doesn't use packing and will last forever. Also sounds very OEM, just a little deeper.
As for the cat, BHR offers a cat option which will be adequate for street driving and anywhere outside of CA and NY, but won't hold up during track use. HJS makes cats that hold up during track use, but they are very expensive and you have to get them from Germany.
Old 11-14-2017, 01:18 PM
Well, you've got two components:
1) the midpipe (which should have a cat and a resonator)
2) the catback
Both will have an impact on volume and quality of the sound. I would start off by dealing with your current midpipe setup.
You'd be surprised how much a good catalyst and resonator can quiet things down. If you aren't getting a P0420 or P0139 code then your cat is probably in good shape and you can just have an exhaust shop weld a resonator in downstream from it.
If you want to get an OEM midpipe (with cat and resonator) PM me and we can talk price.
Once you have that sorted, you can decide if the catback is still too loud. Making a choice on which catback to use is tough unless you want quiet. Most aftermarket systems are designed to either be louder or freer flowing (which generally correlates with being louder). Really, the quietest option is going to be OEM.
Old 02-01-2018, 09:40 PM
Bullsinn's Avatar
Still searching
Update... well she failed the inspection again in MA. So I'm still looking for a good used stock exhaust system to replace what I have. Just spent a couple of hours searching on Internet and cant get there. We did replace the left headlight assembly, also did the recall work from Mazda on the front suspension...which they then didn't torque the bolts down...luckily they caught it on the inspection. Went to look at a spare 6 speed transmission and ended up with it and a motor! Now I gotta find a place to store it. PM me if you have a CAT...or the entire system...in the north east.
Bullsinn is offline
Old 02-02-2018, 07:33 AM
Sorry, I just sold the cat section of my OE midpipe to a guy in Texas. Used a reciprocating saw to cut it off at the bend in the midpipe.
That may be an option for you if you want to broaden your search geography. Cutting the cat off the midpipe at the bend reduces shipping weight and size significantly and any exhaust shop (or monkey with a MIG welder) can weld it in the appropriate place in your existing midpipe.
