{ FS } part out stuff
Old 10-23-2017, 06:26 AM
  #376
FULLY SEMI AUTOMATIC
200.mph's Avatar
Received 2,363 Likes on 1,992 Posts
Price: $10
Location (US State/Canada/Int): PA
rear diff/sub frame sold
200.mph is offline
Old 10-24-2017, 08:14 PM
  #377
eyeguy's Avatar
OE Battery tie down?
eyeguy is offline
Old 10-25-2017, 06:34 AM
  #378
200.mph's Avatar
ill check tonight but pretty sure i sold it with the batt. box
200.mph is offline
Old 10-25-2017, 06:45 PM
  #379
abevalle's Avatar
Does the ECU come with the keys?
Do you have the ABS pump from the same car too?
abevalle is offline
Old 10-26-2017, 06:23 AM
  #380
200.mph's Avatar
the abs module is posted on the previous page. it is from the same car as the ecu. i might have a key or two (ill check) but dont have the ignition where the key goes in
200.mph is offline
Old 10-26-2017, 02:03 PM
  #381
Received 2,007 Likes on 1,636 Posts
You'll need most if not all the CAN modules along with the PCM & keys otherwise it will require Mazda programming regardless
TeamRX8 is online now
Old 10-26-2017, 02:04 PM
  #382
200.mph's Avatar
thanks team, not sure exactly whats needed but i pretty much gutted the engine bay completly. is the rest of the stuff under the dash?
200.mph is offline
Old 10-27-2017, 07:47 AM
  #383
eyeguy's Avatar
So is that a negative on the battery tie down?
eyeguy is offline
Old 10-30-2017, 06:39 AM
  #384
200.mph's Avatar
checked this weekend, i sold the tie down with the battery box. sorry
200.mph is offline
Old 11-03-2017, 07:02 AM
  #385
200.mph's Avatar
friday bump
still have a bunch of stuff
oil coolers
fender vents
misc interior pieces
drive shaft
abs
ecu
etc, make some offers
200.mph is offline
Old 11-04-2017, 02:08 PM
  #386
KombuchaMshroom's Avatar
Needing a lock cylinder for my 04
KombuchaMshroom is offline
Old 11-04-2017, 02:11 PM
  #387
Assisi looking for plastic pieces for tree steering column
Old 11-06-2017, 06:35 AM
  #388
200.mph's Avatar
sorry dont have those
200.mph is offline
Old 11-08-2017, 10:12 AM
  #389
200.mph's Avatar
hump day bump
200.mph is offline
Old 11-13-2017, 08:35 PM
  #390
200.mph's Avatar
monday ttt
200.mph is offline
Old 12-01-2017, 07:20 PM
  #391
noredline's Avatar
Do you have motor mounts for a manual car? Looking to make some urethane filled ones but need a separate set so they can cure for a week. If so shipping to 48114 please.
noredline is offline
Old 12-02-2017, 12:43 PM
  #392
200.mph's Avatar
One is pretty beat up. Not sure if it matters if you are gonna fill them
200.mph is offline
Old 12-02-2017, 07:11 PM
  #393
noredline's Avatar
Thanks for the pics, yeah that one is pretty trashed. Not sure how even filling would be of much help. I'll pass, thanks again.
Old 12-06-2017, 12:28 AM
  #394
200.mph's Avatar
np and bump
200.mph is offline
Old 12-06-2017, 09:05 AM
  #395
They’re no good once the rubber breaks like that
Old 12-06-2017, 07:07 PM
  #396
200.mph's Avatar
thanks team, only one is broke. should i just toss them both?
and a bump
200.mph is offline
Old 12-10-2017, 09:02 PM
  #397
Scrappy
Legot's Avatar
Hey 200, any chance you have a lightweight flywheel?
Legot is offline
Old 12-11-2017, 06:25 PM
  #398
200.mph's Avatar
nope sorry
200.mph is offline
Old 12-26-2017, 09:46 AM
  #399
New Yorker's Avatar
Trunk liner, with no rips or tears? Mine has small tear on left side.
New Yorker is offline
Old 12-26-2017, 10:01 AM
  #400
200.mph's Avatar
nope sorry
200.mph is offline
Quick Reply: { FS } part out stuff
