{ FS } Defi Gauges, Racing beat header, BHR ignition
Old 08-06-2018, 11:41 AM
300zxsteve's Avatar
Sold
Price: $450
SOLD SOLD
For sale is a Defi BF set up. My battery was out of the car so forgive pics without lights on.
Gauges are the white model (white numbers, red needle)
It is oil pressure reading in KPA, oil temp and water temp reading in Celsius.
I have included everything you need to install on a Series 2. Oil sensors go in the driver side oil cooler with banjo bolts.
BF control unit is obviously included and you can run multiple other gauges as well.
Gauge faces have some very light surface scratches, but not noticeable when car is on. Also water temp connector is lose so some hot glue holds in in place (ugly but also not noticeable when installed)
SOLD
Thanks guys!
Attached Thumbnails Defi Gauges, Racing beat header, BHR ignition-img_6149.jpg   Defi Gauges, Racing beat header, BHR ignition-img_6150.jpg   Defi Gauges, Racing beat header, BHR ignition-img_6161.jpg
300zxsteve is offline
Old 08-06-2018, 12:59 PM
Th1nk_f4st's Avatar
Could you do 350 shipped for the ignition?
Th1nk_f4st is offline
Old 08-06-2018, 01:01 PM
300zxsteve's Avatar
What is your zip?
Th1nk_f4st (08-06-2018)
Old 08-06-2018, 01:08 PM
Th1nk_f4st's Avatar
Originally Posted by 300zxsteve
what is your zip?
03106
Old 08-06-2018, 03:42 PM
Th1nk_f4st's Avatar
Thanks for the ignition 300zxsteve, I cant wait to bolt it in and fire her up!
Old 08-06-2018, 03:45 PM
300zxsteve's Avatar
No problem. Thanks for an easy sale.
Old 08-07-2018, 07:41 PM
Clarks Summit PA
skippy1999's Avatar
will the gauges come with the install? Im in pa, and make a mean pasta! lol
skippy1999 is offline
Old 08-08-2018, 11:22 AM
300zxsteve's Avatar
Hahaha if you were a tad closer maybe.
Its actually a very easy install. I even did it without draining the fluids (some towels were needed though)
For the most part, you remove the battery and its box for the coolant temp sensor.
For oil sensors, you remove the driver side wheel, some clips for the well trim.
The wires run through driver side firewall. Tap the fuse box for power/constant.
Old 08-08-2018, 01:17 PM
300zxsteve's Avatar
Someone PM'ed a good question regarding gauge size. These are 60 MM gauges and will either need to be mounted like mine, or on a the a pillar.
They will not fit the Racing beat pod.
Also for those who dont know, these have warning alarms you can set.
Old 08-08-2018, 07:02 PM
Th1nk_f4st's Avatar
Buy with confidence! Steve shipped very quickly and was a delight to work with during the purchase process!
Old 08-09-2018, 03:01 PM
300zxsteve's Avatar
I appreciate the kind works.
Old 08-20-2018, 12:23 PM
300zxsteve's Avatar
Bump ttt
Old 09-11-2018, 08:12 PM
paporx8's Avatar
What’s the figment like for the RB Headers ? Did you have to remove motor mounta or was it a straight forward plug and play install ?
paporx8 is offline
Old 09-11-2018, 08:54 PM
300zxsteve's Avatar
You do have to remove the motor mount but its very easy.
Once the car is jacked up, you just use a piece of wood on top of a jack and brace the engine with wood under the oil pan. With the wheel pulled off the motor mount is easy to access. 3 bolts hold the brace for it, and mount is 2 bolts on the k member.
Racing beat has the instructions online, but you almost dont even need them.
Old 09-14-2018, 08:46 AM
Junior Member
Gabriel Washel's Avatar
Still got the gauges? If so, price?
Gabriel Washel is offline
Old 09-14-2018, 09:47 AM
300zxsteve's Avatar
$550 shipped to lower 48 states
Old 09-22-2018, 10:22 AM
NorthShoreRotary's Avatar
Is the racing beat header still available?
NorthShoreRotary is offline
Old 09-22-2018, 11:48 AM
300zxsteve's Avatar
Yes it is.
Old 09-22-2018, 01:09 PM
Yes it is.
Are you flexible at all on the price/shipping/etc.?
Old 09-22-2018, 04:11 PM
300zxsteve's Avatar
Not really. I spent nearly $600 to get it a few months ago. It has maybe 500 miles on it.
The price is good.
Old 09-22-2018, 06:24 PM
The price is good.
Perfectly understandable - you never know unless you ask. Right?
Any particular reason it looks like it has significantly more than 500 miles on it? I get it, it's exhaust, and next to impossible to keep clean, but that must have been a very spirited 500 miles!
Could you please let me know what the shipping would cost? Shipping to zip 60076. Thanks!
Old 09-24-2018, 11:25 AM
300zxsteve's Avatar
No worries. I understand asking for best price.
I have no idea why it looked liked that after such a quick time, but there's not rust or anything actually problematic. I have the receipt showing date of purchase and I only put about 2000 miles on my car the entire time I owned it. I honestly think its even less than 500 miles.
Anywho, shipping would be $50. PM me if you'd like it.
Old 10-15-2018, 11:20 AM
300zxsteve's Avatar
bump ttt
Old 11-07-2018, 01:44 PM
300zxsteve's Avatar
bump ttt
Old 12-10-2018, 10:12 AM
300zxsteve's Avatar
bump ttt
Quick Reply: { FS } Defi Gauges, Racing beat header, BHR ignition
