{ FS } RX8Performance Motor Mounts
Old 08-09-2017, 02:40 PM
Gangland's Avatar
WA RX8Performance Motor Mounts (( SOLD ))
Category: Drivetrain
Price: $100
Location (US State/Canada/Int): WA
Rx-8 Poly Mounts. These are from Rx8Performance. These are the heavy version. Made of steel so your ***** shake.
20k miles of heart pounding action on these.
CAUTION. You may regret these. They are totally dirty, rusted, flattened, and basically rekt due to BURNING the roads of WA State. The tickets these gaddamn things got me were 10 times as much as I payed for the car.
They groaned with every 10k 3rd gear clutch dump.
They screamed around the corners at Pacific RaceWay.
YOU CAN OWN THEM!!
For a limited time, YOU the LUCKY PERSON will have a chance to own these AMAZING motor mounts!!!
Seriously; Get some bigger washers that go around the whole top of the red busing. It will keep them from deforming. They will settle and loosen after time so get some washers to put under the nyloc nut and cinch the nut down hard the first time. The nut bottoms out on the collar of the bolt so you know its locked. Just make sure you pretension it hard before you mount to the frame. Use the washers between the nyloc nut to pretension, but use them equally. EXAMPLE - 3 washers this side equals that side (i never did this and they loossened and pissed me off). These come with an extra through bolt and nyloc of different size. For cars with the skinny main mount. Mounts were on a S1 Shinka, but "MAY" fit an S2. The onus is on you to decide.
Whatever.
Attached Thumbnails RX8Performance Motor Mounts-s-l1600.jpg   RX8Performance Motor Mounts-s-l1600-1-.jpg   RX8Performance Motor Mounts-s-l1600-2-.jpg
Gangland is offline
Old 08-09-2017, 02:43 PM
acroy's Avatar
^^ haha, great ad
FWIW, I moved the big washers from the bottom to the top, and vis-versa. Sha-bang. perfect. Great engine mounts.
acroy is offline
The following 2 users liked this post by acroy:
Brettus (08-09-2017), Gangland (08-09-2017)
Old 08-09-2017, 02:46 PM
Gangland's Avatar
Yeah they were good when they were brand new. I just didnt want to deal with maintenance. I filled a stock mounts with 80a and they are about the same. Shifts were A+. Not too much vibration with these either when installed correctly. Good mounts.
Gangland is offline
Old 08-09-2017, 03:47 PM
Boosted Kiwi
Brettus's Avatar
Received 1,489 Likes on 839 Posts
Originally Posted by acroy
^^ haha, great ad
Great idea .... I installed a big fat galv. washer from a building depot on top but your idea would have saved me much cursing .
Brettus is online now
Old 08-09-2017, 11:50 PM
No respecter of malarkey
Received 2,006 Likes on 1,635 Posts
You just under-tightened them the first time. If you crank them down until it bottoms the bolt sleeve they won't come loose no matter where the washer is placed.
TeamRX8 is offline
Old 08-09-2017, 11:55 PM
Gangland's Avatar
No I installed them correctly. They settled and loosened. Known issue, which is why I supplied the known fix, which was found on this website. Cheers for the post though.
Gangland is offline
Old 08-10-2017, 05:16 PM
Sorry, never had any issue on mine coming loose with the washers positioned as per the manufacturer.
I suppose you think you're quite the salesman too
TeamRX8 is offline
Old 08-10-2017, 09:43 PM
Gangland's Avatar
Yeah like I said I ******* beat on em. They're great, just want them to go to someone who will appreciate how hyper-amazing they are.
Gangland is offline
Old 08-10-2017, 11:49 PM
skc
rev it up
skc's Avatar
Mine came in aluminium
skc is offline
Old 08-11-2017, 03:19 AM
There are two metal material options/prices; stainless steel and aluminum.
TeamRX8 is offline
Old 08-11-2017, 12:56 PM
Gangland's Avatar
SOLD!! To a helluva guy with superior intestinal fortitude!!!
Gangland is offline
