{ FS } Metra Kit + Steering Wheel Interface + Aftermarket Head Unit
Category: Audio/Video/Electronics
Price: $200
Location (US State/Canada/Int): MI
The Metra Kit is the flat black version. The only issue I had with it was the clock would fall out of time with the head unit, but this is a common Metra issue. I believe a firmware update fixes it if you send the box to Metra (search, you'll find the answer).
The steering wheel interface enables the steering wheel controls to work (duh). The issue with this kit with regards to the RX-8 is you have to tap into the factory harness, as there is not a pin out into the Metra kit for it. I'm sure if you're better at electronics than me, you could put a pin into the Metra adapter that goes to the factory harness...I had no such patience and used a t-tap.
The headunit is a Pioneer AVH-X2600BT. The head unit sounds ground, but can produce distortion with the factory Blose...er, Bose speakers at higher volumes. More info on the HU here.
I'd like $200 OBO for everything together, but I'm willing to split things up if you need/want one piece. $75 for the Metra kit, $20 for the steering wheel interface, and $125 for the head unit (all OBO).
dmitrik4
06-13-2013 01:47 PM
johnsrx8192
11-22-2009 11:42 AM
