{ FS } Brand new Sakebomb IGN-1A coils
Old 03-07-2018, 09:43 PM
06 Shinka #774
lude1888's Avatar
Cool Brand new Sakebomb IGN-1A coils
Price: $515
I have a brand new set of sakebomb IGN-1A coils full kit. Bought them planning to do a turbo build, but changed mind in direction I am going with. So my loss is your gain. Sakebomb website is sold out for a while so here is your chance to get some asap.
$515 shipped.
From the website:
The IGN-1A Smart coils are a must have for high horsepower RX8's, and improve reliability by replacing the OEM coils, which are a known failure point. The issue most will face when upgrading to the marine coils is wiring them up and finding a location to mount them. We have designed a complete package for anyone looking for a completely bolt on mounting solution. IGN-1A Smart Ignition coils
Designed for two-stroke marine engines requiring lots of spark, these coils can not be beat for the rotary! Rotary and two-stroke motors behave very similarly with twice the ignition events per revolution compared to a standard 4 stroke motor (which more coils are designed for).
CDI-Level spark energy without a CDI make these IGN-1A Ignition Coils a must for boosted, high RPM, high compression and nitrous-equipped vehicles! The tradeoff between adequate spark energy and adequate spark duration ends with the IGN-1A High-Output Inductive Coils, the first inductive coils that deliver CDI-like spark energy and voltage, and a long spark duration necessary for vehicles running high compression, high rpm, forced induction and/or nitrous engines.
The IGN-1A High-Output Inductive Coils each deliver over 100mJ of spark energy and a minimum of 40,000 Volts - as much as most CDI systems, without the need for a CDI module! They also provide very long spark duration at full energy, unlike CDI systems and multiple spark systems which fire off small spark events prior to and after their CDI burst to mimic longer spark direction.
With our coil upgrade package IGN-1A High-Output coils easily install in place of your existing coils. They are constructed to operate in harsh environments and are shock and weatherproof allowing them to be mounted virtually anywhere. The High Output coils cost less than the cost of aftermarket LS1 coils and deliver World Class performance.
Highlights:
  • CDI-like spark energy without the need for a CDI
  • Available for vehicles with or without external igniters
  • Massive Spark Energy, up to 118 mJ!
  • Up to 41kV Output Voltage, without a CDI
  • Weather and Shockproof design
SBG IGN-1A (AEM/Mercury Marine) Smart Ignition Coil mounting kit
The mount we have designed places the coils in the stock location on the left hand side of the motor. As with most of our products the mount is completely bolt on and easily removable requiring no permanent modifications. It allows direct access to change plug wires, and also includes provisions for adding an optional heat shield.
Highlights:
  • Completely bolt on
  • OEM appearance
  • Black powder coated steel mount
  • Stainless steel mounting hardware
  • Aluminum anodized spacers included
Plug Wires
To compliment the mount we are also offering accompanying custom MSD SuperConductor Spark plug wires, for a true plug-and-play coil solution! to round out our package we offer custom made MSD spark plug wires specifically to work with our mounting solution (Custom lengths also available). Whether your car is stock or a 500HP monster these wires will suit your needs and meet or exceed your expectations. Our spark plug wires utilize MSD 8.5mm super conductor wires and the highest quality connectors and boots. MSD's 8.5mm Super Conductor wire sets feature a proprietary helically-wound core that has just 40-50 ohms of resistance per foot--but with an EMI/RFI suppression equal to a 1,500 ohm wire! What's that mean? More energy from your coils make it to your spark plug wires which would otherwise be converted to heat in a standard wire. Less resistance means less energy converted to heating the wire, resulting in a stronger spark and longer wire life. These are the best wires money can buy!
We stand behind these wires and individually test and record the ohm rating of each of your plug wires. Not only does this allow you to see the difference in your own wires compared to the others on the market, but also gives you a base-line reading to track the life of your wires over time.
Highlights:
  • Excellent EMF suppression
  • Outstanding Double Silicone Insulator
  • Ultra-Low resistance
Adapter Harness
The last and most important part of our coil upgrade package is the adapter harness. We created our harness to be easily adaptable and comes wired for waste spark. If you are currently set up for direct fire (or if you change setups in the future), the harness can be converted to direct fire by the customer within minutes.. You can find harnesses cheaper than ours, but we didn't want to compromise quality on our product by using cheaper components, which could cause issues down the line. Our harness is built to last and in the end it comes down to what you're willing to spend.
Installing our harness is as simple as unplugging the stock coils, and plugging in our harness. Since our connectors are compatable with the factory connectors there is no cutting or splicing required!
Highlights:
  • Mil-spec Wiring
  • 40 amp sealed relay
  • Isolated engine and battery grounds
  • Weather sealed fuse holder for dedicated power from battery
  • Cables labeled to be easily identified
  • Detailed instructions included
  • Easy install (no cutting or splicing required)
lude1888 is offline
Old 03-08-2018, 10:37 AM
Miracle's Avatar
IGN-NA coils
Good luck with the sale. I get mine today. Hope they'll do what I anticipate even though I'll be running NA for now.
Miracle is offline
Old 03-09-2018, 12:48 PM
06 Shinka #774
lude1888's Avatar
sold
lude1888 is offline
SBGarage
Group Buy Center
258
08-28-2019 05:21 PM
SBGarage
Group Buy Center
20
01-12-2017 12:54 AM
SBGarage
Sakebomb Garage
06-16-2015 01:39 PM
Silverisk8
03-08-2012 07:53 AM
brillo
01-16-2005 02:12 AM
Quick Reply: { FS } Brand new Sakebomb IGN-1A coils
