{WTB} BHR Ignition
Old 01-26-2017, 09:21 PM
KingKoopa93's Avatar
BHR Ignition
Category: Engine - Electrical
Price: $300
Part Fits (you may select multiples): Series II
Location (US State/Canada/Int): MA
looking for a set of bhr coils new or used, if used prefer lower miles but will consider all offers. looking to buy asap. thanks in advance!
Old 01-28-2017, 07:05 PM
40th anniversary Edition
gwilliams6's Avatar
I just did a search in our For Sale/Parts thread, and there doesn't seem to be any used ones for sale right now here among our members or vendors. It does happen that they are available used from time to time.
My advice just buy it new from BHR and get the parts warranty. Remember this is a kit that may well last you the entire life of your RX8, so it is worth buying it new. Charles of BHR gives fast shipping and great customer service.
Black Halo Racing Ignition System | Black Halo Racing
Old 01-30-2017, 01:54 PM
Life After 8K RPM....
Khurram's Avatar
Charles is a great guy and I can proudly vouch for him and his products.. Have had BHR ignition kit for over 150k kms never an issue with it..
good luck with your search.. It's better to wait and buy something that's proven time and time again. Please note, Charles offers lifetime warranty on his ignition kit and that warranty is transferable :-)
Old 01-31-2017, 04:11 PM
jtizzle88's Avatar
I looked at BNR price and they want $45 a piece for replacement coils. I got mine from Jegs for $20 a piece and I have an extra set of 4 in my garage that I am not using. It literally has about 7k on them. I thought I had bad coils and ended being buying new ones for test purposes and my issue was that the battery was disconnected and after charged it would shut off every 20 minutes. I read on the forum to do the Vram reset and was fixed. I left the new coils on though.
Old 02-01-2017, 07:54 AM
gwilliams6's Avatar
You get what you pay for with RX8 coils. The BHR is a proven "lifetime" kit that will last the life of your car and gives a stronger spark.
You have a number of options for coils:
- The Cheapest option: BWD/Intermotor coils from auto parts stores like Advance Auto. 4 coils, 4 plugs, and 4 wires can be had for around $190-220 total based on whatever promotion is running at the time, shipped to your door for free. They are considered to be the first coil revision and you should expect to need to replace them around 20,000 miles, 30,000 miles max. They often come with a "lifetime warranty" by the auto parts store, which could potentially be leveraged for perpetually new coils.
- The Best Upgrade:
The BHR ignition coil upgrade can be had for around $500, which eliminates the need to continue replacing coils periodically, as well as delivering a significantly stronger spark for minor mileage and power gains. It is a proven kit with top notch customer service supporting it. It includes the wires, you still need to add plugs ($80)
- The For-Sure OEM:
Mazmart sells all 4 coils of the latest OEM coil revision (C) for around $250, (just the coils, you still need to add plugs and wires) Supported by top notch customer service. They will likely last longer than 30,000 miles, but we don't have much solid data on how long the latest coil revision will last.
- The Most Expensive option:
Buying from a dealer will run you around $300+ for the coils, $500+ for coils, wires and plugs, and if you have them do the install, expect to get a bill for anywhere from $700 to $1,800. You may not get the latest coil revision. Yes, you are getting shafted if you take this option, so bring lube.
- The Highest Risk option: Ebay coils continue to pop up as counterfeit, mislabeled, dead on arrival, and have zero post-purchase support largely. They are the "cheapest" listed price, but when you add that $92 or whatever to the price of anything in the list above from having to do it over again, you can see that they are no longer the cheapest option. Do it right the first time. "Motor King" coils are popping up at an attractive price on Ebay, but are being proven as ineffective, to the point of being unable to get the engine fired. "Mazda" branded coils on ebay are almost always counterfeit. Check the seller's name though, since some of our vendors sell legitimate coils there. The price will be $200+ though. Anything sold as "Mazda OEM" under ~$26 per coil should really be considered as suspect and probably counterfeit.
Be wary of "LSx D585 coil upgrades", as not all D585 coils are created the same, and the standard generic D585 coil is not properly designed internally for the RX-8's ignition needs. They generally "work", but there are anomalies and performance issues that have to be solved, if they can be solved. Definitely NOT a plug and play option, even if it is advertised as "plug and play"
GB: SakeBomb Garage IGN-1A Ignition Coil Kit
Old 05-17-2017, 12:37 PM
ICT_RX8's Avatar
PM sent if still looking
Old 05-17-2017, 11:44 PM
Okki-Jakarta's Avatar
Im from asia and i still get new BHR coil kit from Charles. BHR FTW!!!
Still on it's way tho haha from a fellow friend. he's coming to asia and bringing me the kit, cant sleep everynight.
Old 07-18-2017, 11:06 PM
yeyo_racing's Avatar
PR I have one
I have a BHR kit available if you're still interested. Just pulled it with plans to sell it. Need money to cover some expenses for my move to Texas. Let me know.
Old 07-19-2017, 09:22 PM
RoToReez's Avatar
How much are you wanting for the kit?
Old 07-20-2017, 12:36 PM
Fijibluefg2's Avatar
I also have a kit available. Removed from running car. Looks clean and in good condition. I can send pics once I get home from work.
Unknown mileage. How's $250 shipped sound?
Old 07-20-2017, 07:41 PM
PR
Originally Posted by rotoreez
how much are you wanting for the kit?
$250 and comes with 4 extra coils.
