S.K.Y-Bulletins
S.K.Y-Bulletins
For those Mazda's with SkyActiv Piston Engines.
As always be careful that you match VIN # first (where shown) to see if your car is part of the TSB concern.
Discussion Thread for these TSB's is here...https://www.rx8club.com/general-auto...ssions-248772/
Mazda 6 Radar Cruise Control TSB..
There appears to be an issue with Radar Sensor in Grille on new Mazda 6.
Some radar sensors produced in a specified period are defective and they incorrectly detect as if dirt is adhered on the radar
DO NOT Grease Stabilizer Bar Bushes on New Mazda's
for the first time Mazda are using a new type of Stabilizer Bush on front and rear Bars for all new CX-5 and new Mazda 6..
They now use a 'grip type bush'..
This TSB is to inform Dealers NOT to use any grease.
I can't recall, but remember reading somewhere there was an owner who was having repeated issues with Auto Trans Oil Pan leaking after being @ a Mazda Dealer many times...
It 'could be' that the Oil Pan BOLTS also need renewing...?
Anyway, for the all new SKYACTIV Auto Trans..
As is the case with ALL new Skyactiv Auto Transmissions, the transmission Oil Pan Bolts must be renewed whenever the Trans oil pan is removed..
..see M tip..
This is the Part Number for the 16 SA Auto Trans Oil Pan BOLTS...
9YA0-10-615A Bolt...16 used.
..see M tip..
NEW TSB's FOR 2014
OK, Here are all new 2014 TSB's for ALL new SA Mazda KE CX-5, GJ Mazda 6 and BM Mazda 3...
They are for all (most) Mazda world markets, as these are from Mazda Japan they include many other nations where Mazda's are sold.
IF you are in North America, please check the Right Top of PDF to see IF TSB applies to your region or not...
ATM as I do not have time to 'triple check' everything I post to update remove or delete with any previous Skyactiv Bulletins listed here or TSB Revisions. I will leave it to the member to verify IF the Bulleting applies to YOUR VIN Number or Model.
There are also some SA Diesel TSB's for Europe and Australia.
