Hive Mind: Raspy growl at 4-6K, 2nd-3rd gear...?
Old Apr 17, 2012 | 09:14 PM
Wily's Avatar
Here's the situation:
When driving hard, I my 8 gets a raspy, growl (almost like it had phlegm in the exhaust) between 4 and 6K...then it kind of goes away.
The sound is definitely coming from under the hood and only under transmission load.
I am wondering about:
A. engine knock...but I run 91 (unless the corner gashop is getting funky).
B. A bad transmission...
C. Computer issue...
It has new plugs and new coils - 8K at least.
Any thoughts?
Old Apr 18, 2012 | 12:24 AM
shadycrew31's Avatar
WENTGERMAN
I'd get your mechanic to check out your muffler bearings.
Old Apr 18, 2012 | 12:33 AM
Hmmm. Maybe you have a Timber Wolf stuck under the hood.
Old Apr 18, 2012 | 12:36 AM
tronicj's Avatar
I get Paid $0.50 a Mile!
He said raspy growl! Timber wolf with a cold!
Old Apr 18, 2012 | 10:23 AM
Wily's Avatar
The muffler bearings are fine - they've been ported and chipped, too.
As for the wolf, it coughed up a cat.
Old Apr 18, 2012 | 10:24 AM
WENTGERMAN
Unsuccessful troll is unsuccessful
Old Apr 18, 2012 | 11:32 AM
well played Wily.
Have you checked the cat converter to see if it has come apart internally? Sometimes it will and the ceramic material will get spread throughout the exhaust system making this sound weird.
Old Apr 18, 2012 | 11:41 AM
WENTGERMAN
what about when you are sitting at idle and rev it to 4-6k?
Old Apr 18, 2012 | 08:39 PM
Hector Castillo's Avatar
That reminds me of my old cat remember 9k
Old Apr 21, 2012 | 08:11 AM
supergoat's Avatar
I don't "smell good".
Do you have an aftermarket intake?
Old Apr 28, 2012 | 03:48 PM
Darkning's Avatar
Try pre-mixing with some TCW-3 2 stroke oil(4-5oz with full tank of gas) and see if the issue noticeably quiets down. Could be a compression issue or lack of oil getting to the combustion chamber. Lucas upper cylinder lubricant could be used as an alternative to the tcw3 premix as a temporary test.
I searched high and low when I was having these symptoms and there were very few threads about this issue at the time.
Old Nov 14, 2016 | 09:22 AM
FlounderKS's Avatar
Hey guys. First time posting. I am also having this problem, and have used the Lucas Oil upper cylinder (clear bottle) which successfully eliminated this noise. My thought is I am having issues with my OMP or lines connecting it to the engine. I did have a compression test done back in May, and it did not score very high on it, however, I seemed to have remedied that problem by using the Lucas oil engine cleaner (white bottle) to remove carbon buildup. The car ran great for a while, but this is a new sound which seems to have been remedied by using the Lucas Oil upper cylinder. This is what is leading me to diagnose the OMP. Thoughts? (Currently no CEL's present and car is not running in limp mode)
RevMeHarder
Jun 1, 2026 02:30 PM
PTQLam
Aug 16, 2015 05:40 PM
dbarber
Jul 25, 2015 01:34 PM
Gord
22
Oct 7, 2007 05:09 PM
Sponge Bob
Aug 12, 2005 09:00 PM
