Cobb AccessPORT Discussion
Old Aug 17, 2010 | 07:24 PM
  #5851
RX8Soldier's Avatar
Time for boost...
When I hit the link, it says it's for the '04 model.. Can I still order that for an '05?
Old Aug 17, 2010 | 07:31 PM
  #5852
All models through 2008 are identical, including AT & MT.
Old Aug 17, 2010 | 07:36 PM
  #5853
RX8Soldier's Avatar
Time for boost...
Ordered! Thanks
Old Aug 17, 2010 | 08:25 PM
  #5854
gh0st's Avatar
Thanks to Charles at BHR, I just grabbed one of these. Thanks again for the heads up Charles!
So... does this mean i have only six month to install my turbo kit if i want MM to tune it? I dont even know if the greddy kit i bought is in working condition :p
man.. first post in 11 months.
Old Aug 17, 2010 | 11:53 PM
  #5855
RotaryMachineRx's Avatar
SPOOLN8
^ send an email to jeff and you can postpone your calibration start date if you bought the AP from MM site
Old Aug 18, 2010 | 03:27 AM
  #5856
Blacknightz's Avatar
gladz to know that... thanks!
Old Aug 18, 2010 | 08:47 AM
  #5857
darnellm's Avatar
Glad to hear that is the case.
I posted in the other thread that I had done the same thing ordered a '04 unit for my '05 RX-8.
I promise that I will read the instructions carefully
Old Aug 19, 2010 | 03:09 AM
  #5858
gh0st's Avatar
i shot him an email. his PM box was full. i hope he says its ok.
Old Aug 19, 2010 | 07:50 AM
  #5859
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
Don't use Jeffs PM box......he avoids it. Use his email address that is on his site.
Old Aug 23, 2010 | 10:43 PM
  #5860
map's Avatar
map
I want to make the most of MM's tuning when my AP comes so I'm going to push up some of the other mods I want to do. Which are the the best NA mods to put on and tune with to get the most out of them and my AP? I currently have a RB catback, looking at the following and prob have to pick one for now.
High flow cat (a bit worried about killing it with the AP though)
RB or AEM intake
BHR ignition (will wait on this one because my plugs and coils were done recently)
Old Aug 24, 2010 | 02:44 AM
  #5861
Tamas's Avatar
Registered Lunatic
If you will get the BHR ignition and want an intake different than stock, then don't buy the Racing Beat. It is very hard to remove the filter for cleaning due to the ignition coil bracket being in the way.
AEM would work OK.
Old Aug 24, 2010 | 05:24 AM
  #5862
yiksing's Avatar
the giant tastetickles
Originally Posted by map
High flow cat (a bit worried about killing it with the AP though)...
Wasn't aware that MM tune can kill a cat, can it?
Old Aug 24, 2010 | 08:03 AM
  #5863
SPOOLN8
^ N/A probably won't change anything with the cat
Old Aug 24, 2010 | 08:39 AM
  #5864
braden420's Avatar
would the addition of a prolite flywheel cause additional tuning to be required on a greddy turbo setup with the ap and mm custom tune? your not under driving anything or adding more air or fuel or changing temps , just allowing the engine to rev more freely so it shouldn't right?
Old Aug 24, 2010 | 08:51 AM
  #5865
yiksing's Avatar
Flywheel shouldn't matter at all.
Old Aug 24, 2010 | 09:35 AM
  #5866
Charles R. Hill's Avatar
Owner of BHR
Definitely does not matter.
Old Aug 24, 2010 | 09:37 AM
  #5867
laythor's Avatar
I zoom therefore I am.
stock tune on a NA car uses fuel to cool the cat. A MM tune can lean out the car to the point that decreased stock cat life can be a result.
Old Aug 24, 2010 | 09:41 AM
  #5868
Owner of BHR
How does that work?
Old Aug 24, 2010 | 09:43 AM
  #5869
laythor's Avatar
no clue, i'm just regurgitating what i was told by MM
Old Aug 24, 2010 | 10:10 AM
  #5870
The Cobb stage 1 mask the CEL but does this mean if I run a scan any hidden codes will show up? I recently scanned with my Goodbox and it says no codes are found but I am not running a cat and I don't have an air pump so I should still have those codes right?
Old Aug 24, 2010 | 10:18 AM
  #5871
If the AP has the codes turned off...they don't show up when scanned at all.....
Old Aug 24, 2010 | 10:20 AM
  #5872
Owner of BHR
He and I are doing some machine-work together in a bit so I will ask him about it.
Old Aug 24, 2010 | 10:22 AM
  #5873
Hmmm. I don't like that. Thanks. I guess I will have to edit that tune in AT and reload it So far the stage 1 is running great, I am not having any lean readings as people have reported.
Old Aug 24, 2010 | 10:38 AM
  #5874
Just turn them back on so you can get the light
Personally I shut off all the ones I don't want to see....and left the others
Old Aug 24, 2010 | 10:41 AM
  #5875
Yeah thanks, i'm going to look into doing that! I'll just shut off the ones I usually get for the air pump and rear 02 and just leave the others. Thanks man.
