Axial Flow Supercharger
Rating: Thread Rating: 34 votes, 4.53 average.
Old Apr 26, 2006 | 02:19 PM
  #3126
Dro's Avatar
Dro
Originally Posted by zoom44
i know im supposed to be looking at the CF( which is very nice , of course) but i cant help noticing the machining done to the top of the intake volute ver nice Richard.
haha I was checking that out too
agree with everyone else, it looks great so far
Old Apr 26, 2006 | 02:46 PM
  #3127
Richard Paul's Avatar
We did the CF work in concert with a friend of ours. We made the mold and he laid up the CF. He used an innertube to set the fiber sheet. From a bike actually.
We have a plate that fits over the flange area and put the tube in from the other end.
The oil system is tapped into the engine by a oil filter adapter, then drains to the pan. It's not hard to do on this car. The pan is ez to drop and weld or braze in a fitting. A plate will be in the kit to put under the oil filter. From a fitting on the plate you run a hose to the blower.
The machined part of the front volute is for me to keep all the parts and jets in when I'm changing carb tuning.
Old Apr 26, 2006 | 03:13 PM
  #3128
Aseras's Avatar
why not just go into the oil pan through the drain plug? You gotta clear the line ayways on a oil change, save a lot of trouble cutting holes in things...
Old Apr 26, 2006 | 03:41 PM
  #3129
Because I want to enter above the oil level. It may work the other way but it isn't really right. The line will not drain as fast at high speeds. Water seeks it's own level but it takes time and oil takes a little longer.
Idealy we will cast a new pan with a lower oil level and added capacity. Some fins on the bottom just for kicks and some extra cooling. Throw in some baffling around the pickup and you have good addition for even the NA cars. If you drive hard in the canyons consider yourself lucky when the level is even slightly low.
Just 'cause you don't see the oil pressure gauge drop in the curves doesn't mean it isn't. Why not? 'Cause you don't have an oil pressure gauge. Have you ever seen it read high when cold? Have you ever seen it move? That's because it doesn't, it always stays the same. It's not even hooked to a pressure sender. Have you ever had a car where the oil pressure was the same at idle? It starts out low then builds as RPM go up, right?
Fear not you always have the warning light. That probably comes on when your down to 10psi.
Don't blame the messenger, blame Mazda.
Old Apr 26, 2006 | 04:11 PM
  #3130
Aseras's Avatar
Thanks RP, I'm well aware the oil pressure gauge is an idiot gauge...
Now get back to work! I need me some supercharger luvin
Old Apr 26, 2006 | 04:46 PM
  #3131
deppenma's Avatar
Thanks for the info RP so it was a plug and vacuum bag process very nice job.
Can you send me your "friend" contact info My current supplier of CF is out of stock and does not truly know when he will get more in.
Old Apr 26, 2006 | 05:07 PM
  #3132
therm8's Avatar
Bummed, but bring on OU!
Originally Posted by Discman2
I hate to ask this (But I also hate to read 200+ pages worth of material):
Nothing for the 4 port?
Not likely as of 50 pages or so ago. I wouldn't count on it, unfortunately. Oh well...[plug for Hymee here]
Old Apr 26, 2006 | 07:47 PM
  #3133
rotarygod's Avatar
Because I want to enter below the oil level. It may work the other way but it isn't really right. The line will not drain as fast at high speeds.
Why is that? With a turbo you want the oil to drain above the level of the oil in the pan as it will back up into the turbo and eventually kill the turbo's oil seals. How is your seal different?
Old Apr 26, 2006 | 07:53 PM
  #3134
Rootski's Avatar
DGAF
How's far is the project from completion? and what additional upgrades will be necessary for the engine to be able to handle it?
Old Apr 26, 2006 | 07:55 PM
  #3135
Did I write that or did you go in there and change it??
I must be getting feable minded. I think the rest of what I said makes it clear that it is the same as a turbo. I don't think it was up there long enough for anyone to have built anything that way.
I'll go back and change it. Thanks for pointing it out, that means your paying attention. And I'm not proof reading what I write.
We are starting the install on my car in a couple of days from now.
Old Apr 26, 2006 | 08:23 PM
  #3136
Hymee's Avatar
Race Steward
Why does it have to drain? Won't it be under pressure anyways? Sorry for my ignorance - LOL!
I don't need to worry about that, as the blower has it's own gear box and oil reserviour.
Cheers,
Hymee.
Old Apr 26, 2006 | 08:48 PM
  #3137
You don't want to have oil pressure in the gear case just to force out oil. This overloads the seals and doesn't drain the heat away. Plus it foams the oil. The only oil you want in there is the spray from the nozzle aimed at the gearset. It lubes the gears and takes away the heat.
A luxury that you don't have.
Old Apr 26, 2006 | 10:21 PM
  #3138
Hymee's Avatar
Race Steward
OK - I get it now. I was thinking too much in terms of the turbo's bearings.
At least I won't be adding any heat to the engine oil!
Cheers,
Hymee.
Old Apr 26, 2006 | 10:37 PM
  #3139
zoom44's Avatar
well our 2 oil coolers can handle the extra little bit of heat much better than your standard single cooler
Old Apr 26, 2006 | 11:16 PM
  #3140
Hymee's Avatar
Race Steward
I think the gear set will might get even hotter than normal from all that hot oil from the engine! LOL :D
Cheers,
Hymee.
Old Apr 27, 2006 | 03:18 AM
  #3141
california style's Avatar
Londons Yellow Peril
ah cool... competition now...the regulators threat must have worked!
Old Apr 27, 2006 | 10:03 AM
  #3142
caribbean_spice_boy_73's Avatar
Work in Progress
go with the flow bro, nothing happens befor it's time..you asked for it,
Old Apr 27, 2006 | 10:47 AM
  #3143
Wurmfist's Avatar
FEAST!
While I might flame someone for asking this question on a thread that dosen't have over 200 pages. I can respect someone asking because frankly, it's impossible to read through the size of this thread. My only hope is that when it's released a new thread will be started. heh
Old Apr 27, 2006 | 10:51 AM
  #3144
Work in Progress
So true.. but in this case and stage the fun is getting there not being there....BTW .R.P. I am takign my car in to mazda tomarow to get a couple things fixed, should I leave it there for the install of the SC.. or have them tow it to your shop
Old Apr 27, 2006 | 11:40 AM
  #3145
Photic's Avatar
I WAS BEES
Hey Richard, I had thought about this earlier but I don't recall if I asked it or not.
It just popped into my head again.
Is the current design about as small as you can get it? Or would you be able to create a version that consists of 2 AFSC that are smaller in diameter that are next to eachother?
Maybe with like 3 blade layers on each SC instead of 5 on one larger one?
Old Apr 27, 2006 | 11:55 AM
  #3146
rotarygod's Avatar
The problem with that is that first off all it would be more expensive for him to machine. Since he makes the parts out of solid aluminum blocks, it would take more of them to make the required parts. It also isn't as simple as dividing them into 2 units and then cutting the stages down. Each stage gives a certain compression of the air. He needs those stages to get the desired pressure. Having 2 blowers wouldn't increase the pressure but it would increase the flow capacity. He's still need 4 stage blowers, just 2 smaller ones. From a money and complexity standpoint, 2 just isn't practical. You will also have more than twice the rotating mass even with 2 smaller units so that would be more load on the engine. One unit seems like the best option. It's already pretty small for a supercharger but even mounting 2 smaller units would be pretty hard to do.
Old Apr 27, 2006 | 12:07 PM
  #3147
I kept on thinking how much should I spend on the upgrades for this year, and after like X nights of lack of sleep. I decided that I will go extreme this time and spend up to 1/2 the price of what I paid for this car ! (Its extreme for me, and Im sure my GF would be ****, but ahh)
So .... WHEN YOU GONNA RELEASE IT ! (Or Hymee, if hes reading it)
Old Apr 27, 2006 | 12:53 PM
  #3148
okay, so it only took me about 2 years of this thread for me to finally post...
Haven't read all 200+ pages (just the last 3) but keep up the great work R.P.
Old Apr 27, 2006 | 07:28 PM
  #3149
Photic's Avatar
I WAS BEES
Yeah I figured it would cost more. I thought about the parasitic draw on the engine and I imagined 2 possibilities. A gear that spins them both that is attached to the belt at 1 point, or a serpentine belt between the 2. I was just thinking of space savings.
Although having seen it in person and holding it, it is pretty small already.
What really got me thinking about it was hearing that VW (I think) developed a Quad turbo design for a 4 banger engine. 4 small turbos, 1 for each cylinder. They said it cut down on waisted heat and turbo lag since they weren't as big to spool up and they were providing just enough cfm and pressure for each cylinder.
Was just a thought
Unfortunately I have a lot of them. Damn process wont stop. Even tried a Kill -9 on it.
Old Apr 27, 2006 | 07:50 PM
  #3150
AvatarQAZ's Avatar
Not as smart as you
A fellow linux man!!! Try using a kill -HUP... you dont want any orphaned thoughts.
You have already rated this thread Rating: Thread Rating: 34 votes, 4.53 average.
