More "Marbles in a Can" Observations
Old Apr 22, 2007 | 08:46 PM
  #176
Shinka-05's Avatar
streetfighter
I doubt that oil is the problem, or the solution.
when to the dealership today, and had them run a test on my pcm. It came up with misfires in both rotors "cylinders as the test said". I had heard to replace the coils and so I suggested it. They did it without really arguing, under warranty. I hope this fixes it.
so to all of you have taken your car to the dealership and they didn't run a test on the codes or nothing, this problem of a sound above 6k, I almost guarantee you, that it is a MISFIRE!!!
Old Apr 25, 2007 | 03:16 PM
  #177
Phantom Menace's Avatar
II SOCIETY
Well my wife took her 8 in to Mazda yesterday. They gave her a POS 626 that smells like "wet-dogs." They didn't tell her what part they are replacing but she picks it up tomorrow. When she comes back with the service order papers, I'll post them up.
Old Apr 25, 2007 | 03:45 PM
  #178
jisoo26's Avatar
RX-8 dreamer
Can't wait to see what happens, that marbles sound kinda freaks me out.
Old Apr 25, 2007 | 04:02 PM
  #179
shaunv74's Avatar
Power!!
Subscribing...
Old Apr 27, 2007 | 07:34 PM
  #180
II SOCIETY
MY WIFE HAS LOST HER MARBLES! So, my wife got her car back today and we revved it to redline. No more marbles! My scanner is acting up, so I'll just post what is on the service order:
"Job#1 20maz02 Cooling system--Cust. states at extreme high rev hear a girrgeling noise from right side dash. sop. S.O.P. from Brett at Mazda to fix issue. Installed valve as per Mazda, rechecked. Ok now."
Basically, that's all the recipt says. If you have any questions you can call the Service Department at Putnam Mazda (Burlingame, California) at 650-347-4800 and ask them what the "valve" they installed is. Just don't tell them I sent ya!
See...all it took was a 5-foot-nothing asian woman to get Mazda to make a fix for the problem that has been plaguing us for months, some for years! When I b!tched and moaned, I just got, "then don't rev that high..."
Old Apr 27, 2007 | 08:51 PM
  #181
shaunv74's Avatar
Power!!
Woo Hoo!! I'll raise a beer for the 5' nuthin' Asian woman! That's great news! Go tell it on the mountain brother!
Old Apr 27, 2007 | 10:01 PM
  #182
II SOCIETY
Can I get a witness-ah?
Old Apr 27, 2007 | 10:28 PM
  #183
shaunv74's Avatar
Power!!
AAAAmen!! Brotha!!
Old Apr 28, 2007 | 12:24 PM
  #184
jisoo26's Avatar
RX-8 dreamer
w00t! Time to call my dealership.
'ey, whut island you from brah?
Old Apr 28, 2007 | 03:35 PM
  #185
techserv's Avatar
That is great. My engine is making a rattling noise, almost sounds like engine knock, but mine does it between 3K and 5K RPM, not at the higher end of the RPM band. Mine is an AT, so that may be the difference. I had to take my car to the dealer yesterday because of the A/C unit (long story) and I got the tech to listen to the noise. He called the Mazda "hotline" and they told him that is an "air valve" on the side of the engine that is making the noise and that they are currently working on a fix for it.
Sounds to me like the same thing they replaced on your car. I guess I need to inform my dealer that the fix is available.
Good work!
Old Apr 30, 2007 | 05:14 PM
  #186
II SOCIETY
Sent you a PM, Brah! BTW, Bellevue? Mang, I was stationed in Bangor and Bremerton for a strech back in the late '90s. You ever seen a real, live, Bremalo?
Old May 1, 2007 | 07:44 PM
  #187
II SOCIETY
When/If anybody else gets this "valve" installed, please post? I'm curious as to know how many other dealerships are admiting to the Marbles phenomena.
Old May 2, 2007 | 12:24 AM
  #188
Shinka-05's Avatar
streetfighter
My dealership has had my car for almost 2 weeks total, trying to fix it... I had mentioned something to them about the valve. They shrugged it off, and said find out what valve exactly... Oh, and If you show a dealership the sound. They can't deny it. They might have the car for a few days and then say can't replicated it but just go in and show it to them. Anyways, when and if I get mine fixed I will let you know. And maybe soon I will post a printout of my misfire / pcm readout.
Old May 2, 2007 | 02:36 PM
  #189
Juggernaut9's Avatar
Phantom Blue
I have this valve as well. My "Marbles in a Can" sound went away for a couple of days but came back. They installed a restrictor valve next to the firewall on the pasenger side. Now its only between 4 & 5k and intermitent. Its also a different tone. The valve was only acnoledged by Mazda after my tech called Mazda's service line. It seems to be caused by the water (coolant) pressure at higher RPM's entering the Heater Core & causing bubbles to form. The hotter the coolant the more bubles form - leaving air in the system. And yes this issue IS KNOWN by Mazda...
Old May 2, 2007 | 03:32 PM
  #190
Shinka-05's Avatar
streetfighter
I am starting to wonder if this noise has anything to do with my misfires then. Either way my car has been in the shop forever now... and hardly a word.
Attached Thumbnails More "Marbles in a Can" Observations-rx8-pcm-readout.jpg
Old May 3, 2007 | 07:50 PM
  #191
Shinka-05's Avatar
streetfighter
Alright folks this is probably one of my last posts on this topic, hopefully. This "valve" I don't think is really a valve at all. The sound IS related to bubbles in the heater system or heater core, I will find out when I get the car back. Also I will find out if this cures it for good. I will post the form when I get it. But from what I understand it is a bad "orifice", which is what they said, or vent in the heater. It took me many times of talking and calling to get something to happen, GL to you all! I will post a copy when and if my car gets fixed.
Old May 7, 2007 | 03:00 PM
  #192
turbine's Avatar
4th Year runnin
Got mine fixed. I gave up on the dealer(s). After two years of dealing with this, I did manage to corner the problem. Took it to RX7 Heaven here in Memphis. Told them all I could about it, and I was right. There were several coolant leaks, which lead to an under presured system or a system that keep building air pockets. Most of the leaks where from the line going through the TB and Thermostat housing.
The DEALERSHIP will not be of use unless you have a CEL, period! End of story.
When I did the TB bypass a while back, no coolant came out. That should be a clue for some of you, maybe.
Also, over the past two years I had several issue's: Bad Coils & Coolant leaks. Together, they made it very interesting to nail down. Did I say the DEALERSHIP did not help in any kind of way.
Old May 8, 2007 | 11:08 AM
  #193
Design1stCode2nd's Avatar
OK who specifically or is their a number to Mazda I should call to get this "Valve" taken care of. I'm sure if I call my dealership they will have no idea what I'm talking about.
Old May 8, 2007 | 10:05 PM
  #194
Razz1's Avatar
Mu ha.. ha...
There's 10,615 views here and not one has posted an engine failure over this sound.
Get a life... It's normal
Old May 8, 2007 | 10:07 PM
  #195
TheKDog's Avatar
2007 BB RX8 GT
You get a life dude. Not every abnormal sound comes from the engine. If you had actually read the thread, you would see that people aren't scared of engine failure.
I don't have the marbles but I test drove one that had it, and it is annoying.
Old May 9, 2007 | 05:43 PM
  #196
ASH8's Avatar
Super Moderator
MMmm, Still think its Carbon Build up and or fowled spark plugs..
I bet the dealer replaced the spark plugs...I think Mazda (and NGK) are really stretching the mileage out of these plugs..
Old May 12, 2007 | 03:02 AM
  #197
Shinka-05's Avatar
streetfighter
Okay, so I have had coils replaced, this valve put in, and I still have the sound. Dealerships might not be able to fix it at this point, but the more people that complain, the more likely the dealerships/mazda will have to fix it. The second time I took my car in for this noise a MNA tech came in and like I stated... was not fixed still. 3rd time a Lemon?
I think turbine is right on this one... at least this is what it seems like to me. The dealership has been no help so far.
Old May 15, 2007 | 12:03 PM
  #198
WisslesRX8's Avatar
Just Nasty
This is crappy. I am having a similar problem. No specific RPM range. Doesnt do it all the time. Some days the car drives wonderful, but other days it seems like it just doenst want to go anywhere. Seems like temp. doesnt matter but it def. does it more on hot days. Ill pull out and accelerate all the way threw first gear. (First gear is usually ok) I get into 2nd and try to accelerate all the way through and i get the marbles and the car starts to hesitate like it doesnt want to move. Then goes a little, and then hesitates again. Had it at Mazda on several occasions and they continuously tell me that its fine. Coolant has been low twice now and i have to fill it back up which tends to be very temporary fix. If i had to guess id say i had a leak somewhere but idk....I dont believe gas is an issue. Ive ran nothing but 93 in the car and havent had the problem until maybe like 6 months ago.idk what to do anymore. The hesitation is rediculous, seems like there is no tourque at all. Have had the plugs replaced fairly recently, also tended to be a temp. fix but the problem came back. Had the injectors cleaned whiched made the car better, but again only temporary. Just seems like something is holding the motor back but i cant figure out what. Someone please help. Thanx for your time.
Old May 15, 2007 | 01:16 PM
  #199
LionZoo's Avatar
road warrior
I think you're pinging. Certainly not what some of the members here have as we've experienced in driveability issues, just an annoying noise.
Old May 16, 2007 | 06:53 AM
  #200
WisslesRX8's Avatar
Just Nasty
Well i know that i have a coolant leak somewhere for starters. Theres no signs of it on my garage floor so where ever its leaking out of its burning up before it has a chance to hit the ground which leads me to believe that its somewhere near that motor(obviously). The motor itself feels fine its just hesitating and makeing an odd (marbles) sound when i try and get on it hard. Could it be when im on it hard the coolant is leakin somewhere at that point? I just put a K&N short ram on last night and the sound has become much louder out of the drivers side of the vehicle. Might possibly be a spark issue or a fuel issue but my plugs are fairly new and like i said there have been no signs of any kind of leak. Any thoughts?
