Which wears first, fronts or rears?
Which tires wear out first, the fronts or the rears?
Stupid me didn't mark the OEM tires before they were unmounted for the winter, and now I'm not sure which tires to put where (2 are good, 2 are worn). I'm used to the fronts going first, but that was with FWD cars...
Rears wear MUCH faster, at least for me : ) I also bought tires/wheels from a guy on Ebay who claimed only 3000 miles. Two had 92% tread, two 62%. This was actually pretty close to my originals at 7K.
Originally Posted by scottmhr1
Rears are gonna wear more if your spinning them a lot, otherwise the fronts will. That being said, if you just rotate them when you should the wear should be equal!!
Thanks for the responses.... I'm going with the rears getting more punishment then
To finish up the thread, it looks like my FRONTS wore out faster, since the two worn tires are also the ones with badly scuffed edges/sidewalls.
I feel like such a wuss now.
I'll try harder... really I will!
Touge
Canada Forum
Sep 10, 2015 08:07 AM
Touge
Canada Forum
Sep 1, 2015 10:47 PM
