Helppppppppppp
Old Aug 28, 2003 | 10:18 PM
eclps0's Avatar
Helppppppppppp
i was puting a neon tube in the trunk and blew the fuse and then i put a new fuse in. Then turned on the car and the dsc light kept blinking and teh traction contrall light is on i try pushing the dsc light but no responce. what do i do.
Old Aug 28, 2003 | 10:25 PM
8_wannabe's Avatar
Go baby!
Re: Helppppppppppp
Originally posted by eclps0
what do i do.
Stop pimping out your car, for starters.
Sorry, someone had to say it. I know it's your car and your money and your right to do what you want. As to fixing the electrical problem, I have no idea. Best of luck on that; i'm sure it'll work out fine.
Old Aug 28, 2003 | 11:17 PM
P00Man's Avatar
uhhhhh....hello?
probably f*cked up the fuses
________
MASTURBATION *****
Old Aug 28, 2003 | 11:55 PM
eccles's Avatar
Prodigal Wankler
Re: Helppppppppppp
You must've blown a main fuse, because apparently you cut power to the ECU. The blinking DSC light indicates that you need to recalibrate the DSC. This involves turning the ignition on, turning the steering wheel all the way to the left, then all the way to the right, then back to center, and turning the ignition off again. At least, I think that's the correct sequence - it's described in both the owners' manual and the quick start guide that came with the car. A true case of RTFM.
Old Aug 29, 2003 | 01:11 AM
Napboy's Avatar
Sho'Nuff
i disconnected the battery and when i turned the car on, i got the dsc flashing. it turned off once the abs tested (i think). put it in reverse, then first, then shut off the car, then start it up again. that should fix the problem.
Old Aug 29, 2003 | 01:45 AM
mikeb's Avatar
100% Italian
If none of that helps go to a stereo shop they are normally good with those types of problems
Old Aug 29, 2003 | 08:58 AM
eclps0's Avatar
thanks everyone
all i did was i disconected the battery for 10 min hooked it back up and then i drove around the block and cleared it self.
i have a new rule for mt self i will not touch anything electrical with this car.
well thank you to everyone that gave me advise
Old Aug 31, 2003 | 05:39 AM
Squidward's Avatar
Bottom feeder
a lesson learned, some wisdom earned.
Old Aug 31, 2003 | 08:39 AM
KEF's Avatar
KEF
for future reference the tech-highlights CD gives a demonstration on how to reset most of the electronic systems, usually requiring set combinations of key turns in the ignition.
Old Sep 1, 2003 | 10:14 AM
khoney's Avatar
FX8TED on my RX-8
What tech highlights CD? How do I get one?
Old Sep 2, 2003 | 06:31 PM
U. N. O.'s Avatar
who?!
dude u crazy? o a stereo shop? they probably know less than we do, the car is so new.. they probably can't even get the wiring diagrams yet to install an alarm... how would they know about other fuses and stuff connected to the DSC??!
take it to mazda if posible , now THEY should know what to do..
