So whose taken off the Engine Cover
Old Aug 27, 2003 | 09:38 PM
Shocka's Avatar
WHAT.... YEAH... OK!
Ive been wantin to look at the engine but never got around to takin the covers off from under hood.
if anyone has.. got ne pix..
sux i started a new job and havnt had time to spend with my new baby.
Old Aug 27, 2003 | 09:46 PM
8_wannabe's Avatar
Go baby!
Re: So whose taken off the Engine Cover
Uh, this may be a silly question but instead of tapping away on the keyboard here why don't you go down and pop off the engine cover? Not that it's any of my business.
Old Aug 27, 2003 | 09:47 PM
Len's Avatar
Len
Here's a pic with the cover off. But if you have time to read this, you have time to open the hood and lift off the cover!
Old Aug 27, 2003 | 09:52 PM
Shocka's Avatar
its dark.. by the time i get back from work its dark... sux...
maybe tihs week.. i think i wanna leave it of, it shouldnt have any negative effects should it?
Old Aug 27, 2003 | 10:09 PM
TJRX8's Avatar
RX-R8ED
It helps keep the engine clean from road dust.
Old Aug 28, 2003 | 12:13 AM
rx8daniel's Avatar
remove cover to add oil...
You must take off the main cover to add your oil - if you've driven over 500 miles surely you may be wanting to add some. Please at least say you've checked the level if you've driven over 100 miles?!
Old Aug 28, 2003 | 02:29 AM
Squidward's Avatar
Bottom feeder
Re: remove cover to add oil...
What's wrong with the gauge on the dash?? is it not accurate?
Old Aug 28, 2003 | 06:56 AM
Shocka's Avatar
well i just toped 100 last nite.. so ill try to check it today when i get home from work
Old Aug 28, 2003 | 07:40 AM
rx8daniel's Avatar
that's great! I drive at least 90 miles any one day I drive it to work. The deal with the pressure gauge (it's in another thread of course) is that the gauge is in reality a 'dummy light' - if you have any pressure it looks the same as any other amount of pressure. In other words it's not reflecting the amount of oil or pressure but the presence of a minimal amount of pressure - you'd probably have to be a coupe quarts low, at least, to lose all presence of oil pressure so it can in no way be used as a guide to oil level...
which reminds me again - has anyone determined if we can get a real oil-pressure sending unit thingie for the Renesis??
Old Aug 28, 2003 | 12:04 PM
XK4's Avatar
XK4
Re: Re: remove cover to add oil...
A. It's shows oil pressure, not quantity
B. It's not a gauge, it's an idiot light in drag
C. Check your oil
Dave
Old Aug 28, 2003 | 12:53 PM
vudoodoodoo's Avatar
LOL!!!
Old Aug 28, 2003 | 12:59 PM
8_wannabe's Avatar
Go baby!
I agree with the need to check and add oil, but I do both without removing the engine cover.
Old Aug 28, 2003 | 01:07 PM
P00Man's Avatar
uhhhhh....hello?
how do you add oil without removing the cover? do you have a custom cover? or do you not use the fill-hole (not proper name...the opening underneath the yellow cap)?
________
Franco Cortese
Old Aug 28, 2003 | 01:10 PM
8_wannabe's Avatar
Go baby!
Sorry, my bad... it was a dumb comment. I haven't had to add oil yet (after 2200 miles, still nearly topped off.) I thought I recalled seeing the fill cap with the engine cover on, but I was wrong. Still, I can reach the dipstick without removing the cover. It'd be tough if you've got beefy hands.
Old Aug 28, 2003 | 01:23 PM
LesPaul's Avatar
I've had real trouble reading the dip stick. The oil seems so clear I have to feel for the wet spot. I suppose as the oil gets used and darker I'll be able to see it better.
Old Aug 28, 2003 | 01:33 PM
jtimbck2's Avatar
But then it will be time to change it
Like others here, I have not had to add oil yet -- when I check it always looks full. I have almost 900 miles on my RX-8. Now I'm wondering if I'm reading the dipstick correctly.
Old Aug 28, 2003 | 02:32 PM
f1michel's Avatar
Don't worry, pretty soon the oil light (just above the cruise light) will show and you'll think: "what the hell" than check the oil and see you're half way between the marks.
There was another thread about this earlier
Old Aug 28, 2003 | 04:36 PM
Squidward's Avatar
Bottom feeder
Re: Re: Re: remove cover to add oil...
C. Check your oil
Dave
Oh, I must be idiot.. okay okay I go do C now..
hehe :D
Old Aug 28, 2003 | 08:53 PM
B-Nez's Avatar
Tilt it at an angle under good lighting, and you should be able to see the level. Good lighting is key. I have to use a drop light in my garage - at least until I get the mondo duo-flourescents installed. Makes a real PITA to Zaino in the garage at night, too.
Jesus Martinez
44
May 6, 2025 08:09 AM
vapor2
Nov 3, 2020 03:38 PM
ShadowDragon78
Aug 21, 2015 03:29 PM
ShadowDragon78
Aug 11, 2015 06:42 AM
MolecularConcept
Aug 9, 2015 04:46 AM
