Check engine light flashes 3 times, then goes off?
Old Aug 10, 2006 | 07:28 AM
DailyDriver2k5's Avatar
The Prototype
This morning on the way to work, i got into some spirited driving. Never went pass 9,100 rpms, but noticed my check engine light flashed three times then went off. Drove normal , went to the gas station , filled up, continued on my way to work , the engine light stayed off. Car has 18k miles on it, and is a 2005.
Has this happen to anybody else or know of the cause for the engine light to flash 3 times, thanks.
Old Aug 10, 2006 | 07:39 AM
theboy's Avatar
RX8 newbie!
might be rotor is not balance, only happen when high speed. also might be apex seal is gone.
Old Aug 10, 2006 | 07:52 AM
expo1's Avatar
He's as bad as Can
Happened to me at the TRACK.
I blame high RPM'S, elevation changes, less than 1/4 tank of fuel. Dealer thought it was a misfire do to fuel starvation, changed the plugs and never drive hard with low fuel. No CEL's since.
Old Aug 10, 2006 | 07:58 AM
willhave8's Avatar
Holy pessimist! Probably scared the crap out the poster... I think I would pursue Expo1's direction instead of this reactionary one. You might be right but I highly doubt it. A CEL does not equal major engine failure.
I had one the other day because of a blown fuse...
Old Aug 10, 2006 | 08:45 AM
brillo's Avatar
Go Texas Longhorns!
its most like a misfire code, if everything else feels fine currently. Its happened to me once. I seriously doubt its anything catostrophic. If it happens again, take it to the dealer, you could have a coil pack issue.
Old Aug 10, 2006 | 09:02 AM
Paul_in_DC's Avatar
Rotary Public
We had that happen to a couple of us at the track. In the case of a single misfire, it blinks a few times and goes out; for more than one misfire, it stays on until cleared. Some reported that they can clear the CEL with 3 good (calm) driving cycles.
Note that a misfire is not the only reason you might get a CEL. If it stays on, see the dealer ASAP.
Old Aug 10, 2006 | 11:32 AM
The Prototype
You know that might be it, on my route this morning, they had to change the traffic patterns over a few rolling hills. In the process, i did have a little less than a 1/4 of a tank , that was the point where i was getting a lead foot(9,100rpm), plus the lanes swooped left from right and back again on these hills. Wow,All of that could have set it off! Crazy!
I guess that was the problem because i just came back from lunch and no CEL. Ran it hard , and no flashing CEL light, full tank too.
Thanks guys for your input.
Old Aug 10, 2006 | 12:35 PM
When the engine misfire, thats what you're going to see. (flash 3 times) if keeps happening then u have ALOT of misfire. but if it goes off then u should be fine.
Old Aug 10, 2006 | 01:00 PM
there is no cel meant to indicate any of that.
Old Aug 10, 2006 | 01:11 PM
Nopstnz's Avatar
Had this same thing happen to me when I had around 2k miles on the car or so. I punched it in first then slowly redlined second and got a flashing cel but it went off after 3 or so flashes. Can't remember if the tank was low or not though. I think it was below half but closer to the 1/4
Old Aug 14, 2006 | 11:30 PM
dastallion951's Avatar
yea ive had a blinkin cel thats usually associated with a misfire.......could be plugs startin to foul, which could happen at 18k, could also be bad ignition coils, if anything go tell mazda dealership problem u had, n request they replace spark plugs n ignition coils........that should take care of the problem.........
vapor2
Nov 3, 2020 03:38 PM
akagc
Aug 11, 2015 07:07 PM
marc2820
Jul 26, 2015 10:47 PM
Jmanie9515
Jul 20, 2015 07:29 PM
netrovers
Jul 20, 2015 03:32 AM
