my oil gauge doesn';t move at all
Old Jul 29, 2006 | 04:10 AM
hyogen's Avatar
Hyogen's RX-8
I dont' think it ever moves..it always is a few ticks above middle...
and it stays there even when the dipstick shows my oil level is below the recommended line
what could be wrong? :O
Old Jul 29, 2006 | 04:21 AM
dtorre's Avatar
Ultimate ****** Goderator
Its a dummy gauge there for the looks...will only move on extremes
Old Jul 29, 2006 | 04:24 AM
otherside's Avatar
I dont care...
There is nothing wrong. It is an oil pressure guage, not an oil level guage. You could be two quarts low and still maintain good oil pressure. Just check your level every 1500-2000 miles, thats about when I need to add a quart.
Old Jul 29, 2006 | 09:53 AM
RotoRocket's Avatar
Freely Radical
You should check your oil every 500 to 600 miles.
Old Jul 29, 2006 | 10:31 AM
Aseras's Avatar
it's only a on or off gauge.
Old Jul 29, 2006 | 11:18 AM
BunnyGirl's Avatar
Gee, I check my oil every Friday. That's somewhere around 350-400 miles usually.
Old Jul 29, 2006 | 11:20 AM
if it moves then its time to worry.
Old Jul 29, 2006 | 11:28 AM
Moostafa29's Avatar
Storm Trooper
^Yeah, if so pull over immediately.
Old Jul 29, 2006 | 06:22 PM
r0tor's Avatar
^... and for the love of god, check your oil level more frequently
Old Jul 29, 2006 | 10:13 PM
AdRoCK3217's Avatar
Rotary Superstar
I'm pretty sure you missed the point on that remark..
Oil pressure is supposed to fluctuate. Out stock gauges are COMPLETELY WORTHLESS! At idle it should be about 30-40psi lower then WOT. Buuuttt, it never moves.
Old Jul 29, 2006 | 10:22 PM
WhiteDealershipRice's Avatar
Actually... look at it (VERY) closely, it does move, just that it moves just short of a tick mark from idle to redline the rest of the needle's sweep range is unused. I wonder if there is a way to alter it to show a better representation of the oil pressure...
Old Jul 29, 2006 | 10:30 PM
Brandon's Avatar
Idiot guages are kind of stupid, but in some ways they are smarter than we are. A person will gladly watch a guage slowly creep up as long as they think they can get to their destination before they think something "bad" will happen. People can easily fool themselves into thinking they are taking an acceptable risk when it seems inconvenient to do stop and do something. But if the guage suddenly shoots up, it will get a pretty immediate reaction, as it should.
Old Jul 29, 2006 | 10:38 PM
no there is no way to alter it. in order to get an oil pressure reading you need to add your own sender and guage. the dash can module gets a signal from the pcm that indicates pressure or no pressure- on or off. thats it. there is no changing that.
Old Jul 29, 2006 | 11:09 PM
DOMINION's Avatar
I don't buy Kool-Aid
Question answered. Thread closed. lol JKing.
Old Jul 30, 2006 | 03:15 AM
Senna's Avatar
Merchant Of Pace
It sucks compared to the oil pressure gauge in my FD--which frequently varies depending on gear and speed etc....
Old Jul 30, 2006 | 01:58 PM
oreo's Avatar
on my FC it varied GREATLY from idle to medium load. Weren't all mazda oil preasure gauges supposed to be equally useless?
Old Jul 30, 2006 | 02:20 PM
Zeltar's Avatar
Makes you wonder. Why have the guage at all if it's just on/off. That should be an idiot light. They ought to give us a guage for oil level; instead of making us check it with a barely readable dip stick every time we fill the thing with fuel (per owners manual).
Old Jul 30, 2006 | 05:00 PM
Raptor75's Avatar
They want to give the illusion of full instrumentation but don't want to have to deal with low oil pressure issues from the owners.
Old Jul 30, 2006 | 07:07 PM
AdRoCK3217's Avatar
Rotary Superstar
Uh, how is that useless? If your gauge DIDN'T vary greatly from idle to load, you would know something was wrong. IE: a pinhole leak, low oil, etc...care to explain how you find that useless, hmm?
Old Jul 30, 2006 | 07:10 PM
msrecant's Avatar
Hubble has been saved!
The RX-8 instrument clutter (not misspelled) was designed to look cool (rather than be functional) to hit the car's target demographic.
Old Jul 30, 2006 | 07:53 PM
New Yorker's Avatar
Both correct. Ah, to live in a time when MBA's—rather than engineers—call the shots.
Old Jul 31, 2006 | 10:31 AM
Aseras's Avatar
yeah that's what the little oil light is for... which usually some tard comes here after driving home with it on and ask what does this light mean.. and then mugatu comes in and rapes them with a broken broom handle named search.
Old Jul 31, 2006 | 04:12 PM
jinsenser's Avatar
It is even worst. Those MBA's were in many cases engineers, turned into bean-counters. And many drive Porsches.
Jose, aka "Hey Boss, pay me an MBA"
Old Jul 31, 2006 | 06:11 PM
r0tor's Avatar
unless you have the oil temperature, pressure, engine rpm, and oil viscocity logged and continually calculating an oil pressure at the standard conditions for the rpm range and also the oil pressure chart to compare your numbers with across the rpm range - your real pressure guage isn't telling you anything a dummy guage isn't (you either got oil or don't)
Old Jul 31, 2006 | 06:25 PM
olddragger's Avatar
disagree r0tor,
for instance it wasnt until i gauged my car did i see for myself that it would not hold the manuel's identified normal pressure at 3K with the recommended 5W20 oil. Need less to say i now run a 5w/30. oil pressure gauge can also identify(we dont have one with the 8) oil pressure drops during high G moves. oil pressure gauges are useful. like everything else they have a specific purpose and thats all. for some drivers the stock one would be fine. just cant believe mazda cheaped out on gauges.
olddragger
