Wind Deflector Damage...
Old Jul 22, 2006 | 11:13 AM
fullsmoke's Avatar
Anatomy of a corner...
I recently decided to take off my wind deflector to detail the sunroof area. Then I discovered that I should have taken it off long ago...
It seems that the trapped dirt/road grime under the rubber molding of the deflector has slowly rubbed into my paint. Now there are two distinct lines from the two contact points of the molding--pretty faint, but noticible when walking up to the car.
I've tried to use bug/tar/sap remover, but to no avail. What should my next step be?
Thanks,
FS
Old Jul 22, 2006 | 11:30 AM
HolyCross05's Avatar
Herrroooo Rarrra
Touch up paint? post some pics.
Old Jul 22, 2006 | 11:40 AM
Low Fly'n 8's Avatar
https://www.rx8club.com/series-i-exterior-appearance-body-kits-27/moonroof-wind-deflector-leaves-lasting-impression-47667/
Old Jul 22, 2006 | 12:05 PM
fullsmoke's Avatar
Low Fly'n: Thanks for the link. What brand clay did you use?
Photo Update:
Attached Thumbnails Wind Deflector Damage...-im001803.jpg   Wind Deflector Damage...-im001805.jpg   Wind Deflector Damage...-im001806.jpg
Old Jul 22, 2006 | 12:13 PM
I use and highly recommend "Clay Magic" which can be purchased at any Auto Zone. I've read that it is better than the Maquire's clay bar. The marks are still there on mine if you look hard. I'm thinking the only way to really fix this is professional wet sanding / buffing. The optional wind deflector definately ruins the flowing lines of the 8, so mine never went back on.
Old Jul 22, 2006 | 01:22 PM
fullsmoke's Avatar
Sadly, I wish I had taken mine off from the get-go. It never bothered me until I saw the dirt trapped underneath it. Now this has happened!
Old Jul 22, 2006 | 01:38 PM
OneEvilRx8's Avatar
I AM SUPER MAN
Thanks,
FS
welcome to the club1, i'm in the same boat. but insted of buying clay, i'm selling the whole car.....
Old Jul 22, 2006 | 01:48 PM
tiggerlee's Avatar
May Cause Anal Leakage
I had the same issue. Claybar will remove it for sure.
Old Jul 22, 2006 | 02:15 PM
dtorre's Avatar
Ultimate ****** Goderator
I like my "racing stripes" from removing my deflector
Old Jul 22, 2006 | 02:18 PM
fullsmoke's Avatar
Next outing, I'll go pick up Clay Magic as Low Fly'n suggested. We'll see how it goes...
Old Jul 22, 2006 | 02:50 PM
SayNoToPistons's Avatar
Wheels, not rims!!
clay magic blue or mothers. i wouldnt use meguiars since theyre clays are knwon to be tacky and easy to fall apart.
Old Jul 23, 2006 | 12:03 AM
NgoRX8's Avatar
mother's for sure. maybe some polishing agent if it doesn't work.
Old Jul 23, 2006 | 12:07 AM
Wheels, not rims!!
there will still be some marring after claying because clayiing will only remove the dirt/contaminates... it wont remove the marring. so yes you might need some polishing. Meguiars Scratch X by hand.
Old Jul 23, 2006 | 05:09 PM
Stavesacre21's Avatar
1.21 Jiggawatts
This really does seem to be a common occurance with almost any car that has had a wind deflector for awhile. Usually some of the only choices you have are to claybar it really good and cross your fingers it's not too extensive, or to take it to a professional body shop and ask them to blend that area in.
Often times on top of the car, blending isn't near as obvious as hood or side blending.
Hoping the claybar does the trick for you though!
talonhart2
Aug 26, 2015 04:14 PM
blkswan
Jul 30, 2015 10:55 AM
needAnRX8
20
Nov 5, 2003 01:35 PM
RX8Lover
Aug 29, 2003 07:07 AM
