Exhaust Finisher Installation
Old Aug 20, 2003 | 04:41 PM
8th1der's Avatar
Question Exhaust Finisher Installation
Wow! I just received my exhaust finsishers from Trussville and I looked at the instructions and thought holy crap! It looks like a major project for the average guy. Has anyone installed these themselves or would anyone have any advice or tips on the installation?
Old Aug 20, 2003 | 04:52 PM
brothervoodoo's Avatar
RainMan is Back
Hello, some shortcuts have been discussed about installing the exhaust finishers. Try to search and find that old thread. It is exactly what you are looking for. Somebody actually documented and photographed the procedure.
Old Aug 20, 2003 | 05:23 PM
Mazdatrix's Avatar
Former Sponsor
http://www.mazdatrix.com/faqrx8/exhfinish.htm
-- Should help a lot --
Magnesium's Avatar
Lurking troll
Yes, there are alternate ways to install them and install them correctly.
It took me about 30 mins total to get mine on.
You should have purchased from www.mazdatrix.com
They are the ones I purchased through and they gave me the shortcut instructions.
Old Aug 20, 2003 | 06:35 PM
8th1der's Avatar
Hmmm....Live and Learn, I guess. Thanks alot for all the help!
Old Aug 20, 2003 | 06:38 PM
8th1der's Avatar
I just checked out the site and dang, that is a whole lot easier compared to the instructions that came with them. Thanks again!
Old Aug 24, 2003 | 02:43 PM
RXhusker's Avatar
Int-X 293WHP 242TQ :)
Finally got mine installed using the Mazdatrix short cut. This was my third attempt -- I had one of the fastener clips that would just not release. Well I "lost" that clip but then everything went smoothly. Doesn't appear any worst for the loss of one of the fasteners -- lets hope it stays that way! Glad to have my final accessory install completed. Still think the strakes were by far the best accessory purchase :D
Old Aug 24, 2003 | 05:46 PM
mikeb's Avatar
100% Italian
pics please
Old Sep 26, 2003 | 03:28 PM
xqos's Avatar
I bought the exhaust finishers, but sent them back after looking at them, they are cheap bits of tin and make very little difference to the appearance. The strakes are very cool and are the Alu thresholds.
Joe.
Old Sep 26, 2003 | 05:38 PM
mikeb's Avatar
100% Italian
I didn't get exhaust finishers because I know if changing the exhaust and I wanna make sure my exhaust fits first
Old Sep 26, 2003 | 05:57 PM
r0tor's Avatar
so after say a weak, can you actually see them or are they covered in exhaust soot?
Old Sep 26, 2003 | 06:46 PM
mikeb's Avatar
100% Italian
I hope that was a joke
Old Sep 26, 2003 | 09:01 PM
RXhusker's Avatar
The finishers look good -- just not as good as the strakes. Really can't see them when looking straight from the back. From the side angles ou get a good view of the metal. They stay clean -- no soot -- I usually just wipe them out when I am drying the car after a wash. I don't think they would hamper an exhaust mod. They don't really take any room or affect the opening by the exhaust pipe.
Old Sep 27, 2003 | 10:15 PM
hogleg.45's Avatar
I, too, bought a set of exhaust finishers from Trussville. They really don't stand out well at all, but are easy to keep clean. They were easy to install by using the following trick.
The only problem encountered with the "official"instructions dealt with the need to drill a hole thru the black plastic imediately above the tailpipes. Since a drill won't fit there, Mazda tells you to dismantle the whole back end! All you really have to do is use a small electrical soldering iron or gun to melt a hole right thru! Laying on my back in the garage, I was able to melt a hole , place the finisher in position, and reach around the bumper to secure the nut. It didn't take an hour! No extra fasteners or special clips were needed.
Ta-Dah!!
Old Sep 27, 2003 | 11:24 PM
mikeb's Avatar
100% Italian
post pics please
Old Sep 28, 2003 | 07:35 AM
red_rx8_red_int's Avatar
Excellant idea, using a soldering iron! I wish I would have thought of that. All you need to install them is a hole in the right place. I used the MazdaTrix shortcut and had difficulty at first. Besides depressing the center portions of the tabs, you need to pull really hard to get the black plastic pieces off.
Old Sep 30, 2003 | 07:50 PM
sandiegorx8's Avatar
Is Mazdatrix faster than the dealer? I've been waiting on rotary accents for weeks. They say Mazda keeps pushing back the delivery for the dealers. I got the bra pretty quick but the stuff I really wanted is taking forever!!!!:D
Old Oct 1, 2003 | 01:03 AM
mikeb's Avatar
100% Italian
mazdatrix is awesome
they are good people
Old Oct 4, 2003 | 10:20 PM
ectomort's Avatar
Mythical Member
Thanks for posting this trick, hogleg.45. Prior to seeing it, I had attempted installation using the Mazdatrix method a couple of times but wasn't comfortable with the amount of force required to release the tabs on the plastic cowling. (I know a couple of other posters have broken these tabs during the process; and I can't bring myself to hurt this car!)
Using a soldering gun, I was able to cautiously melt holes for the fastening screws. I'd melt a little at a time, with the finisher pressed firmly in place as a guide. Then remove the finisher and clean away the plastic "flash" from both sides of the hole. Repeat. Eventually the hole was large enough to accomodate the bolt and I fastened the finishers permanently. The whole job took me about half an hour and looks subtle but great.
Old Oct 29, 2003 | 10:04 AM
stang0013's Avatar
Great tip for using the soldering iron. Only took me about 10 minutes to install both and they look great.
Thanks.
Old Nov 1, 2003 | 11:41 AM
Evil Weevil's Avatar
... at risk of sounding like mikeb's echo, but....
PICS PLEEEEEEZ!
Old Apr 11, 2004 | 11:26 AM
spdspappy's Avatar
Make sure you clean the area...
Old Apr 11, 2004 | 11:32 AM
spdspappy's Avatar
Insert finisher & find where your hole is going to be.
Old Apr 11, 2004 | 11:33 AM
spdspappy's Avatar
Use soldering iron to go through hole & mark spot where you're screw-sized hole will be. Remove finisher.
Old Apr 11, 2004 | 11:36 AM
spdspappy's Avatar
Use soldering iron to make hole bigger until screw fits. Also, remove lip using selected tool (in my case, it was a lexan cutter used for R/C bodies). A reaming tool for lexan may also work to make the hole larger (I do not have one, so I didn't try it).
