Miscellaneous A/C question...
Old Aug 20, 2003 | 09:53 AM
RotorBoy's Avatar
I have friend whose A/C in her car is working fine when the car is in motion, but when stopped at a traffic light it gets hot. Not like just a tad warmer than when driving but actually hot. Anyone ever heard of anything like this?
BTW: It is NOT an RX-8.
Old Aug 20, 2003 | 11:05 AM
seikx8's Avatar
Is this title ok?
Probably condensor fan isn't working. May causes by broken fan, burned fuse, or the bad relay. To find out if the condensor fan is working correctly is to pop the hood and watch if the fan is running when the AC is on. If they are running, then that car may have some other issue.
Old Aug 20, 2003 | 05:50 PM
RotorGeek's Avatar
Still spining
He might just need some Refrigerant. He might have a small leak
Old Aug 27, 2003 | 03:12 PM
julian's Avatar
like seikx mentioned, it could be from airflow over the condenser, airflow over the evaporator (not likely though), or because the engine gets too hot underhood and the AC system can't cool the hot air. does holding the engine at a constant higher rev make a difference? what about turning on the interior blower to high?
Old Aug 27, 2003 | 07:42 PM
cueball's Avatar
Hopefully its not the condenser because I know that is a $600 part.
It most likey it the refrigerant ,though. Just take it to a shop and have them check it out.
Old Aug 27, 2003 | 08:03 PM
Doctorr's Avatar
Ricer is Nicer.....
Cool AC.....
At idle, the compressor is only working at about 8% of its design maximum speed - it will get a little less cold, though it IS still putting out, just not enough.
Because of the extremely high revs the engine can reach, the pulley is a little undersized for adequate idle output, it is just something you will have to live with.....
doc
RevMeHarder
Jun 1, 2026 02:30 PM
nadodave
Aug 28, 2019 05:55 AM
NotAPreppie
12
Sep 24, 2015 03:22 PM
djp6783
Sep 19, 2015 12:12 PM
mazdaverx7
Jul 21, 2015 07:31 PM
