Finally Installed my JL Audio 500/1, 10w6v2 and 4080 Box
Old Jun 8, 2006 | 02:34 PM
slllygrl10's Avatar
EX-Member
Wow I can't believe I did it! Everything was already prewired because I had an old system. After the install yesterday I drove my car for about 3 hours and the fuse blew. I asked people for advice and I decided to change the power wire to 4G because the 8G might be too small for the 500/1. Also yesterday I had a 40A fuse rather than 50A fuse which is recommended. So, today I wired a 4G and put 50 AGU fuse. I just hope I dont run to any problems anymore. Thanks Adrian-1 for all the help and selling me ur sub/amp/4080
Attached Thumbnails Finally Installed my JL Audio 500/1, 10w6v2 and 4080 Box-wires-001.jpg   Finally Installed my JL Audio 500/1, 10w6v2 and 4080 Box-wires-003.jpg   Finally Installed my JL Audio 500/1, 10w6v2 and 4080 Box-sub-001.jpg   Finally Installed my JL Audio 500/1, 10w6v2 and 4080 Box-sub-002.jpg
Old Jun 8, 2006 | 02:49 PM
ZoomZoomH's Avatar
Mulligan User
very clean install karyl, well done
Old Jun 8, 2006 | 02:56 PM
sharkman's Avatar
Wouldnt the amp get overheated with that cover over it....nice med rec by the way
Old Jun 8, 2006 | 02:58 PM
sharkman's Avatar
How long did it took you to do the entire install and how hard/easy was it?
looks good silly....
Old Jun 8, 2006 | 03:05 PM
Lookin' pretty good. Did you put 1 or 2 boxes?
Old Jun 8, 2006 | 03:42 PM
slllygrl10's Avatar
EX-Member
Adrian-1 has the same setup he didnt mention about overheating. Yeah thats why I replaced the picture lol
Old Jun 8, 2006 | 03:45 PM
slllygrl10's Avatar
EX-Member
Well yesterday it took me about 5 hours but today to put a new power wire it took me 2 hours. I can't feel the tips of my fingers!
Old Jun 8, 2006 | 03:48 PM
slllygrl10's Avatar
EX-Member
Only 1 box this is way better than my 2 xplod's I had before
Old Jun 8, 2006 | 03:50 PM
slllygrl10's Avatar
EX-Member
Thank you
Old Jun 8, 2006 | 04:08 PM
sharkman's Avatar
How does it sound? is it nice tight bass? i pretty much got the same setup in my garage waiting to get intalled .
Old Jun 8, 2006 | 04:11 PM
Napboy's Avatar
Sho'Nuff
I have a very set up, with two amps in the same place as yours. although i have a plexiglass cover, i've never had a problem with overheating so i think you should be fine. if it's a concern, the installer suggested that I drill small holes into the cover to release the heat.
Old Jun 8, 2006 | 04:16 PM
sharkman's Avatar
I was looking at a plexiglass cover, sound like the option i will probably go with. I would hate to blow my amp.
Old Jun 8, 2006 | 08:14 PM
slllygrl10's Avatar
EX-Member
It has a good bass to it I'm very impress.
Old Jun 9, 2006 | 12:56 AM
adrian-1's Avatar
Ex- member.
Great job.
Wow, a woman that does her own installs, that's HAWT!
I didn't have any overheating issues with the cover on. As far as the settings on the amp, checkout this link. They should already be set to that, then just play with the gain.
I've mailed you the power distribution block to use for the cap. It'll fit perfectly with your 4ga power wire, you'll just need some 8ga wire to run to the cap and theamp. Here's a pic of where I put it.
Old Jun 9, 2006 | 01:14 AM
Vengeance's Avatar
10w6 = greatness, I have 2 of them and if I crank it enough I can't breathe... Need EQ for 2 of them though, because its way too much most of the time.
Old Jun 9, 2006 | 09:11 AM
slllygrl10's Avatar
EX-Member
Yeah not until my bf changed all the settings! Thanks for the link this is very helpful. I bought me an insolator because the power wire/agu gets hot and I'm scared that it will melt. And thank you for mailing the distribution block.
Old Jun 10, 2006 | 03:47 AM
zerok1d's Avatar
my goodness, i wish my 8 looked like yours! ahaha :]
Old Jun 10, 2006 | 06:19 AM
slllygrl10's Avatar
EX-Member
Aww you'll get there!
Old Jun 10, 2006 | 10:12 AM
NgoRX8's Avatar
nicely done sillygrl
Old Jun 24, 2006 | 09:05 PM
slllygrl10's Avatar
EX-Member
Updated pics
Attached Thumbnails Finally Installed my JL Audio 500/1, 10w6v2 and 4080 Box-ampsub.jpg   Finally Installed my JL Audio 500/1, 10w6v2 and 4080 Box-ampsub01.jpg
Old Jun 25, 2006 | 02:47 AM
lesper4's Avatar
T-29 years and counting
looks very good and clean but no more golf clubs in the rear...you want to do mine now?
Old Jun 26, 2006 | 07:02 PM
Kel Rx8's Avatar
if your not 1st your last
looks good silly
Old Jun 27, 2006 | 08:52 AM
slllygrl10's Avatar
EX-Member
Thanks Kel
Old Jun 29, 2006 | 12:33 AM
LiL BenNy's Avatar
Bubblicious? DEF.
i have 210w6v2s running off a 500/1 amp.. anyone know how the sound would differ between her set up and mine? would it be bad if i got another 500.1 amp so it would be a 500.1 to each 10w6v2?
ed0128
Sep 9, 2015 04:50 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Rupanrx
Sep 4, 2015 06:44 AM
