disclaimer: stock endlinks w/ rb bar...
Old May 28, 2006 | 08:13 PM
brattesani's Avatar
broken swaybar king
i just sheared both bolts on one of my stock endlinks while autocrossing with the racing beat front swaybar, if you have this swaybar then get the bigger endlinks that racing beat sells, its worth it. cheers.
Old May 29, 2006 | 10:51 AM
dsmdriver's Avatar
BOTH bolts? How can you do this? Once one bolt in the system fails there is no more stress on anything else in the system. Just wondering if something else may have gone wrong...
Old May 30, 2006 | 12:02 AM
Remember when modding do research. Usually one mod can't be done, it needs the compliment of another mod.
Old May 30, 2006 | 12:23 AM
brattesani's Avatar
broken swaybar king
edit: i looked under my car and noticed that one bolt got sheared and is still halfway on the endlink and the other bolt + the blue endlink connecter thingy is still bolted on the car not connected to anything.
Old May 30, 2006 | 09:16 AM
dsmdriver's Avatar
Razz1, many people are running the stock endlinks in autocross and road racing with no problems. Maybe someone needs to do a search
Thanks for the update Brattesani- That makes a lot more sense.
Old May 30, 2006 | 10:52 AM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
First thing you need to do is lose that bar... No way you will make that work in BS trim.
I have to wonder if one of the bolts came loose and then broke. I know of a few people that have had the endlinks bolts work loose, then they can move around and I could see one break then. I have never heard of any autox/road race/etc car have a factory link fail.
Even if this was a weak area I would much rather have a nice cheap end link fail than a control arm issue after you drill out the stock hole.
Old May 30, 2006 | 04:02 PM
brattesani's Avatar
broken swaybar king
yeah we realized that the bar was to stiff about 5 days after we got it and ordered the mazdaspeed bar. i got faster times after the endlink fell off. the mazdaspeed bar uses stock endlinks, yes?
Old May 30, 2006 | 09:38 PM
mp5's Avatar
mp5
Yes, stock endlinks. If you are not already in the Mazdapeed motorsports program, you should sign up and get your new endlink through them.
Old May 30, 2006 | 10:10 PM
ULLLOSE's Avatar
Could have saved your money.... Joe G is putting the BS smack down on a stock bar.
There is such a small difference from stock to MS not worth the money imho.
Hector Castillo
Oct 6, 2013 06:31 AM
marka
Jul 26, 2012 01:59 PM
getemslough
Jan 7, 2012 08:57 PM
SoFL_RX8
18
Sep 21, 2006 10:33 AM
toxin440
48
Jul 18, 2006 12:06 AM
