Question about warrenty
Old May 22, 2006 | 01:54 PM
Bangadrum5's Avatar
I just failed my MV inspection for of all thing the gas cap. Does anyone know if the gas cap is covered under the warrenty?
Old May 22, 2006 | 01:57 PM
REV_ME_62's Avatar
If it is a defective part it can be replaced by your dealer "I guess" if it otherwise complicates the function of your car as a whole. Otherwise go to your local automotive store and invest on a $10-30 on a cap. That's that!
Old May 22, 2006 | 02:14 PM
Bangadrum5's Avatar
So are you saying that this should be covered by the warrenty or that it is kind of like brake pads and tires. Some that wears out and you need to replace.
Old May 22, 2006 | 02:16 PM
REV_ME_62's Avatar
Am not sure, but you should contact a dealer about this issue, give/show them a copy of your failed MV inspection. It may be a probability of having it replaced.
Old May 22, 2006 | 02:24 PM
Go48's Avatar
Failed gas caps is a fairly common occurance with the RX-8 and a dealer will almost certainly replace it under warranty if you show him evidence of why your car failed the emissions test.
Old May 22, 2006 | 02:41 PM
Glyphon's Avatar
脾臓が痛みました
i've never heard of a gas cap being considered as a "wear" item for warranty issues, but i guess stranger things have happened.
Old May 22, 2006 | 03:25 PM
Aseras's Avatar
wonder if the gas cap falls under the emissions rider.. ?
Old May 22, 2006 | 04:04 PM
Go48's Avatar
It's not necessarily a wear problem, rather a faulty, non-sealing cap that allows fuel vapors to escape. Usually, a CEL is thrown when the vapor containment system loses pressure due to a faulty cap. In which case, it is an emissions issue which the dealer (i.e., the manufacturer) is bound to rectify.
Old May 22, 2006 | 04:59 PM
Bangadrum5's Avatar
Well I spoke to the dealer and my car is going in for service at the same time the gas cap will be replaced.
Thanks for everyones help.
Old May 22, 2006 | 11:16 PM
unpocoloco's Avatar
Don't you know I'm loco?
Uh, what exactly is wrong with your gas cap? I noticed on the last two fill ups my cap unscrewed more easily than it used to. This time I made sure to screw it back on tight and I'll check it out next time. It doesn't really bother me, though, so I'm just curious.
Old May 23, 2006 | 11:54 AM
Duke15's Avatar
2006 Velocity Red Mica
Everytime I have had any of my cars inspected by their respective dealers while they were under warranty, they passed...
Evan Gray
Nov 24, 2015 01:00 AM
nferguson88
Oct 6, 2015 12:45 PM
pjwermuth
Sep 28, 2015 11:36 PM
kody59
Sep 28, 2015 03:43 PM
Learners_Permit
Sep 27, 2015 07:38 PM
